Does anyone have a wiring diagram for ADL 2000 -X 08 Amish heater?
I disconnected several wires and need the exact location where they go
    Novelist:
  • 166 Answers
I tried to search for it and was not successful but if the plugs into a 120 outlet--it's not too complicated green is always ground---white is always neutral---black(red-blue-yellow-any color other then white or green) is power(hot) via NEC---the power is always switched first (on/off) --then through (in) thermostat (control) then (out) to elements (in) and /or fan and/or light---then (in) each of the components then (out) connected to a neutral (white) this completes the circuit----IF YOU ARE FUZZY OR NOT SURE OF ANY OF THIS---- DO NOT ATTEMPT TO DO THIS --- GET AN ELECTRICIAN---YOU CAN CAUSE A FIRE AND/OR ELECTRICUTE SOMEBODY OR YOURSELF
Posted on Dec 06, 2014
Where does a Protection Wire Loop,Located?
as you can see on the diagram this "LOOP" is exactly what it says it is , a loop of wire that carries power thru all the safety limit switches to finally the engine run relay , just follow the wire hooked to each safety switch you'll see it 4 sure , But I will say its my experience that ive only ever found one machine with a broken wire harness(and it was obvious) , its most always a switch (bad or not set) if I were you id follow power thru circuit (switches) with a simple 5 dollar test light 1st
Dec 01, 2015 | Craftsman Garden
I need a wiring diagram to help install a Honeywell st9120c-4057 control board
SHOULD BE A WIRING DIAGRAM WITH THE NEW CONTROL THAT HAS CONVERSION CHART TELLING YOU EXACTLY HOW TO CONVERT OLD CONTROL TO NEW ONE . MUST BE LISTED ON PAPER EXACT CONTROL NUMBER IF IT DONT LIST IT YOU HAVE WRONG REPLACEMENT CONTROL BOARD.
Jan 11, 2014 | Honeywell Heating & Cooling
I need the diagram
You want wiring diagram? With recommended wire size?
This particular water heater has a factory-pigtail, and is direct-wired into octogon box, and appears to be 240Volt 6500 watts. Connect water heater to 40 amp breaker and 8 gauge wire.
Here is illustration:
http://waterheatertimer.org/images/Main-subpanel-Tankless-4a-8.jpg
Look at nameplate on device for amp and wattage rating to confirm exact power requirement.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
Oct 14, 2012 | American Heat ADK-3 - Electric 6.4KW...
I wanted to clean inside the heater and I happened to disconnect two wires and now that I connected them back to where I thought they belong it makes a short is there a way to see a diagram of the wiring...
I am not sure but if the wires comes from the resistors try to see how they were banded before. You cannot make a short. you will see exactly what you did when you'll power it up.
Jan 29, 2011 | Lakewood Economy Radiant LAK-205 Coil /...
Need wiring diagram for cadet the hot one heater so i can install new fan motor
You do not need a wiring diagram to replace the fan. TURN OFF POWER.
The fan will have two wires coming from it to two places. Make a little map of that location. There is usually a quick disconnect, you unplug and swap.
Nov 07, 2010 | Cadet Manufacturing Hot One® RCP502S...
Line voltage Tstat installation Dayton D-F79 elctric shop heater
If I understand your post correctly....You state that you are hooking up a 240v heater and towards the end you speak of removing jumpers...W2 terminals..ect. It sounds to me your trying to us a 24v low voltage thermostat instead of a Line voltage thermostat.That's what I'd take a look at.
Dec 16, 2008 | Dayton (3E379) Heater
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
