Question about Kirby Vacuums
How to put on attachment hose
How to attach hose on kirby vaccum cleaner
  • Kirby Expert
  • 324 Answers
Here is a walkthrough on that with pictures:
Vacuuming Bare Floor with Kirby vacuum
You will need to take off the nozzle to attach the hose.
Install Kirby belt and nozzle
800-775-6586
GoodVac com
Posted on Feb 27, 2015
SOURCE: Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
Don't listen to Solution #1, it is simply NOT correct. This is the correct answer:
As you stated, you already know where the water hose connection is. It is under the easily visible port cover on the top of the base.
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Posted on Dec 06, 2007
b0sslady2001
  • 357 Answers
SOURCE: Kirby Ultimate G will not suck with main brush head attachment
You need a new belt. When the green light goes out, the brush is not spinning. The belt is stretched and needs replaced. Here are detailed belt changing instructions....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope I have helped...
Marci
Posted on Mar 15, 2008
dthompson
  • 98 Answers
SOURCE: kirby attachments instructions
Ok, the hose goes on the front. The light should lift up then, the front emblem rotates. this releases the belt from drive shaft. Underneath where the light was, there will be a release lever, which will release the entire front end where the brushes are located.
Once removed, you will see the intake fan and bar beneath it. The hose hooks to this bar. Then to the left of intake, there is a safety switch. The end of the hose has an arm that will fit into this safety switch.
Once hose is in place, the release lever that loosened the brushes will now tighten the hose.
The bag stays in the same place. If you have the 2nd handle attachment, you can use that to replace the upright handle. The release button on back side of handle.
I own a G4 and used to sell the G6 which was right before the one you own. The G3 thru Ultimate G are work in the same manner just different colors.
Hope this was helpful.
Posted on Apr 22, 2008
Agent Don
  • 310 Answers
SOURCE: I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
Kirby G5 Bagged Upright Vacuum
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 23, 2008
RockyNR1
  • 324 Answers
SOURCE: need help attaching vac hoses to shampoo couch.
Here are the instructions. But please be very careful and shampoo an inconspicuous area prior shampooing entire piece of the furniture.
Posted on Nov 04, 2008
Looking for a manual for a kirby Heritage 11 modle 2HD
Hello
I did a search and found a very useful web site for owners of the same vaccum as yours im sure you will be able to get parts and possibly a manual, hope it helps
http://kirby-owners-club-shop.com/
Jul 23, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby turns on with hose attachement but not with head attachment
Front of the unit, black switch that is pressed by this plastic protrusion from hose coupling has two parts. It is because ANY generation Kirby has speeds - HIGH for vacuuming with hose and LOW for using it with nozzle.
Looks like the switch went bad (Switch HERE)
We have instructions for replacing it too.
The "funny noise" with hose throws me off a bit though. Check if there is nothing in the hose (put a nickle through it).
Good Luck
May 29, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Tradition Vaccum Cleaner - Model G 368811
There are so many attachments that it would take forever to explain them here.I would contact Kirby directly at 1-800-494-8986-and ask if they still have the owners manual.
Nov 18, 2008 | Vacuums
Shampoo attachment
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier. Now, put the shampoo gun on the end of the hose and you're ready to go.
Instruction manuals available in DVD, VHS or book format by following this link,..
http://stores.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQcolZ4QQdirZ1QQfsubZ7656839QQftidZ2QQtZkm
Hope this helps...
Aug 09, 2008 | Kirby Ultimate G Bagged Upright Vacuum
What hose gets hooked up for upholstery cleaner. The one that usually goes in front? I cant get my vacumn to turn on.
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic "cup" with two hooks and a screen on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. (if the hose isn't all the way on, the vacuum will not run) If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier. If this didn't help, I have mnauals available.
Hope this helps...
Marci
Jun 02, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Monday thru Friday
Go Ahead. Use Us.
Apr 23, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby attachments instructions
Apr 22, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
67 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
