Question about Building Materials
Need to reprogram remotes for Liftmaster 1255R
We tried to program our new car's built in garage opener, it didn't work as the dealer instructed, and now the remote doesn't work. Can't find the manual, and can't find one on line, so don't know how to reprogram the remote.
  • 504 Answers
YOU SHOULD BE ABLE TO FIND PROGRAMMING INSTRUCTIONS ON THE LIFTMASTER WEB SITE.
THE CAR PROGRAMMING DEPENDING ON MAKE AND MODEL WOULD BE EITHER HOMELINK.COM OR learcar2u.com/vehicle-list .
GOOD LUCK
STEVE
Posted on Dec 15, 2014
My opener seems to forget its program and needs frequent reprogramming
you are getting a break in power somewhere, perhaps a bad circuit board in the motor itself. the least expensive is to try a new remote.
Oct 28, 2014 | Sears Craftsman LiftMaster Chamberlain...
I have a 3 month old LiftMaster garage door opener. About 2 weeks ago, all remotes; (2) cars, keypad, and opener that came with the unit sometimes work and sometimes don't. I reprogrammed one of the cars...
Did you wipe out the codes in it.. It will only hold 3 or 4 code, not sure which.
See your manual, I think you hold program button down ten seconds to wipe all out. Then reprogram. Of course, should not have happened in first place... May be a board problem.
If this does not work you should follow instructions for warranty service. That might be your best course anyway. warranty it, else it may happen again after warranty expires.
Jan 26, 2011 | liftmaster Chamberlain Garage Door Opener...
I have two liftmaster's model 2500 one will not
I have the very same problem. I have 2 Liftmaster 2500, 1/2HP openers installed in a 2 car garage. They are merely 15 feet apart in my garage ceiling. About 15months ago one stopped working by only the remotes. Went through the process of reprogramming the good one 1st and replaced batteries in the remotes, then trying to reprogram the one not working. Checked for radio interference near the one not working no LED or Halogen Lights, no wall tarnsformers, no cell phone interference etc... Nothing worked to on the 2nd
opener in trying to get the remotes working again.
I then purchased a New Logic Board, part number 41A5507-B. It was about $70 and then installed it in the 2nd opener which is not working. Tried to get the remotes programed - still nothing? I was baffled. I called Liftmaster - the only suggestion they gave me was was to totally unplug the GOOD opener and try the reprogramming up close to the 2nd door opener that's not been working. SURE enough - the Opener Remotes "Learned" okay and started working! Liftmaster Help line indicated that the thought to be GOOD opener actual had the defective Logic board and it was over powering the signal from the 2nd opener which was not working. I'll be taking the New Logic board and replacing it in the 1st opener.
Thank you Liftmaster for the help !
Jan 17, 2010 | liftmaster Chamberlain Garage Door Opener...
My craftsman remote opens my neighbors Liftmaster door and visa versa. I tried to reprogram my remote and he tried his, yet they still open both doors? The way that I did the reprogram was to hold the...
This problem was exposed on a popular news program some ten years ago. There's a number code inside the remote that you have to change, and set the garage door opener to the same code. It should solve the problem.
Oct 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster security+ garage door opener. My car remote does not open the door anymore. Is there someway to reprogram the remote again? We are also having problems programing the remote in our car,...
If the instructions for programming your car remote has you using your original remote and the original remote has quit you will need to purchase a new Liftmaster remote.
Oct 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have Chamberlain LiftMaster 1255R garage door opener. The electric eye does not lit and the opener unit flashes 5 times and then off. Do you know what the problem may be?
My garagedoor opener is not working.
I open the box and found the plastic gear worn out.
I have Liftmaster 1255R.
Do I need to replace the whole box or replace the worn gears?
Jul 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
HomeLink works in vehicle... unable to program hand held or remot
When did your remote and keypad quit working? Was it when you programmed the Homelink? It sure sounds like you have a bad logic board.
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Reprogram keypad with new code
Here is a link that will give you the programming instructions for your model.
Use the model number from the motor unit, not the remote. I believe that Craftsman now goes under the Liftmaster name.
http://www.garagedooropeners.us/helpgifs/maincode.html
Mike
Apr 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
I CAN NOT PROGRAM MY BUILT IN CAR REMOTE ON MY NEW 139.53985DM
didnt try everything cause if you did, it would work! Get two people and garage door opener. One read manual from car under Garage door" or Homelink while other pushes button. When manual says if this did not work or if you have security plus or rolling code, continue with other instructions. You will need a working remote and will need to pushh learn button on motor logic board.
Dec 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
96 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
