Question about Electrical Supplies
McCullough FG2000TC Digital Generator. On/off switch snapped off.
Ihave gas generator McCullough 5700with 11.0 i need the recoil cord
There are pull start cord repair kits in the garden section of home improvement stores.
Apr 15, 2017 | Garden
Power board for McCullough Generator, FG5700. price & availability
Not exactly sure what you are asking..... But you can buy all the parts for these McCulloch Generators here:
http://www.generatorguru.com/mcculloch
Nov 27, 2016 | Electrical Supplies
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
My champion generator runs great but the voltage meter stays at 0
Is it digital or analog desplay if analog its nomally something simple like a wire has come loose or snapped. If digital also check wiring if not best get a professional have a look
Dec 26, 2014 | Electrical Supplies
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Fg2000tc tried a 1000 watt jack hammer but overload alarm came on what to do
Your gen. is a 2000 wt max 1000wt running out put. Means it will start your jackhammer but will not maintain the wattage to run it long. You are using the max it has to put out. So let me try to explain - 2000 watt max output works like this - We will use a fan as an example. A fan sitting still and not turning takes more amperage/watts to start. that is called lock rotor amps. So lets say the fan is a 1000w to run. 2000w start the fan turning then it takes 1000w to keep it turning. Your gen. can start the fan but not keep it running it is using all it has to put out, now if that fan only uses say 750 w running watts you have some head room to keep it running with out things getting hot. Hope this is clear as mud.
Jun 06, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
How to change alternator on 2005 Jeep Wrangler Unlimited?
Straight out of the repair manual:
REMOVAL
WARNING: DISCONNECT NEGATIVE CABLE FROM BATTERY BEFORE REMOVING BATTERY OUTPUT WIRE (B+ WIRE) FROM GENERATOR. FAILURE TO DO SO CAN RESULT IN INJURY OR DAMAGE TO
ELECTRICAL SYSTEM.
(1) Disconnect negative battery cable at battery.
(2) Remove generator drive belt. Refer to 7, Cooling System for procedure.
(3) Remove generator pivot and mounting bolts/nut (Fig. 2) , or (Fig. 3). Position generator for access to wire connectors.
(4) If equipped, unsnap plastic cover from B+ terminal.
(5) Remove B+ cable output terminal mounting
nut at rear of generator (Fig. 4), (Fig. 5), or (Fig. 6). Disconnect terminal from generator.
(6) Disconnect field wire connector at rear of generator by pushing on connector tab.
(7) Remove generator from vehicle.
INSTALLATION
(1) Position generator to engine and snap field
wire connector into rear of generator.
(2) Install B+ terminal to generator mounting
stud. Tighten mounting nut. Refer to Torque Specifications.
(3) If equipped, snap plastic cover to B+ terminal.
(4) Install generator mounting fasteners and
tighten. Refer to Torque Specifications.
CAUTION: Never force a belt over a pulley rim using a screwdriver. The synthetic fiber of the belt can be damaged.
Jul 05, 2009 | 2005 Jeep Wrangler
McCULLOCH FG2000Tc engine starts but idle
Check the valve clearances with a feeler guage. Over time the valve lash adjustment vibrates a little looser than we want and the engine gets hard to start, runs rough, etc. After the engine warms up the heat makes the valve tappets expand enough to make the engine smooth out.
Regards,
Carl
Feb 26, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
McCulloch generator stops after about a minute
Have Generator McCullough FG 6000 was running fine motor still running fine than NO power output, any suggestions ?? Can you get replacement parts and repair diagram off the interent ??
Sep 30, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Electrical Supplies Logo
104 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
