Question about Dell 1720dn Laser Printer
My Dell 1720dn mono laser printer has not printed properly for some time - in fact it's dreadful! The letters and dark images have white vertical lines going through them, and some of the printing do
No error codes or warning lights appear. Printing just deteriorates. Periodically (when printing becomes really bad) I clean off excess toner from the rollers that I can access easily.
  • Dell Master
  • 1,915 Answers
Change your toner cartridge. A properly working toner cartridge will never leave that much toner lying around. The white lines are an indication that either the toner is low, or the mag roller is defective.
Posted on Dec 05, 2014
Testimonial: "Mark left a quick and helpful reply to my query."
  • Jayvee
    Jayvee Dec 05, 2014
    Thank you Mark for your prompt response. I appear to have almost half the toner left (according to the indicator popping up on the screen when I use the printer). So perhaps it is the mag roller, which I'll look into. Though you'd expect it to last more than 500 pages?
5mm vertical gap dell 1720dn
Any time an imaging drum is replaced on a 1700, 1710, or 1720 model dell laser printer, you must reset
the photoconductor count. The following procedure illustrates how this is done:
1. Open the front access cover
2. Press and HOLD the Cancel Button (Red X)
3. When you see the LED's 'Chase' turn the printer off
4. Close the access cover, and turn the printer back on
5. Press the Continue Button (Green Triangle) to print a settings report
6. Under the section 'Cartridge Information', locate the item 'PHOTOCONDUCTOR COUNT=0K' indicating 'Zero Thousands'.
s now been reset, and you should now be able to print now ok
May 06, 2014 | Dell 1720dn Laser Printer
1720dn Laser Printer: printer offline. unable to set online....
I Open my browser....I signed in to my router as administrator ....
Mine is 192.168.1.1 ....
I went to status in my router ....
Then to local network ....
Then to DHCP Clients Table ....
This is how I found what printer address the was.... Then I typed the printer ip address into my browser
Mine happened to be 192.168.1.105 ....
Yours will probably be different....That got me to the 1720dn printer menu ....I clicked on Configuration ....
I clicked on Print Server Settings
I clicked on TCP/IP
I clicked on Set static IP address.
I changed IP address from 192.168.1.105 To 192.168.1.125
and Submit....Now you can get to the printer menu at 192.168.1.125
Go to run....
Printers & Faxes
Right click on Dell laser printer 1720dn
Properties. Ports ....
Add port ....
Double click on Dell Enhanced TCP/IP ....
I named the port My dell laser 1720 dn....Where it said enter a single IP address or host name I entered the new address 192.168.1.125
the clicked OK ....
Properties....Ports
Choose your new port ....
May 06, 2010 | Dell 1720dn Laser Printer
Problem with Dell 1720 printer
Hello
You have to check couple things in this case.
Ensure that the printer cover is closed.
  1. Remove the toner cartridge.
  2. Firmly shake it side-to-side and front-to-back several times to redistribute the toner.
  3. Reinsert the toner cartridge, and continue printing.
Repeat this procedure multiple times until the print remains faded. When the print remains faded, replace the toner cartridge.
or
The imaging drum is approaching full and needs to be replaced. Order a new imaging drum.
Apr 30, 2010 | Dell 1720dn Laser Printer
I need to print 5X8 index cards on my Dell 1720dn. No matter how I load the cards, it says I'm out of paper
Are you using the manual feed slot in front of the printer and setting the paper size properly in your software? 3x5 is supported by Dell so this should work.
Aug 28, 2009 | Dell 1720dn Laser Printer
Dell 1720dn has gray streaks in printing
That green drum is the imaging drum, and it needs to be replaced. You can purchase directly from dell:
http://accessories.us.dell.com/sna/productdetail.aspx?sku=310-8710&cs=19&c=us&l=en&dgc=SS&cid=27530&lid=627063
After-market replacements are available as well from a number of online sellers. A search on Google will provide many links.
Feb 13, 2009 | Dell 1720dn Laser Printer
Dell 1720dn Printer
Sounds like the fuser needs to be replaced or the pick up rollers need to be replaced
Feb 12, 2009 | Dell 1720dn Laser Printer
Popping noise when i print
if there is a clicking noise, check the paper tray. either the tray is overloaded or the paper guide is not set properly.
it's common for the blue paper tab in the paper tray to slide back. the tab has a little square cut out. make sure that it says "LTR" if you use regular letter size paper (8 & 1/2 x 11 inch).
Dec 12, 2008 | Dell 1720dn Laser Printer
Dell 1720dn Laser Printer Logo
126 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
