Question about Baxter Ovens
Oven is working properly but the temp inside the oven is way up the temp display how can I adjust to compensate the display this for baxter rotating oven model ov210-g
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Oven temp. is off at times, varies how many degrees
Replace the thermostat, and it should solve your problem.
Please rate my solution.
Thanks.
Posted on Nov 10, 2009
SOURCE: My baxter rotating tray oven is not baking cookies
Inside your oven you have an array of louvers or fins in the back left corner and the front right corner. Sometimes a tray will jam and knock one of the louvers out of adjustment. You may need to call a local authorized service provider to come and reset your louvers to the factory settings. In the meantime you can attempt to make small adjustments to see if you can rectify the issue.
Do not ever adjust the louvers in the back left corner of the oven.
For the trays in question, to direct more air towards the center of the cookie sheet slightly bend the louvers in the front right backwards towards the rear of the oven. ONLY MAKE SLIGHT ADJUSTMENTS!! If you bend the louvers too far you will end up burning the center of the cookie sheet and under cooking the edges.
Posted on Dec 30, 2011
Oven doesn't give steam but it does reach the temp.how can i fix that?
First locate the water solenoid valve. Disconnect the water line to the inlet side of the valve to make sure water is getting to the valve. Once that's verified, disconnect the outlet side of the valve. Activate the steam and verify that the valve opens and there's a good amount of water coming out of the valve. If no water comes out. Verify that the coil is getting energized with the correct voltage. If the correct voltage is present and you have no water coming out. Replace the solenoid. If everything is working then remove the left panel inside the oven to check for blockage in the steam manifold. The manifold consists of a pipe with several spray nozzles that spray water on rebar. Remove all the nozzles and activate the steam. Do this several times to purge any rust or debri. Clean the nozzles and replace them. You should be good to go.
Aug 25, 2015 | Baxter OV310G Mini Rotating Rack Gas Oven
BXA2G oven is not heating properly and also air-flow on display board is not stablising and also both set temperature and oven temperature is flashing.so can you email me aa manual please
Your temperatures will begin flashing after the oven attempted to heat for 10 minutes without successfully increasing in temperature. Sound like you are having burner issues and should call a licensed burner technician to have it serviced.
Aug 05, 2011 | Baxter BXA2G Stainless Steel Gas Single...
The top bar on the inside that holds the racks has stopped spinning during bake.
The top bar, referred to as the "carrier" will only rotate when you start your bake cycle. If there is an issue with the rotation you should hear a steady buzzer about once every second. If you are hearing the buzzer that means the rack alignment switch isn't closing momentarily during rotation like it should be. This could be a result of a number of things, such as a bad rack switch, mis-adjusted rack switch, burned or broken wire on rack switch, bad rotation motor, rotation motor chain or sprockets fell off or are loose, or the shaft switch bar is loose (unlikely).
If you are NOT hearing the beeping then the carrier inside the oven itself could have some loose set screws and the shaft could be spinning freely inside the carrier.
Look on top of the oven and you will see a rectangular shield covering the lift and rotation assembly, remove these covers and verify if the shaft is spinning and hitting the little switch mounted near the top of the shaft.
Mar 01, 2011 | Baxter BXA2G Stainless Steel Gas Single...
Hotpoint ew81n cooker. Non working oven thermostat has been replaced. The cooker temperature is hotter than the dial reading. What can I adjust to make them the same?
Hi.
Unfortunately, the oven thermostat is non adjustable.
However, it is normal for oven temperatures to vary by + or - 10% of the setting.
This is acceptable, so to compensate, set the temp 10% less of the required temp setting.
Make sure you have the sensor fitted correctly inside the oven compartment
Make sure that the thermometer is accurate if you are checking the temperature with one.
Feb 23, 2011 | Hotpoint Ovens
Wich is the power supply 120v, 208 1 phasse or 208v 3 phase.
Most Baxter BXA ovens have separate power supplies, usually 120v for the controls and lights, a 120v output on a circuit breaker for the roof fan, and a 208VAC 3 phase supply for your convection motor. Older Baxter ovens may have a 3 phase service disconnect inside the electrical/burner compartment, if I recall correctly the BXA models do not and the only way to shut it off is via the 3 pole breaker at the service panel.
Feb 04, 2011 | Baxter BXA2G Stainless Steel Gas Single...
I have a Baxter oven OV210G, When the door is open the rack will not stop or lower. The micro switches all work and relays seem to work but I can't find the MR3 cantactor and don't if that is the problem...
When you open the door check to see if your burner and circulation fan remain on, if they do you have an issue with your door switch.
Also if your rotation micro-switch was bad you would get a buzzer every 1 second because the oven would think the carrier isn't rotating.
It's hard to troubleshoot beyond that without seeing the oven, its possible you could have a bad relay on your control board. In this case I would call an authorized service provider to have to check the oven out.
Dec 07, 2010 | Baxter BXA2G Stainless Steel Gas Single...
The rack inside has stopped rotating
On top of the oven is a cover with 6 screws in it, loosen the screws and remove the cover. You will see two pulleys, most likely one of the pulleys are loose, try tightening the set screws, the one on the right can be tricky because the set screw is under the pulley. Good luck!
Dec 04, 2010 | Baxter OV300E Stainless Steel Electric...
My baxter rotating tray oven is not baking cookies evenly. The cookies on the outside of the cookie sheet are over-done and the cookies in the middle of the cookie sheet are not done ??
Jun 14, 2010 | Baxter OV300E Stainless Steel Electric...
Ovens Logo
57 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
joneable
Level 1 Expert
Jerry Kramer
Jerry Kramer
Are you a Baxter Oven Expert? Answer questions, earn points and help others
