Question about In Microwave Ovens
WHEN I TURN ON MICROWAVE OVEN LIGHT COMES ON POWER TO TURNTABLE B UT NO HEAT IN OVEN?
  • 3 Answers
Most likely either the magnetron is bad or a bad diode. Does the unit sound louder than normal? Buzzing?
Posted on Dec 06, 2014
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave turns on, but no heat or turntable movement
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure, but it may also be a broken switch mount. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. It is at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 or at http://www3.sears.com
Posted on Mar 20, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: the microwave does not heat
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
For Kenmore models, you can usually find an exploded view by entering your model number here: http://www3.sears.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
SOURCE: Microwave oven does not heat anything
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Posted on Aug 14, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave won't heat, and turntable doesn't turn
All the parts you mention are very inexpensive, but yours does not have a triac.
It could be the cook relay, but it's more likely to be a switch.
Looking at the schematic, it's probably a bad primary interlock (upper door switch) or maybe its mount is bad.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you have a broken mount, it's usually more economical and safer to just add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
Here are some helpful links:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or elsewhere, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 23, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Ewave OTR Microwave Oven, Model KOT-153UW. Light
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jul 13, 2009
Does not heat - light inside comes on and turntable turns.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 22, 2010 | Maytag MMV5207A Microwave Oven
Microwave will not heat. The light comes on the turntable turns
Basic Microwave Oven TroubleshootingTips
heatman101/./,/,
May 16, 2010 | Maytag MMV4205 Microwave Oven
Not heating
If the oven is doing everything else properly (light comes on, fan runs, turntable goes around) but there's no heat, you may have a failed magnetron tube (the microwave source). There's also a relay that controls power to the tube that may not be working correctly, or the control circuit board is bad. It's also possible one of the door switches is not working (so the oven thinks the door isn't closed), although this usually keeps the turntable and fan from running.
Microwave oven service is not for do-it-yourselfers. There are potentially deadly voltages present even with power off, and a chance of microwave leakage if repairs aren't done properly. Let a professional give an estimate to repair it, or just replace it if it's under $100. (When I was servicing these things it wasn't unusual for a repair to cost over half the price of a new one. That's one of the reasons so few shops still work on small appliances.)
Jan 31, 2010 | LG MV-1444Y Microwave Oven
Microwave has power and runs but will not heat light is on, turntable turns, and blower works. oven does not heat the food inside.
heatman101
klp
Dec 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Jenn Air Microwave M169W will run but not heat
heatman101
zcvzcv
Jan 28, 2009 | Jenn-Air JMC7000 Microwave Oven
MICROWAVE RUNNING. DON'T HEAT & TURNTABLE WON'T TURN
your magnatron needs replaced! (It may cost less for a new one then to fix this one!)
Dec 09, 2008 | Sharp R-930AK Convection/Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Does not "heat" food.
The Microwave Magnetron or power circuit break down . You need to replacement the parts .
Good luck
Sep 30, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
Top In Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
Ron Dufek
Ron Dufek
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
