Question about Garden
Motor starts and run till I let go of key then shuts down
  • Garden Master
  • 2,478 Answers
The switch is or getting bad
Posted on Dec 06, 2014
My Kawasaki twin engine model FD 590 on my lawn tractor sputters, looses power and shuts down after about 15 min of running. Will star after it cool down. Cause please??
Immediately check for spark after it dies. A failing ignition module will quit after it gets hot (about 10 minutes) then work again after it cools. Other causes could be a blocked tank vent; try to run till it starts to act up and loosen the fuel cap. See if it starts to run right again or if it does die it starts right back up. A sticking shut-off solenoid, sticking float needle or partially clogged fuel filter can also cause these symptoms. They let some fuel in but not enough and eventually the motor starves for fuel. then slowly the fuel fills back into the bowl and it will run again for awhile till it runs out of gas again.
Sep 01, 2014 | Garden
Yamaha V Star 1300 starts but immediately shuts down went put into gear with clutch in
clutch plates stuck keep motor off put in high gear like 4th and push back and forth till plates unstick make sure kick stand is up
Jul 19, 2014 | 2007 Yamaha V Star 1300
Runs great till you shut it off
Does it turn over very slowly, if so it would be your starter motor, have that checked first
Jan 04, 2014 | Chrysler LHS Cars & Trucks
Radiator fan runs after ignition is off and key is removed
Does the fan motor shut off after a time or does it run your battery down?
If it runs for a time and shuts off, this is normal with a lot of cars today. It is a second stage cooling system that keeps cooling even after the motor is turned off. They all have either a temperature control or timer switch that turn them off.
If the motor runs till your battery is discharged then the temperature or timer control switch has gone bad and needs to be replaced.
Should you find that your car is overheating while in town, then the fan motor or sensor switch are usually what is at fault and will need to be evaluated and replaced accordingly.
Dec 27, 2013 | 2007 Jaguar X-Type 3.0 Sedan
Blower start up problem
The motor is bad. It is overheating and shutting down on thermal overload. You need a new motor
Jun 24, 2017 | LG LWHD1200FR Wall/Window Air Conditioner
Polaris 700
This sounds like the thermal sensor on the head/block is faulty or in some cases the wires have shorted to the chassis somewhere causing the fan relay to stay on, clould be a faulty relay also.
Nov 25, 2011 | Polaris ATV
1999 gti runs till it comes to temputer then shuts down ,will turn over ,but won't start ,let set for awhile will start right up?
Thray to repair starter motor because when car is hot computer gives engine litle fuel ant if starter motor doesnt work fast enough it cant start because of low fuel on low turning engine speed. When the themperature lowers down engine gets more fuel and it starts up...
Jul 24, 2010 | 1999 Volkswagen GTI
Hobart M-802 mixer
Your overloading the mixer with too much product or not enough water,cut the batch down,the motor protection board is doing its job by shutting off.
Aug 06, 2008 | Hobart Food Mixers
Htr shuts off after awhile and won't come back on till it's cooled down
I believe your heater has a solid state relay to start the motor when the motor gets to speed it is supposed to shut off. It may be stuck in the on position.
Jan 20, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
