Question about Juki Sewing Machines
My juki machine computer is not working
My sewing machine juki industrial the computer is not working
  • Juki Master
  • 1,860 Answers
The computer may need to be checked to see if there is something wrong with the motherboard
Posted on Dec 19, 2014
  • 13 Answers
SOURCE: juki ddl-227 industrial machine
Before all else. Turn off machine!
(1) break screws on the hook loose.
(2) tighten one back up very skightly, one you can reach when the needle bar is at its lowest position.
(3) lower needle bar to its lowest position.
(4) loosen the screw just tightened.
(5) position the tip of the hook behind the needle hole. the tip should be as close to the needle hole as possible without actually touching the needle
(6) tighten screws
(7) slowly hand turn the machine (depress the foot pedal to disengage clutch brake on motor) several revolutions to make sure the needle doesn't hit anything on the hook.
(8) if it passes this test, try on a scrap of fabric
Posted on Dec 15, 2008
  • 5 Answers
SOURCE: Brother DB2-B755-3 industrial sewing machine
I have the manual in pdf form here
http://myweb.tiscali.co.uk/stitches/BROTHER-DB2-B755-MKIII-MANUAL.pdf
Posted on May 12, 2009
SOURCE: Juki DDL-5530 Sewing Machine Manual
go to www.juki.com.jp login industrial sewing machine and you can doenload manual for juki machine
Posted on Aug 20, 2009
  • 48 Answers
SOURCE: there is a wrong way and right way to insert a new
-If your bobbin case is inserted from the left side of the machine, then the scarff( indentation on the back side of the needle ) should be on the right side as you insert the needle.
drtension
Posted on May 02, 2010
SOURCE: how do you adjust timing on pfaff 138 sewing machine
Take the foot off the machine
Remove the needle plate
Remove the feed dogs
rotate by hand until the needle is at the lowest position
continue rotating until the needle rises 2 mm
the hook assembly should be passing exactly by the scarf of the needle
if not loosen the two screws that secure the the hook assembly and rotate the hook assembly by hand until it is exactly at the scarf of the needle and the distance between the hook and the scarf is .1 mm (almost touching the needle)
tightened the two screws, replace the feed dogs and foot and it should sew perfectly
Posted on Sep 22, 2012
I am a swimwear designer and just got a juki ddl 8300n did I pick a good machine? How can I adjust the machine for a more stretchy stitch?! What number should my stitch dial be on to get a stretch?
Perhaps a manual would be helpful:
File JUKI DDL 8300N Instruction Manual pdf
You should probably contact the manufacturer with questions. Hopefully, you did some thorough research before purchasing this machine. From the info I found, it appears to be a straight stitch only machine. I don't know anything about this machine, but I would be hesitant to purchase a straight stitch machine for sewing swimwear. Usually, swimwear needs a stretch stitch or zig-zag capability. Just my thoughts...
Amazon com Juki DDL 8700 Industrial Straight Stitch Sewing Machine Arts...
Juki DDL 8300N Industrial Single Needle Lockstitch Sewing Machine with...
JUKI DDL 8300N Straight Stitch Industrial Sewing Machine With Table Lamp...
Nov 21, 2016 | Juki Sewing Machines
How i use juki rotalix hw622 and which number of needle we need to sew properly in home
Depends on what you're sewing. A good 14/90 universal needle should work for most material though.
Aug 31, 2016 | Juki Sewing Machines
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
Oct 08, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Need beginners manuel for 1541-s Industrial Sewing Machine
Contact your seller or Juki and ask for a threading diagram.
Sep 01, 2012 | Juki Sewing Machines
My yuki serger run too slowly.i want to set up it speed faster because i am a worker in a sewing shop
Domestic sergers usually sew 1500 stitches per minute, you can't increase this. You can make the stitch longer which will move a bit more fabric through with each stitch but obviously you need the stitch to hold the fabric too.
If you find this is not fast enough for the volume of work you need to do, then shop around for an industrial machine. Usually built into a table, and designed to feed very fast. Try the Juki website, they do a big range of industrial machines such as these http://www.juki.co.jp/industrial_e/products_e/apparel_e/cat6/
Jun 13, 2011 | Juki MO-735 Mechanical Sewing Machine
Promblem with an industrial overlocker. need information
DC x 1 should be your needle type.
Try this company for your manual:
Juki MO-2500 Parts - MO-2500: Sewing Parts Online www.sewingpartsonline.com/...ewing-machine-parts.aspx
An Online Juki Parts Superstore, We also supply MO-2500 manuals, presser feet and accessories. Fast, free shipping over $75.
Jul 02, 2017 | Juki MO-623 Mechanical Sewing Machine
Aug 07, 2009 | Juki DNU-1541 Mechanical Sewing Machine
Sewing Machines Logo
62 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
