Question about Cell Phones
For got screen lock for my LG-E435k need free codes n full hard reboot settings
How unlock my phone
Hi if you've locked your phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
If you lock your phone again some time in the future and you're still with the same service provider you can use that same Puk code.. CHEERS..
Mar 11, 2016 | LG Cell Phones
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Screen locked and unable to unlock
Turn off . Press and hold POWER + ENTER button for reset menu.
Select
Factory reset with Volume Down button and press Power to reset. All data will be lost! there is an alternate method too friend
Use this method to hard reset your Samsung GT-S Galaxy mini phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Samsung GT-S5570 Galaxy mini download mode if you want to install eg. Gingerbread
Press and hold Volume DOWN + HOME + POWER ON S5570
Restart your device to clear any temporary software bugs
If you know the hard reset with buttons / keys, pls leave a comment. All comments are welcome!
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings :Privacy
:Factory data reset :Reset phone : Erase everything.
Clear storageā€¢ : Erase the credential contents from the device and reset the password
Set an unlock pattern
Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen
Settings Location and security Set screen lock : Pattern
If you forget your PIN or password, bring your device to a Samsung Service Centre to reset it.
Set an unlock PIN code
Settings Location and security :: Set screen lock : PIN
Set an unlock password
Settings Location and security :Set screen lock : Password.
You can hard reset software firmware update your Samsung GT-s Galaxy mini phone
Hope it helps u
Dec 08, 2013 | Samsung Cell Phones
Unlock code for lg ks360 free
This LG is PDA phone,so you cannot Unlock it as free of cost,You can get the paid Unlock code at here Simpleunlocking.com and follow the instructions below and Unlock it step by step,then You can use any GSM network,Specify the Network,country it locked and get the code...
LG KS360 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your LG KS360 mobile phones. If you enter over a certain amount of wrong unlock codes on your LG KS360 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your LG KS360 with its ORIGINAL SIM Card,
2 - Enter 2945#*71001#,
3 - Sim unlock mode pop up,
4 - Enter the unlock code and press ok,
5 - The LG KS360 will then reboot and the unlock is complete.
ORIGINAL : We mean, to use the sim card that was originally given to you by your network/service provider along with the LG KS360.
Aug 10, 2011 | Computers & Internet
Unlock my lg u990
You can Unlock it simple by using the Unlock Code ,you can get the Unlock code at low cost from here
Superunlockcodes and follow the instructions below and UNLOCK IT.
LG U990 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your LG U990 mobile phones. If you enter over a certain amount of wrong unlock codes on your LG U990 mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your LG U990 with its ORIGINAL SIM Card.
2. Press the telephone icon at bottom of screen to bring up the LG U990 keypad.
3. Enter 2945#*990#.
4. A menu will pop up, select sim unlock.
5. Enter your Unlock Code and press ok.
6. The LG U990 will then reboot and the unlock is complete.
ORIGINAL : We mean, to use the sim card that was originally given to you by your network/service provider along with the LG U990.
(or)
1. Switch ON your LG U990 Without any SIM card.
2. Hold "camera" + "lock" button.
4. Enter your Unlock Code.
5. The LG U990 will then reboot and the unlock is complete.
Each LG U990 mobile phone has an unique unlock code. You can buy the unique unlock code for your LG U990 mobile phone using the form above.
Jul 13, 2011 | LG Cell Phones
Need a free unlock code for my lgu8360 mobile prepaid 3 phone
Hello, no one will give you free LG U8360 unlock code even your network provider. The only way that you can do is find more cheaper lg unlock code rather than asking for free code, trust me even you get a free code it will not exactly the correct code and it can worst your phones and become hard locked.
Jun 09, 2011 | LG U8360 Cell Phone
Need unlock code for Lg Ku990 Viewty phone
I understand that you need an unlock code for your LG KU990 Viewty Phone.
1. insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*990# 4. A menu will pop up, select sim unlock 5. Enter your unlock code and press ok6. The phone will then reboot and the unlock is complete.
Dec 22, 2009 | LG KU990 Viewty
I have an lg prada ke850 touch screen phone and I was trying to set in a security code but instead I just locked my phone. Can you please help? I don't know how to unlock it!!!!!
This is a small tutorial on how to hard reset the lg prada on request for forgotten security code. Turn the prada on without a simcard and wait for the insert sim screen. On the touch screen hit call, after enter this code 2945#*#. and you will see a menu pop up headed "Engineering menu". scroll down to factory reset hit that and wait for it to reboot.
Best Regards
May 14, 2009 | LG Prada KE850
Security
If it is configured to lock the screen it can yes if you don't know the code try 0000 if that doesn't work reboot phone and before the screen locks type 277634#*# it will open a hidden engineer's menu and you can choose master rest phone and it will set all settings and codes to default and turn the screen lock off for you.
Jan 08, 2009 | LG Vu CU920 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
