Question about Cell Phones
I need to no how to unlock screen lock on my lg e435k n to hard reboot lg e 435k
How to unlock home screen on lg android
Unlock home screen
Kelli, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to turn off the screen lock on my LG G2
How to bypass Android lock screen pattern PIN or password
Solved Forgotten the Password of the Lock Screen
Hard reset your Android phone or tablet when you forget the passcode or...
Jun 07, 2016 | LG Cell Phones
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Unlock code for lg ks360 free
This LG is PDA phone,so you cannot Unlock it as free of cost,You can get the paid Unlock code at here Simpleunlocking.com and follow the instructions below and Unlock it step by step,then You can use any GSM network,Specify the Network,country it locked and get the code...
LG KS360 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your LG KS360 mobile phones. If you enter over a certain amount of wrong unlock codes on your LG KS360 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your LG KS360 with its ORIGINAL SIM Card,
2 - Enter 2945#*71001#,
3 - Sim unlock mode pop up,
4 - Enter the unlock code and press ok,
5 - The LG KS360 will then reboot and the unlock is complete.
ORIGINAL : We mean, to use the sim card that was originally given to you by your network/service provider along with the LG KS360.
Aug 10, 2011 | Computers & Internet
How to unlock the lg xemon (instructions)?
You can Unlock the LG XENON GR500 model Phone using the Unlock code,You can get the Unlock code and instructions from here
Classicunlocking.com and Unlock it from Network Lock....
LG GR500 Xenon Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your LG GR500 Xenon mobile phones. If you enter over a certain amount of wrong unlock codes on your LG GR500 Xenon mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your LG GR500 Xenon with a NOT ACCEPTED* SIM Card.
2 - LG GR500 Xenon will display "phone restricted" Select "Cancel".
3 - LG GR500 Xenon will display "phone restriction code" Enter the Unlock code. Select "OK".
4 - The handset is now successfully unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your LG GR500 Xenon is locked to.
(OR)
1 - Switch ON your LG GR500 Xenon with its ORIGINAL SIM Card.
2 - Enter2945#*9701#.
3 - A menu will pop up, Select Sim Unlock.
4 - Enter your Unlock Code and press OK.
5 - The LG GR500 Xenon will then reboot and the unlock is complete.
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG GR500 Xenon.
(OR)
2 - Type *#865625#.
3 - Enter the unlock code twice.
4 - LG GR500 Xenon should say: Network Lock Deactivated.
5 - LG GR500 Xenon may automatically reboot and is now unlocked!
Aug 03, 2011 | LG Xenon GR500 Cell Phone
Unlock my lg u990
You can Unlock it simple by using the Unlock Code ,you can get the Unlock code at low cost from here
Superunlockcodes and follow the instructions below and UNLOCK IT.
LG U990 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your LG U990 mobile phones. If you enter over a certain amount of wrong unlock codes on your LG U990 mobile phone, your phone may get hard locked and sometimes become unusable.
1. Switch ON your LG U990 with its ORIGINAL SIM Card.
2. Press the telephone icon at bottom of screen to bring up the LG U990 keypad.
3. Enter 2945#*990#.
4. A menu will pop up, select sim unlock.
5. Enter your Unlock Code and press ok.
6. The LG U990 will then reboot and the unlock is complete.
ORIGINAL : We mean, to use the sim card that was originally given to you by your network/service provider along with the LG U990.
(or)
1. Switch ON your LG U990 Without any SIM card.
2. Hold "camera" + "lock" button.
4. Enter your Unlock Code.
5. The LG U990 will then reboot and the unlock is complete.
Each LG U990 mobile phone has an unique unlock code. You can buy the unique unlock code for your LG U990 mobile phone using the form above.
Jul 13, 2011 | LG Cell Phones
Code for unlock cell phone lg cu920
hello ma'am, in order to unlock your phone try following these steps..
Warning: Do not enter any wrong unlock unlock codes on your LG CU920 mobile phones. If you enter over a certain amount of wrong unlock codes on your mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your LG CU920 with an ACCEPTED SIM Card.
2 - Compose : *#865625#.
3 - Enter Unlock code.
4 - LG CU920 should say: Network Lock Deactivated.
5 - LG CU920 may automatically reboot and is now unlocked!
ACCEPTED : We mean, to use a sim card from the network your LG CU920 is locked to.
Each LG CU920 mobile phone has an unique unlock code. You can buy the unique unlock code for your LG CU920 mobile phone at www.mobileunlocksolutions.com.
thank you very ma'am.. i hope this'll help..
May 28, 2011 | Cell Phones
Need unlock code for Lg Ku990 Viewty phone
I understand that you need an unlock code for your LG KU990 Viewty Phone.
1. insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*990# 4. A menu will pop up, select sim unlock 5. Enter your unlock code and press ok6. The phone will then reboot and the unlock is complete.
Dec 22, 2009 | LG KU990 Viewty
Locked LG Incite phone with nonresponsive touchscreen
You have to reinstall the rom
http://www.wireless.att.com/answer-center/main.jsp?t=solutionTab&solutionId=KB102425
May 27, 2009 | LG Incite Cell Phone
I have an lg prada ke850 touch screen phone and I was trying to set in a security code but instead I just locked my phone. Can you please help? I don't know how to unlock it!!!!!
This is a small tutorial on how to hard reset the lg prada on request for forgotten security code. Turn the prada on without a simcard and wait for the insert sim screen. On the touch screen hit call, after enter this code 2945#*#. and you will see a menu pop up headed "Engineering menu". scroll down to factory reset hit that and wait for it to reboot.
Best Regards
May 14, 2009 | LG Prada KE850
Cell Phones Logo
65 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
