Question about Konica Minolta bizhub Office Equipment & Supplies
HOW TO PUT DUPLEX UNIT ON KONICA MINOLTA BIZHUB 215
    Habit-Forming:
    New Friend:
  • 178 Answers
Look 1st inside the box Duplex unit comes w/ Installation manual.
Posted on Dec 12, 2014
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
SOURCE: Cannot print in duplex
Go to Option, in driver and be sure that the Duplex Option is installed.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
djklermund
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
Konica minolta bizhub 215 giving error c2558
C2558
Abnormally high toner density detected TCR sensor board
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between MFPB to TCRSB is disconnected.
Error Codes Konica Minolta bizhub 215
Mar 07, 2015 | Konica Minolta Office Equipment & Supplies
Can i see konica minolta bizhub 211 drum picture please
OPC Drum for Konica Minolta bizhub 210/162/211/163/182/215/164/
Feb 05, 2015 | Konica Minolta bizhub Office Equipment &...
How to install duplex on konica minolta 215
Right click the printer and choose properties, after that there should be a button called preferences. Press that, and in there you should find Duplex/Or print on both sides.
Dec 05, 2014 | Konica Minolta bizhub Office Equipment &...
My konica minolta has a false misfeed showing at fuser area
Check all the sensors, the sensor in the fuser unit might be broken, common thing
Sep 06, 2014 | Konica Minolta Bizhub C550
What would be the genuine problem when konica minolta bizhub 215 shows maintainence call(m2)
Procedure
1. Press the COUNTER.
2. Press the following keys in this order:
STOP 0 0 STOP 0 1
3. Enter the code number corresponding to the function to be used from the KEYPAD.
4. Press the START.
<Exiting the Mode>
• Press the AUTO RESET until the initial screen reappears.
Apr 03, 2014 | Minolta bizhub 180 Black and White Copier
C-d403
Incorrect code for Konica Minolta digital copier.If you have an analog copier the Codxx code refer to duplex unit.Verify the duplex tray drive mechanism and the gears.
Feb 20, 2013 | Konica Minolta bizhub C250 All-In-One...
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Jun 01, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
