How do i replace the turntable belt on MTGA05
I have not tried anything. Will have to have my son do the fixing.
  • Lessie Fowler
    Lessie Fowler Dec 08, 2014
    This is an Anders Nicholson turntable, CD, cassette player, radio combination. Model MTGA05. Given to me still in the original packing, although several years old. Everything works except the turntable. The speeds are too slow leading me to believe the belt needs to be replaced. I'm guessing that it is belt operated.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
I'm sorry, but I don't know what a MTGA05 is. If it has a removable platter(by hand, lift off) you will have access to the belt. All depending on how stretched the original belt is, you may be able use the overall length of the old belt to approximate the correct length new belt. Be careful in your measurements. Too tight, or too loose a belt, can make your issue worse or better, depending on your choice.
Posted on Dec 11, 2014
2 Suggested Answers
SOURCE: help need to replace beltplease help turntable
FAIRLY SIMPLE...
1) REMOVE THE PLATTER
2) WRAP THE BELT AROUND THE INNER CIRCLE FOUND ON THE BOTTOM SIDE OF THE PLATTER, THE BELT SHOULD FIT PERFECTLY....
3) PLACE THE PLATTER BACK INTO PLACE...
4) THROUGH ONE OF THE SPACES ON THE PLATTER, TAKE THE BELT AND PLACE IT OVER THE MOTOR WHEEL...THAT SHOULD DO IT.
Posted on Aug 19, 2008
BOSE 360 turntable manual
go google and type in --bose turntable spares --- and get a site that says spares like bose .com.au>en_au>support
or sansui-parts-shop.com
call on the phone or e-mail on the contact address
Jul 03, 2016 | Audio Players & Recorders
The turntable was a gift for my son and it worked once. Now, it isn't responding to anything. We've checked the belt and it seems to be installed correctly. What now?
hi,
there are not much electronic circuit for controlling the mechanism. all mecanical movements. there are only switches to sense staring and ending. remove the power and do the following
while holding the tone arm in its rest position, slowly turn the platter by hand clock wise at least 10 rotation to clear the machanism's automatic cycle.
the connect the power and press start.
ok
Jan 05, 2011 | Audio Technica AT-PL50 Turntable
My sony pslx250h turnable belt was ordered and i can't find the repair book to repair it.
Pretty simple fix. Remove the mat, remove the turntable, install new belt on bottom of turntable hub. Place turntable back onto spindle. rotate turntable so you can see motor pulley. Stretch the belt from turntable hub over motor pulley, replace mat, enjoy.
Nov 08, 2010 | Sony PS-LX250H Turntable
Model PS-LX300USB Turntable Drive Belt
Hi Norman
Normally the belt does not go through any special tensioners or anything of that nature,The belt should go directly from the spindle motor onto the inside of the platter. Hook the belt on the motor section and lay the belt open wide inside the turntable. Next, replace the platter and manouvre the belt onto the platterinside through the two large holes
Mar 11, 2010 | Sony PS-LX300USB Turntable
The belt came off
Normally the belt does not go thoough any special tensioners or anything of that nature,The belt should go directly from the spindle motor onto the inside of the platter. Hook the belt on the motor section and lay the belt open wide inside the turntable. Next, replace the platter and manouvre the belt onto the platter inside, through the two large holes
Jan 28, 2010 | Sony PS-LX300USB Turntable
Belt came off
Dec 28, 2009 | Sony PS-LX250H Turntable
THE BELT ON MY TURNTABLE SLIPPED OFF AND NOW I AM HAVING PROBLEMS OF GETTING IT BACK ON. THE BELT IS NOT CATCHING THE PULLY THAT IT IS SUPPOSE TO CATCH ON TO.
Normally the belt does not go thoough any special tensioners or anything of that nature,The belt should go directly from the spindle motor onto the inside of the platter. Hook the belt on the motor section and lay the belt open wide inside the turntable. Next, replace the platter and manouvre the belt onto the platter inside, through the two large holes. Move by hand slowly to see waht happens. If the belt slips off again, it may be streched and needs to be replaced
Nov 18, 2009 | Panasonic Technics SL-BD22D Turntable
Help need to replace beltplease help turntable
FAIRLY SIMPLE...
Aug 18, 2008 | Pioneer PL-990 Turntable
Turntable rotating slowly or not at all
First and foremost, are you sure you installed the correct replacement belt, and installed it correctly? Just ruling out the obvious. Now, if you installed the belt correctly, then the only other thing that could cause this is a bad motor. Not an expensive part, but with labor, it might be cheaper to just buy a new one. Figure the part itself is about You will more than likely be able to remove the cartridge/stylus and use it on your new turntable, just make sure the tonearm is the same style as your existing turntable - P-MOUNT Tonearm. If you buy another belt drive, you might even be able to keep the belt you purchased as a back up - might fit! Here is some part info on your turntable: - Belt - Part #SJY90080-3 - $5.99 - Motor - MOTOR, 4 VDC, .2 WATTS - Part #SDMB5E - $19.99 Labor - 30min This is just to give you an idea of what it would cost to replace the motor. I put the belt part # on there, just so you could verify that you bought the correct part. Hope this helps some. - Justin
Aug 02, 2007 | Technics SL-BD22 Turntable
Technics problems
There is no drive belt on this unit. This is a direct drive turntable. Your pitch control might be on it's way out. Are you getting any sort of unusual speed issues? Or is it just sort of running slower than usual? There is a pot you can adjust under the turntable platter to speed it up a bit, however, this is only a temporary fix. It is listed as VR301 - and is on the main board under the turntable platter - it says PITCH on it. Try adjusting that pot, to see if it does anything. WORD OF CAUTION: Make sure your turntable platter is ALWAYS on whenever you power up your turntable, and if you do any electrical modifications, make sure you always disconnect your turntable from it's power source to be on the safe side. If this does not work, then either your pitch control (which is a variable resistor) will need to be replaced. The problem could also be one of the drive components on the main board, however, this will need to be worked on by a service tech. Hope this helps. - Justin
Jun 11, 2007 | Technics SL-1200MK2 Turntable
73 people viewed this question
 Grubhead
Grubhead
