Question about Onkyo Televison & Video
Onkyo RC-738M remote control mute does not work and volume control is intermittent. How to fix?
Mute button is none responsive while volume control sometimes works if one holds down button and waits
    Top Expert:
  • Onkyo Master
  • 74,136 Answers
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
If the remote control is found OK; check it with set it up to an other set-up code said for your TV. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Dec 06, 2014
How do I program an AT&T u-verse remote to an ONKYO RC-866M remote
The RC-866M is the remote. What you need to do is add the codes for your Onkyo receiver into the ATT remote. There are 4 or 5 different Uverse remotes, but most can be reprogrammed by pressing the 'Menu' and 'OK' button together. First add your Onkyo codes to the ATT remote as an 'aux' device. After that is working, you can control the power and volume by adding the 'aux' device (Onkyo) to the power and volume buttons on the uverse remote.
These are all the different Onkyo Receiver codes:
Onkyo: 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140
This is how to reprogram the S10 style of Uverse remote:
http://www.att.com/support_media/images/pdf/uverse/standard_black_remote_control_uverse.pdf
Dec 22, 2014 | Onkyo Audio Players & Recorders
NR626 - no sound
If none of your speakers gives any sound, perhaps you pressed the mute button on the remote control?
Make sure you have a source selected, that will give sound. Choose a low volume, before switching anything. You can destroy your speakers, when switching on with full volume.
If some speakers work, and only the surround does not work. check if you have surround sound as input. If you only feed 2 channels you can't expect to hear more than 2 channels.
Jul 01, 2014 | Onkyo TX-NR626
Hi, My Denon RC-1154 stereo has suddenly stopped working, it gets stuck on the initializing part - it gets to 2/4 connecting.... on the internet radio and freezes and so you can do anything with it? How...
follow this test and fix it. God bless you
The speakers are not connected properly. Check the speaker connections. The Mute function is activated. Turn off the Mute function. The volume is turned all the way down. Turn up the volume. Neither set of speakers is selected (if unit has A/B buttons to select sets of speakers). Press either A or B to select a set of speakers. Both sets of speakers are selected, but only one set is connected (if unit has A/B buttons to select sets of speakers). Press the appropriate button to deselect the speaker outputs which are not connected. The receiver is set to TAPE MONITOR (if applicable). Turn off TAPE MONITOR mode. Headphones are plugged into the main unit. Unplug the headphones. The source selector is set to the wrong source. Select the proper source. The impedance of the speakers is less than the rating for the system. Use speakers with the correct impedance rating.
Oct 24, 2013 | Denon RC-1154 Remote Control 307010080001D
Closed captioning on ONkyo remote control
If you are sure this feature is included in the TV, usually turning off the speaker or pressing a MUTE button on the remote will start the CC process. There may be a slight delay before it starts.
Sep 04, 2012 | Onkyo Remote Control RC-742M p/n:24140742
All remotes controlling my Onkyo TX-SR304 stopped working
try putting the remote an inch away from the IR receiver on the unit and see if it works then, if so then you definitely know its broken. This can and does happen. From what you have posted it sounds like no remote is working on the receiver, the ir receiver can break. If you need further assistance let me know.
Thank you,
Lee
May 28, 2009 | Onkyo TX-SR875 Receiver
TX SR705 Receiver not respomding to Remote
for your mute button:
check your setup:
*press setup
*go to Miscellaneous
*go to volume setup
*go to muting level
*make sure that the muting level is on minimum (press the left arrow or the left preset button)
*if it shows a negative infinite sign (its measured in decibels) its ok.
you can now mute it without the loud noise.
Abaout Remote:
Please make sure that the remote ID is set to 1. this would be on the setup menu of the receiver. The remote ID on the receiver should be the same as your remote. Please refer to page 94 and 98 of your owners manual. it would give you the exact procedure in how to set it.
Jan 11, 2009 | Onkyo TX-SR705 Receiver
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Nov 10, 2008 | Toshiba Televison & Video
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Televison & Video Logo
439 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
