Question about Cell Phones
My grandson,s phone,cell phone #262-203-4980 is blocked from calling my home#, 262-882-5088. when he calls my phone rings one time and a message pops up on my phone,caller blocked. could this be caused by the national no call service and if so how do I fix it. thank you David Cain. email- dcn383@aol.com.
I need to extend the length of time my phone rings on incoming calls
Hello, Mary -
I checked the user manual for your Alcatel 3003G cell phone:
https://www.manualslib.com/manual/1150047/Alcatel-Tribe-3003g.html?page=1#manual
I did not find any information regarding increasing the length of time of rings of incoming calls in the manual. So, I thought the incoming rings length of time may be dependent upon your cell phone service provider, Vodafone.
I found some information on a Vodafone Support page:
https://support.vodafone.co.uk/
How to increase the time before a call goes to voicemail?
(Quote)
Your Vodafone mobile is set to ring for 15 seconds before going to voicemail. You can change how long it rings for, choosing from 5 to 30 seconds in 5-second intervals.
To choose your desired ringing time:
  • Enter **61*121*11* on your Vodafone mobile
  • Choose the number of seconds you'd like your phone to ring for, followed by #
  • Press Call
  • A confirmation message will pop up on your screen with your new ring time
For example, if you want to set your Vodafone mobile to ring for 25 seconds, you enter **61*121*11*25#, and press Call. When the message pops up, you'll know it's all done.
Watch this simple video to find out how to increase the time before a call goes to voicemail.
https://youtu.be/rGJNpaaD5z8
(End quote)
Best wishes.
Apr 13, 2018 | Lands Phones
How do I block a number?
Call your provider.
If your provider doesn't block numbers, what has worked for me in the past is sending a text message along these lines every time you get a text
Error 23: SMS Not Delivered - Sender blocked by intended recipient
They might not believe it the first few times, but it gets the point across and the texts usually stop. As for calls, just let them ring through and never answer them.
Jun 22, 2015 | Samsung Intensity II SCH-U460 Grey Verizon...
Hi i want to block number to call me ,my phone is nokia 1280
You can not block that number.Your mobile will not support for that.
* You can do one thing.You can add that number to the screened list.
* If you add means your mobile will not ring if that person calls you.
* Their you will see the miss call information.
* If they send you message means it will be stored in the screened message.
* If you want to add that number means you should follow this steps.
* If you have miss call from that number means select that number there you will be having option select that option.
* There scroll over to add to scrn.list select that one.
* Then it will ask do you want to add this number to screened list.
* Select it.
* From now you wont get ring if that person call you.
* Message will be stored in screened message.Select message scroll over to screened message.In that you will find the message.
Thanks for your question.
Jun 27, 2011 | Nokia 1280 Cell Phone
Our phones only ring 4 rings before going to message bank. We have a telstra wall connection, and 3 panasonic KX-TG1840AL
You can change the number of times the phone rings before the unit answers calls.
You can select 2 to 7 rings, or “Auto”.
“Auto”: The unit answers after 2 rings when new messages have been recorded, and
after 5 rings when there are no new messages. If you call your phone from
outside to listen to new messages, you will know that there are no messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
1 Press OK.
Select Answer System, then press >(Right navigation button).
2 Select Settings, then press >.
3 Select Number of Rings, then press >.
4 Select the desired setting, then press >.
5 Press End button
725a0bb.jpg Thank you
Aug 10, 2010 | Cell Phones
I need to block an incoming number on my Motorola SLVR L7 cell phone on the ATT network. Can that be done on the phone itself? Will it block incomingtexts from the same number?
This will block the call, I am really not sure about the text messages although my guess is it should
Settings >>> Security >>> Restrict Calls
If that doesn't work, you can always assign a ring tone for the number, and select silent as the ring tone, but that will not block text
Nov 26, 2009 | Motorola Mobility SLVR L7 Cellular Phone
LG Vu calls coming in that are anonymous/restricted numbers
to reject calls you need to go to the main menu then go to your settings and touch call then scroll down and you will see the call reject icon then enter that icon and then go to the call reject list and touch new so that you can block the number
good luck
Mar 22, 2009 | LG Vu CU920 Cellular Phone
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Bellsouth answering machine
TS stands for "Toll Saver"
It will ring 4 times if there are no new messages waiting, it will ring 2 times if there are new messages waiting.
This has two effects:
1) If you are calling home to check your messages, you can wait 2 rings. If there are new messages to check, then it answers immediately. If you make it to 3 rings, you know there are no new messages and you can hang up before you are billed for your call. This was more useful when you would use a pay phone or hotel phone to make a long distance call home. With a pay phone you would get your "quarter" back as long as there were no messages. With cell phones,it isn't as useful.
2) If you not home (which is implied by the fact that there are new messages waiting), it answers faster, so people calling you don't have to wait as long. This could also be viewed as a security risk... it tells your callers whether you are home or not.
- Ben
Mar 13, 2008 | BellSouth Digital Answering System 2006C...
Samsung E900
set all call barring and set call divert you can choose what you want!
Oct 02, 2007 | Samsung SGH-E900 Cellular Phone
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
