Can I use a K8A60DA Transistor in place of a K10A50D?
The K10A50D has a higher Drain current flow rating, it is spec at 10a vs. the K8A60DA rating of 7.5a. The physical layout is indentical, but you run the risk of compnotent fatigue if you install the lower current rated replacement. Other dynamic characterictics of the MOSFETs' are inconsequential in the required performance.
Front view pin layout:
1: Gate
2: Drain
3: Source
Posted on Dec 05, 2014
What is the Radio shack version of the K10A50D Transistor?
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0&_nkw=K10A50D&_sacat=0
a tenner each seems the going rate
its some sort of FET the k is usualy 2SK10A50D
but on ebay its just the short form ?? not sure im right 100%
but in the past this is the case 10 amps 50ma drain at source??
is it a big switching device motor driver perhaps ??
anyway a 10r buys it
take my advice and never go to ' radio shake ' again!!! and dont use or try use some equiv device
always use the exact device the maker put in is the best policy
or your home can burn down etc,, and your insurance will be void in some cases
Dec 05, 2014 | Radio Communications
Blown transistor output
open the amp, you will see the remaining parts of the blown transistor in the pcb mostly the soldered legs will be there. before desolder the legs, findout the right position and direction of the trnsistor insertion to the pcb by comparing the blownout transistor with the legs on the pcb once confirmed the position write down(or draw) in apaper then remove the legs from the pcb and solder a new transistor in the pcb..i hope this will help you to fix your problem thanks.
Aug 31, 2013 | Sony STR-DE595 5-Channel Amplifier
Does anyone know the number of the heat mounted transistor on the power board of philips 40pfl4707 tv
Download the service manual to this set by internet. It will have all details.
Jan 16, 2013 | Philips Televison & Video
Am I testing this horizontal output transistor correctly?
Check the resistance between collector and emitter. It should never be Zero Ohms.
Dec 01, 2012 | Symphonic Televison & Video
I had a akira tv remote but it could not work,,, and then the transistor poart is missing?
hi,
u can use the C945 NPN (emitter,collector, base configuration ) transistor in that place.
ok
Dec 27, 2010 | Akira SV-4201 42 in. Plasma Television
Specification of part place in the heat sink of the acer al1716As lcd monitor power supply pcb,i cnnot recognized burnt already,is that IC or transistor.it has 6 pin
Transistors are with just three pins, so what you are seeing there should be an ic and not a transistor.
It is ics that have numerous pins, transistor have just three legs(pnp) or (npn).
So what you see is an ic.
Take care.
May 04, 2010 | Acer AL1716As 17" LCD Monitor
No picture
I disagree with given info, this tv has no horizontal output transistor because it is dlp tv.
3 red light blink means lamp cover is not placed back properly after lamp replacement/ lamp checking. Make sure lamp cover is fixed back in its place securely and tight.
Jul 16, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Electro Med Services...
