Question about Octane Fitness Q37ci Elliptical Trainer
How do I turn off the digital display when the Q37ci is not in use without unplugging
Stopped working without power. Unplugging/re-plugging did not work. No display, no buttons responding. Is there re-set option?
there is a fuse inside,take it to someone that knows how to repair,if you use the wrong fuse,you could cause a fire or health problems
Mar 14, 2015 | Sharp R-820BK Microwave Convection Oven,...
The dehudifier won't come on in and in the digital display the message CH 01 comes up. Any idea what the problem is?
CH 01 usually indicates that the filter is dirty and needs to be removed and cleaned. Turn the unit OFF and unplug it, before removing the filter. Never operate the unit without the filter in place.
Thanks for choosing FixYa.
Sep 07, 2011 | LG LHD659EBL Dehumidifier
Fault code EF is flashing on my Electrolux fridge FSC23R5DSB6. What does this code mean?
EF on the Electrolux refrigerator digital display means "evaporator fan."
The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Turn the power off on the digital display and carefully unplug the refrigerator from the power source. Leave the refrigerator unplugged for three to five minutes. Plug the refrigerator back in and give the refrigerator a few minutes then turn the power button back on. Press the default button on the display and see if the EF code goes away.
Electrolux recommends that you do not plug the refrigerator into an outlet that has a reset button. If your refrigerator is plugged into one of these outlets, try plugging it into another outlet and see if the refrigerator resets itself.
Hope this helps.
Jul 21, 2011 | Refrigerators
When I power up the unit it only shows Welcome and stuck there, after reset or unplug power it also shows Welcome. It is totally frozen at Welcome.
Hello
Its power board had got damaged. It ony supplies 5VDC to the board, which in turn energises the system control and display. There is 4 more voltages out from it is missing. You have to findi out it, and reason for its failure. Actually the swithcing process in the power supply board is OK. But without the above said missed voltages, there will be no motor voltages and mainboard chroma and decoder voltages. The system is very complicated in circuit nature, so without any previous expeience, never attmpt to reapir it. If you are well aware in digital electronics, you can do this. A high quality digital multimeter and a concept of soldering are also needed. I've given you the fault advice according to your post. Determine what should do. OK.
Mar 23, 2011 | Sony RDR-GX300 DVD Recorder
My camera turns on for a brief second and then immediately turns off. The lense has no problems going in and out it's just the screen that won't stay on.
Check your settings to see if the display is turned off in shooting mode. Does the camera still take pictures without the display on (using the traditional view finder). This is a feature that saves battery life. Can usually be turned off/on in the settings menu.
Jan 03, 2011 | Kodak EasyShare Z710 Digital Camera
VIZIO 52" LCD is on but....no display
If this is indeed an LCD and not a plasma, then you need to replace the LVDS (LCD controller) board.
May 18, 2009 | Vizio GV52LF 52 in. LCD TV
Strange display screen issue
If you have had the camera for less than a year, it may still be under warranty. Call 800 730 6597
Nov 13, 2008 | GE E1030 Digital Camera
Reformat??? Regarding pink scrren issue
May be some of display cables are unplugged. Turn on your ipod and imagine that you ipod without display, can you play music? If yes your display broken in other case download ipod tools to ypur PC and try to repair it click
If you have any question you can ask me.
Sep 07, 2008 | Apple iPod MA446LL/A MP3 Player
HP PSC 2210 won't initialise
Unplug the power cord from the All-In-One and also from the wall outlet,
Leave the cable unplugged for atleast 1Min.
Connect the cable directly to wall outlet without the surg protector and before connecting it to the All-In-One press and hold the # and no 6 Button and plug the cord to the unit without releasing the keys, it should come up with the message as Semifull Reset
If the display goes off or printer turns off then release the keys and turn the power on.
Good Luck.
Aug 29, 2008 | HP PSC 2210 All-In-One InkJet Printer
Octane Fitness Q37ci Elliptical Trainer Logo
Top Octane Fitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Octane Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
