Question about Sewing Machines
Machine shuttle is out how do I replace it?
The shuttle parts are out
    New Friend:
  • 18 Answers
There are differences in the different brands and models, but often there are interlocking parts - so there will be a click when they are engaged in the right way.
It might be in the manual - look online using Google or other search engine if you don't have a hard copy of the instruction book.
Posted on Dec 05, 2014
Bobbin shuttle won't come out of machine # Kenmore convertible 15819800 How to fix?
https://www.searspartsdirect.com/partsdirect/user-manuals/15819800-kenmore-parts-manual
Kenmore 158 instruction manuals
Unable to locate a manual specific to your machine, however, this may be helpful. Look at page 24 of the manual, picture #4 shows the bobbin shuttle. There are two flippers that hold the bobbin shuttle in place.
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/15718.html
May 13, 2018 | Kenmore Sewing Machines
Necchi 3537 manual is useless. How do I put bobbin shuttle hook back into the machine?
HINT: before you install the shuttle, make sure to place a drop of sewing machine oil around the outer edge of the shuttle and lightly spread it around the outer edge (you should do this about every time you change a bobbin). Sorry, you'll probably need to be familiar with removing and installing the shuttle. Have patience! Once you've done it a couple of times, you'll wonder why it was so difficult.
It usually helps if you can tilt the machine back about 45 degrees so it is supported by something (pillow, cushion) so you can get good visibility into the bobbin area.
Raise the needle so that the take-up bar is at its highest point.
Make sure the outer hinged door on the shuttle area is open. Inside that open door is a metal unit that is shaped like a "C". The shuttle makes up the other part of the "C". The two C's face each other and complete the circle. Grasp the shuttle by the projecting bobbin pin. (Perhaps the photo & videos will help you in placing the shuttle (you'll probably need to wiggle it around a little until it pops into place.) Once the shuttle has snapped into place and you've closed and latched the outer cover, you can install the bobbin case.
Necchi Zig Zag Shuttle movement
Necchi Oscillating Shuttle
Jan 04, 2016 | Necchi Sewing Machines
1910 Singer Hand Crank Machine shuttle hitting
Ok... great. That helps. Here is a manual for the 128 (the more modern version of the 27/28), on PDF page 9 there is an adjustment instructions for the shuttle area. Your shuttle carrier will be slightly different (no button to help remove the shuttle) but the adjustments are the same. Don't be a afraid to "tweak" your carrier gently with a pair of pliers if needed. I found my carrier had been bent slightly a few tweaks, straightened it out and gave me better results. The parts are hard to find and expensive.
http://www.parts.singerco.com/IPinstManuals/127_128.pdf
Aug 04, 2012 | Sewing Machines
Should the machine have some oil? Where? It is a Bernina Activa 130
The Activa range is fitted with a light-weight part-plastic hook/shuttle that Bernina claims does not require oiling. However, this does not mean it shouldn't be regularly cleaned and I'd recommend that it is also lightly oiled at the same time. Remove the bobbin case, press the metal lever to the top left of the bobbin door and the black plastic hook/shuttle retainer should pop open so that the hook/shuttle can be removed, or it will just drop out anyway. Use a cotton bud to firmly clean around the inside edge of the hook race (the round piece that the hook/shuttle sits in. Give the whole thing a good clean to make sure any surface grime/fluff is removed. Put a small drop of oil on the running surface of the hook race - the recessed groove around the inside edge, before replacing the hook/shuttle and holding in place by pressing the hook/shuttle retainer back until the securing lever clicks back into place. Rotate the handwheel once to distribute the oil and off you go. Dont overoil but do this regularly and your machine will run much quieter and produce a consistent stitch formation.
Jul 07, 2011 | Bernina Activa 130
I need to know how to clean and oil the machine
From the Sears Kenmore manual:
Using a small brush, remove the lint that accumulates in the shuttle area and around the feed dogs.
To Clean the Shuttle Area:
  1. This area must be kept free of dust, lint and occasional tangled thread. Raise the needle bar to its highest point and remove the bobbin case.
  2. Push levers of shuttle race aside and lift shuttle race cover and shuttle out.
  3. Clean the shuttle race with a small brush.
  4. Put a drop of oil on the center pin of the shuttle and shuttle race.
Jan 25, 2010 | Sewing Machines
Bobbin and shuttle case pop out of machine .
You might need to clean the shuttle assembly.
1. Raise the needle bar to its highest position and remove the bobbin case.
2. Push levers sideways of the shuttle assembly and liftshuttle and shuttle race cove out by the center pin.
3. Clean the shuttle race of any lint or small particles of thread with a small brush.
4. Put a drop of oil on the center pin of the shuttle and on the shuttle race.
to reassemble, hold sjuttle by center pin and it carefull into assembly opposit the shuttle driver. Slip shuttle race cover into place. Snap the levers into position.
Occasionally remove the needle plate and clean feed dog with soft brush.
I hope that helps!
Apr 23, 2009 | Brother LS-2125 Mechanical Sewing Machine
Shuttle alignment and assembly
The shuttle/race/bobbin system shouldn't really be taken apart by the average user. Unfortunately, your chances of ever getting it back together properly so the machine will sew (this is the timing of the machine) are very slim. You'll need to take it to a sewing machine technician. I would recommend an authorized Pfaff tech as they'll be sure to have the proper tools to do this correctly - won't be inexpensive but will be worth it. Most "neighborhood sewing machine repair folks" don't have experience on computer machines. Resetting timing on a computer machine isn't the same as the old mechanicals and requires some expertise.
May 02, 2008 | PfaFF Creative 7570
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
