Question about Sewing Machines
I purchased a used newhome DX 2015 machine. upon bringing it home and checking it out I found that all of the stitches worked except the back stitch.. I messed with the back stitch button pushing it down several times while running the machine the result is that now it sews in one spot. It will not go forward and occasionally will pull the fabric through backwards. I have worked in a sewing and repair shop many years ago so i took the covers off to see if something appeared to be broken but everything to be in place.. what can I check or do to make it work again?
  • Sewing Machines Master
  • 1,860 Answers
Check to see if the machine is set for darning instead of sewing
Posted on Dec 19, 2014
4 Suggested Answers
  • 54 Answers
SOURCE: Suddenly started sewing backwards (fabric feeds
is your machine sitting in button hole.
Posted on Aug 17, 2010
Tally Girl
  • 1129 Answers
SOURCE: Upper thread brakes often.
It could be your thread is old, dry and brittle, always store out of sunlight and in airtight container to avoid this. You could try putting the thread into the fridge overnight to add a bit of moisture back into it. Or buy some new thread and try again. Also, always use same thread on top as in the bobbin, don't be tempted to just use an old bobbin of thread you have already as different colours and thread top and bottom will affect stitching quality.
If you are getting loops on the underside it also sounds like top tension is not right. Check dial is on 5, and always raise the pressure foot when you are threading up so the tension is open for the thread to go into.
Then lower the pressure foot and pull on the thread below the tension - it should feel firm when you pull it. Also revisit your threading up, it is possible that the thread is catching somewhere between the spool and needle causing it to break so check with your manual carefully to see if you have missed a threading eye.
Failing all of this, go back to the shop and ask them to watch you thread up and see if they can spot the issue.
Posted on Jun 02, 2011
SOURCE: I just got an old Sears Kenmore Sewing machine model 385.17781. Everything is working fine except the reverse stitch. When the reverse button is pressed, the fabric doesn't move or sometimes movin
it sounds like the feed dogs & the reverse button need to be
checked at a repair shop,
to see why they are not responding to each other.
Posted on Sep 11, 2012
I am a swimwear designer and just got a juki ddl 8300n did I pick a good machine? How can I adjust the machine for a more stretchy stitch?! What number should my stitch dial be on to get a stretch?
Perhaps a manual would be helpful:
File JUKI DDL 8300N Instruction Manual pdf
You should probably contact the manufacturer with questions. Hopefully, you did some thorough research before purchasing this machine. From the info I found, it appears to be a straight stitch only machine. I don't know anything about this machine, but I would be hesitant to purchase a straight stitch machine for sewing swimwear. Usually, swimwear needs a stretch stitch or zig-zag capability. Just my thoughts...
Amazon com Juki DDL 8700 Industrial Straight Stitch Sewing Machine Arts...
Juki DDL 8300N Industrial Single Needle Lockstitch Sewing Machine with...
JUKI DDL 8300N Straight Stitch Industrial Sewing Machine With Table Lamp...
Nov 21, 2016 | Juki Sewing Machines
Stitch length will not change
Setting Stitch Length: A Quick Look at How and Why ...
www.sew4home.com/.../sewing.../setting-stitch-length-quick-look-how-a...
Mar 3, 2015 - The majority of sewing machines indicate stitch length in millimeters. A 2.4 stitch length means each stitch will be 2.4 mm long. ... When you adjust the stitch length, it's not the needle that is changing, it's the feed dogs (those ...
How to Select Stitch Length ' Sewing Lessons - YouTube
? 2:40
https://www.youtube.com/watch?v=YqwHtYpKBzo
May 31, 2011 - Uploaded by HowcastArtsRec
Learn how to select stitch length when using your sewing machine for ... also not so small that it will take forever to get through your machine.
How Do I Fix My Sewing Machine: Troubleshooting Your ...
www.craftsy.com > Blog Home > Sewing Blog
Jan 24, 2016 | Sewing Machines
I have a Janome Newhome 672. Cleaned and oiled it, works great. But, the decorative stitches will not form correctly. The reverse is not engaging. How can I fix this. Also, the button hole knob h
In most cases Laurie, with decorative stitches selected some machines can't sew in reverse. Your stitch length is too long or too short to make the decorative stitches sew correctly. So many things could be wrong. I'd need more info to get you going again.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Oct 22, 2014 | Janome Sewing Machines
My sewing machine will only sew in reverse
The stitch length lever on some machines will back stitch when the lever is in the uppermost position. Bring the lever down to an appropriate stitch length and your machine should stitch forward.
Oct 11, 2014 | Singer 3116 Simple
Can I sew a Blanket stitch with my Bernina 930 Record machine?
Once upon a time, a blanket stitch used to be a long wide zigzag stitch. If you are referring to an electronic stitch version that would look like the inverse of a blind-hem stitch, then no, this is not possible on the 930 record machine.
What is nowadays called a blanket stitch used for quilting applications requires the machine to stop feeding during the stitching cycle to allow for the single stitch to the left and then back again. An electronic step motor machine, common to all newer Bernina machines can do this and or similar functions. That being said, don't be thinking about getting rid of your 930. Better to get one of the newer units for occasional blanket stitching and keep the Swiss made 930. The Bernina 930 is a lifetime machine. Computers machines are not lifetime class machines by virtue of being computers. Electronics are short lived.
SewTechnical Home
Jun 17, 2014 | Bernina Sewing Machines
Bernina activa 230 sews a stitch then stops?
sounds like you bought someone else's problem, it could be mechanical or if the machine has a computer, that could be the problem, it would be a good idea to have the machine checked since it is used...
May 04, 2014 | Bernina Activa 130
Machine not working as normal
it's possible there could be a loose or broken part in the machine, and the cam that does the zig zag could be worn or damaged.
having it checked would be a good idea.
Apr 03, 2014 | New Home Sewing Machines
Thread becomes jammed in reverse
Reverse can be tricky if the machine is not timed correctly. So try this. after you've stitched forward for a while, use the hand wheel to bring the needle all the way down into the fabric and let it come part way up. Then push your back button and take your back stitches. If that works for you then you know the machine should be checked for proper timing.
Oct 02, 2013 | Singer Sewing Machines
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
May 08, 2008 | Sewing Machines
Sewing Machines Logo
155 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
