Question about Pelco PEL-PMCL542A-S 42-Inch Liqued Crystal Display 500-Series
I have a Pelco PMCL542A 42" monitor that power RED led is on but screen is black
MODEL: PMCL542A
    Scholar:
  • 92 Answers
Your TV might just have a blown capacitor? It also can be a bad power supply not powering up the screen. The Backlight might be burned out but in my experience it always is a blown capacitor in the main board. If your handy with opening up the TV, look for a can like component that might be all black in color oozing a yellowish grease like substance? Replacing a blown capacitor is quite easy by just desoldering it and replace it with a new one of equal values.
Posted on Dec 13, 2014
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
Lcd tv's Do that when the backlight bulb is out. There should be a small panel on the back. Order a new bulb and replace it and it should work fine.
Posted on Dec 07, 2014
Tip
Pelco PMC10A Monitor 10 INCH COLOR HIGH RESOLUTION
We bought 6 Pelco PMC10A Color Monitors and they are working 24 hours a day. Suddenly after the warranty was over, the screen went totally black on 3 of them. After searching a while for the cause, Pelco seems to have used the wrong capacitor on their board close to the fly-back. They used a catalytic capacitor G-LUXON 4.7uf 50v and they have all busted by just looking at it on the board. I replaced the defect capacitor with a 4.7mf/250V Metallized Polyester Film Capacitor for about $2 each. They are now fixed! Hope this will help someone that has the same problem as I did.
REF: http://cgi.ebay.com/4-7mf-250V-Metallizd-Polyester-Film-Capacitor_W0QQitemZ220150073474QQihZ012QQcategoryZ4662QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
on Dec 03, 2007 | Pelco Pel Monitor 12" B/W
How do I reset KBD300 pleco keyboard
To initialize the keyboard, wait five seconds after powering-up the CM6700, enter the number for the
monitor you are viewing (1-4), and press MON. The LED display shows the number entered.
NOTE: You must re-initialize whenever power is cycled.
Source: http://www.jmacsupply.com/v/vspfiles/files/PMFiles/Pelco/Instructions/KBD300A-InstallationManual.pdf
Jan 15, 2015 | Pelco Kbd300a Pushbutton Control Keypad W/...
I have a Peloc 500 series monitor 32 " that seems to have a power isue. The power led stays an orange/red color. I have left it unplugged for quite some time to let it cool down, but made no...
I have never work on this model yet, but the power supply voltages and caps will be the first palce to look. May be you should open it up and inspect the pwoer supply module first.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 04, 2011 | Pelco Computers & Internet
I have a pelco pmcl319 19" lcd monitor. when i switched it on the power (LEDlit) stays blue but it has no display. hope you have a solution for this. thanks.
First thing I would recommend is to get a flash light and shine on the surface of the screen where the Pelco name normally appears when first turned on. Next press the power button and watch at the center of the display. If you see a gray image of the Pelco name then the ccfl backlighting is no longer functioning. I have been able to order replacement ccfl lamps and if need be inverters that drive those lamps. These part can be purchased from http://www.lcdparts.net/. Disassembly of the LCD display is required as well as some soldering.
Feb 17, 2011 | Pelco 300 SERIES 19 INCH FLAT PANEL LCD...
I am looking for a wiring diagram for a Pelco TV10AC zoom lens.
Zoom yellow
Focus Green
Common Black
Common Red
video (aiv) AUTO IRIS lens back side
1 = Red wire VCC (+9 to +18 VDC) _____
4 = Black wire Ground p ' '
3 = White wire Video Signal L ' 2 1 '
u ' * * '
g ' '
1 = red ' 4 3 '
2 = nc ' * * '
3 = white \ /
4 = black \ /
\__/
Jan 04, 2011 | Pelco Cameras
Monitor wont turn on. is there a fuse of some sort inside? or any other minor issues i should check?
There is always a fuse inside and if it is blwn, there is something else that has failed. Check the power supply caps also. Common failure.
May 05, 2010 | Pelco PMCL417 17 in. LCD TV
Power Reset
First disconnect the plug. Wait 5 min. Plug back in. Then press the menu button and while holding it, switch it on. This should do the trick for most models.
Cheers
TeaCii
LiveOnline to earn money if you have website
Guard to watch you CCTV for $1
Apr 06, 2010 | Pelco PMCL 400 Series Flat Panel, TFT...
Screen went black
I am working on one right now with a similiar problem. The power supply is bad in the one I am working on, and sadly, the part is not made anymore. I hope you have better luck than I am finding the bad component in yours. Sorry for the negitive answer.
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Televison & Video
Pelco PEL-PMCL542A-S 42-Inch Liqued Crystal Display 500-Series Logo
63 people viewed this question
Top Pelco Video Cameras Experts
Are you a Pelco Video Camera Expert? Answer questions, earn points and help others
