Question about ZTE Cell Phones
My zte warp recently started to not respond to touch. IF I can get it unlocked, the entire right side of the screen is unresponsive. Most of the time if the screen is off, I will push the button to un
I have deleted almost every app on the phone, and try to not let it connect online. I have installed the clean master app, and have actually cleaned A LOT off the phone.
  • Stephanie Walter
    Stephanie Walter Dec 05, 2014
    half of my question doesnt show.
Where is the digitizer located on the zte warp elite
this is a layer just below the glass.
The digitizer is the key component in touch functionality
Zte warp elite lcd disaseembly
Oct 06, 2016 | Boost Mobile ZTE Warp Sequent Touchscreen...
How to fix the screen to stop showing colors.
Screen Is Damaged--Replace It
Mar 19, 2015 | ZTE Warp
My screen is not working at all
tune the phone off and turn it back on
Feb 25, 2014 | ZTE Warp
Wet phone black screen buttons light up can charge
Step one- try pressing volumen k- and power k at the same time .this will refresh your phone. Second possible solution. When your phone starts try hitting menu I before screen gets black and reset it.be aware this step erase all your stored info and contacts. I hope this will do something for your phone. Cheers:)
Dec 06, 2013 | ZTE Warp
My touch screen phane has a little crack is really hard to unlock when it is it moves the screen by itself and you cant stop it
Boost may not be able to help with that, you may have to send it back to ZTE and pray that they know what they're doing.
Nov 08, 2013 | Boost Mobile ZTE Warp Sequent Touchscreen...
How to unlock
If your phone is pattern locked then either it will ask for Gmail account details if you have registered one or you can just enter *983*987# in the Emergency Dial which unlock your phone and also your phone will be resetted and all the datas will be erased. If your phone is locked with some PUK code then contact your service provider to unlock the phone.
Feb 07, 2013 | ZTE Warp
My phone has a black screen and a green robot on it when i turn it on
That is the boot up screen for the android. You can change the back ground in the settings menu under personalize I believe it is.
Jan 21, 2013 | ZTE Warp
I have just purchased TF101 eee pad. it is showing the desktop with the time and a lock in a circle. when i touch the lock to open it, it does nothing. how do i open it?, or get it to respond?
To unlock the scree, you need to tap and hold the lock with the circle around it. When you do that it makes a larger circle and moves the lock to the right side of the larger circle. While still holding, drag your finger to the lock (or to any part of the larger circle) and the device will unlock. If the touch screen is unresponsive you can press and hold the power button for about 10 seconds and the device will reboot.
I hope this helps. Let me know if you have any questions and I hope you enjoy your new Transformer.
Thanks,
Ray
Jun 14, 2011 | ASUS Computers & Internet
Touch screen is unresponsive
If the Touch Sceen is not responding properly, calibrate the touch screen.. Turn the Nuvi off then back on Slide Power key to the right (lock) Hold your finger on the secrren for 30 seconds until the calibration screen appears Follow the on-screen instructions
Oct 26, 2010 | Garmin GPS
Cell Phones Logo
65 people viewed this question
Top ZTE Cell Phones Experts
john smith
Nyte_Ryder
vince
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
