2003 Mazda Protege Logo
Posted on Jul 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rattling soung after changig timing belt of Mazda
I have rattling soung after changig timing belt, water pump and est of the enginge belts of 2002 Mazda protege, 2.0 litter. What is the probable reason.
nathan
Level 3:
  • Master 634 Answers
  • Posted on Jul 06, 2009
nathan
Master
Level 3:
Answers
634
Questions
0
Helped
290092
Points
1974
Light metalic pinging type noise check for loose heat shield and pipe clamp, if not could be few things need more info
2002 mazda protege - 2.0l - car sat for a week and when started alternator belt squeeled and ate some belt up. Now it seems ok. Bad alternator or bad water pump?
could have been a loose belt to start with. check alt and water pump. if alt is not noisey and charging. check water pump for leaks and noise. make shore belt is in good condision and the correct tension
My tribute is getting hot and has a rattling/ tapping noise in the motor.I have checked the oil and water and both are fine. Is it possible that the timing belt needs replacing, and how often should this...
timing belts should be checked every 20,000 miles and replaced every 50,000 but sounds like you need a new thermostat and your valves are going bad
2helpful
How do you replace the water pump on a 2002 mazda 626 4cyl? does it interact with the timing belt?
hi from uk the 626 water pump is not driven by timing belt but by another drive belt so easy to change after removal of under wing cover to access /see pump b4 you remove drive belt would advise you to slacken off the water pump pully 1st while it is held by drive belt to prevent turning ? then with belt off /pully removed pump is more accessable hope this helps?
1helpful
Timing Belt on 2002 Mazda Protege
every 90,000 to 100,000miles and yes it is strongly recomended to replace the water pump with it
2helpful
REPLACE WATER PUMP THE EASIEST WAY
well get ready cuz ur not gonna like it in order to change the water pump you must remove the top left motor mount then remove all the belts and plastic covers you can get to then pull the harmonic balancer and acc belt tensioner then then remove the rest of the plastic covers take off the timing belt and tensioner pulley assembly then u can remove the water pump install is reverse of tear down but make sure you get the block clean and replace the timing belt too otherwise that water pump wont matter cuz you'll meed a new enginge when that belt breaks
3helpful
Water pump replacement in a 2002 Mazda MPV
The reason is the water pump is driven off the timing belt, extra parts and allot more labor. No the eng does not have to be removed, labor time around 4 hours, parts about, about $125 US for parts, if it is a dealer add $75 US
6helpful
How much should I reasonably pay to replace the Timing belt in my 2002 Mazda Protege 5?
replacement of timing belt $350-$500. aftermarket shops will try to sell you a package containg a belt, water pump, and tensioner pulley. the dealer will just replace the belt, they might recommend to replace the water pump if there are alot of miles on the car, they will also inspect the pulley for wear.
Timing belt/waterpump
usually a good time to change it is at about 100,000 miles. change it before it becomes a must or not ride(type of thing). if your water pump is run by your timing belt, then yes you should change the water pump when you do the timing belt. the tension from the new belt will sooner than later kill the bearing in the old water pump and it will cost you twice to fix it versus the one time fix. when you go in to the shop there should be no additional cost to replace the timing belt because it has to come off to replace the water pump.
Top Mazda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mazda Expert? Answer questions, earn points and help others
