Question about Panasonic SA-HE7 Receiver
I have panasonic sa he7. My problem is error f70 overload.There was a electrical failure in my speaker. After that reciever showed f70 overload error. Fuse is not the original one. After that every ti
I tried to replace fuses but the reciever still showed the message.
I have he-75 Panasonic reciever and left channel not working at all
it showed f70 error after restarting no left channel
can u help me out i just want to fix it diy only nothing professional
Posted on Sep 28, 2016
  • Panasonic Master
  • 757 Answers
You may have a speaker connected that the amplifier cannot drive. Your receiver is compatible with speakers with 6-8ohm rating, however, even though your speakers may be operating within that range they may also have low sensitivity.
With the receiver turned off, disconnect the power cord for a few minutes, reconnect and then power it back on. And while you're behind the unit, that would be the convenient moment to inspect your speaker terminals...check for cracks, evidence of arcing and any stray pieces of strand wire that can touch the chassis or other terminals. If any of those conditions exist then that can a root cause of the problem and will have to be repaired.
You must also ensure that all of the chassis vents are not blocked and the unit does not have another device on top of it that also generates heat as well. In any event, keep it cool.
After that, enter into your speaker setup menu and adjust your crossover to a higher point for whichever speaker you had the failure. This will help control the overload condition, if in fact, it is being caused by your amplifier ability to drive your current speakers.
If after all of the above is performed and the condition still exists, try speakers with compatible ohm rating but higher sensitivity.
Posted on Dec 06, 2014
AV CONTROL RECEIVER SA_HE7 F70
F70 error checking fixed contacts fuses.
Oct 04, 2013 | Panasonic SA-HE7 Receiver
Panasonic receiver Panasonic SA-HE7 PARTS
Tell us on what to look for board resistor R1702 and transistor Q1702? And what foot solder a resistor to the transistor (collector)?
Jan 10, 2012 | Panasonic SA-HE7 Receiver
Panasonic AV Control Receiver SA HE7 error code F70
solution about f70 on my amplifier to remove
Jun 07, 2011 | Panasonic SA-HE7 Receiver
Panasonic sa-he7,no sound from sub output,im using a samsung subwoofer of impedance 6
Have you looked at the manuals?
If the unspecified sub isn't self-amplified it won't work with this receiver.
If it IS self-amplified you still needt o set up the receiver to run a sub.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SA-HE7-Receivers-manual/id/312ag700/t/2/
May 10, 2011 | Panasonic SA-HE7 Receiver
I have an error on my receiver that says "error F70 overload", how to fix this?
check to see that you have positive and negative wire connected correctly and that none of them are touching each other
Sep 23, 2010 | Panasonic SA-XR55 Receiver
Firt a error F70 and overload
a error F70 in my panasonic sa-he7
Oct 14, 2009 | Panasonic SA-HE7 Receiver
Amplificador panasonic modelo sa-he7, se pone en error f70
rafatecnico amigo mio el error esta en la placa de coneccion de dispositivos auxiliares por favor revisa soldaduras de los dos transistores de potencia que se encuentran juntos y de los dos transistores de acople de los de potencia, si se encuentran bien entonces alguno de ellos esta averiado en cortocircuito o abierto
Jul 29, 2009 | Technics Audio Players & Recorders
TECHNICS SA-DX850 F70
It could be an overload from two speaker wires crossing, check the owners manual for error codes.
Dec 22, 2008 | Pioneer VSX-818V-K Receiver
Intermittent F70 Error
F70 interrmintent problem caused by (Ic-current) interupted, supply for cpu, Q1702 (emitter point) high resistant to IC1701, suggestion- connect a wire between these component due to pcb track poor contact.
Aug 21, 2006 | Panasonic SA-HE7 Receiver
Panasonic SA-HE7 Receiver Logo
412 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
