Question about LG LSC26905TT Side by Side Refrigerator
I have an LG side by side refrigerator. It wont stop making ice. The arm on the front of the tray is all the way up and it wont go down. It stays up all the time. Any suggestions
  • 59 Answers
I would check and make sure the arm is securely attached. It may have slipped out of it's operating position. Can you tell if the motor is trying to move the arm and the arm is slipping. If the motor is working, something is blocking the arm from returning to the down position or the arm is not properly attached.
Posted on Dec 06, 2014
    Master:
  • 966 Answers
Jesse, there must be something that is preventing the arm from going down. Can you check? Also try emptying the ice and re-install the container making sure nothing blocks it. sorry not much of a help.
I have an LG side by side refrigerator. It won't stop making ice. The arm on the front of the tray is all the way up and it won't go down. It stays up all the time. Any suggestions
http://www.searspartsdirect.com/ replace the ice maker would be the simplest. If you're a good DIY'er, shut off the water to the icemaker, remove the maker and try your skills at troubleshooting the unit. The timer on the icemaker is suspect as it controls the water valve. The wire bail you mention only tells the ice maker that the tray is full and to stop making ice by stopping the timer until you push the bail back down. My guess is that the timer motor failed and stopped just as the water was turned on, BAD TIMER!
Dec 05, 2014 | LG LSC26905TT Side by Side Refrigerator
Ice maker stopped working in lg refrigerator lfx25976st/00
I just slide the ice tray to the left and down till it unhooks from the right hand side. Then unhook the wires from under the tray. To replace just repeat in reverse order. I have to take our ice tray out ever so often to clean it since we have well water.
There is a little square button up under the left hand side in the back. If you press that with a screwdriver or butter knife it will reset the ice tray and it return it to fill with water.
Sep 03, 2012 | LG Refrigerators
KitchenAid 25in KSRJ25CNST00 icemaker trouble. The LED light on side of freezer is blinking twice with a delay and repeats same sequence. No ice is making. Any suggestions on what to look for?
Try the reset button on the control panel. If that doesn't work, then try unpluging the refrigerator.
Also, make sure that ice tray shut off arm isn't in the up position. It should be in the unlock position one notch below the off position. This arm is used by the refrigerator from over filling the ice cube holding tray. Once the ice fills the tray. The ice in the bend will push up on the arm which
initiate the ice maker to stop making ice. As soon as you start using the ice in the bend and the arm falls below the off position. The ice maker will start making ice. GB....stewbison
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Lg side by side model number lrsc23915sw how to turn off ice maker
I'm having trouble identifying that model number, but I can give you the generic answer. On most icemakers the "shut off" is lifting the wire arm to the up position. It should lock in that position. Lifting the arm shuts it off in the same manner that it stops the ice maker when too many cubes are in the tray. I have seen some icemakers that actually have a swich on the front side of them. But, they are in an obvious position so I'm guessing you don't have that style.
Hope this helps
Jan 28, 2011 | LG LRSC26920TT Side by Side Refrigerator
Ice maker is not making ice, the arm that indicates if the chest is full won't go down, it is stuck in the up position
It is probably frozen in place. The old ice tray bend and spils water all over the place. Have you changed the ice tray with the update?
Sep 10, 2009 | LG LSC26905TT Side by Side Refrigerator
Icemaker not producing ice
you need to troubleshoot the problem, if the wire arm that tells the ice maker to stop making ice when full is in the upright position the ice maker will not make ice. the problem has to be either the switch on this arm malfunction. but probably in MOST cases it is your electronic water valve which has gone out. this is located on the water supply line on the back of the fridge at the bottom probably behind some cardboard or plastic. it is the same kind of water valve as a dishwasher uses, if it malfunctions it will not deliver water to your tray, manually fill the tray and put the arm down, if the maker dispenses the ice out of the tray, chances are your electronic valve is broken.
Apr 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Faulty ice maker
Hello. Yes, that is the correct position for the icemaker feeler arm. The updated icemaker has a longer feeler arm that hangs down a little more (thereby shutting off sooner when the ice piles up not so high).
Your water leak onto your food is from water spilling out of the front left corner of the ice tray during fill. This has also been updated with a plastic lip that keeps the water from sloshing out when filling up.
The photo shows that your ice tray appears to be unlevel and drooping in the front left corner. This happens with flex tray icemakers over time. The icetray does not fully flex back to its level posiiton. I do not feel you need to replace the entire icemaker. Repalcing just the ice tray should fix your issue.
Hope this helps, please rate my solution.
Jul 01, 2008 | LG LRSC-26922 Side by Side Refrigerator
No ice
There is a gauge of some kind which determines how much ice is in the trough. It is often an arm which is now raised out of that tray...Push it down.
Dec 21, 2007 | LG LRSC26910 Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
