Machine failure c2810 - Office Equipment & Supplies
    Problem Solver:
  • 15 Answers
What brand and model of your machine?
Posted on Dec 06, 2014
Hello , I have kyocera taskalfa 6550ci with c2810 error code we replace the waste toner motor and PWB, drive shaft is working too but still the problem is there . any help please
Which PWB did you replace? Check the long PWB in the front of the machine. If the waste toner motor plugs into it you may need to replace the board.
Aug 10, 2017 | Kyocera Office Equipment & Supplies
How can I get my computer out of safe mode?
With the machine unplugged from the wall remove the battery from the motherboard. Then with the machine still unplugged press the On button for 30 seconds to dissipate any remaining electrical charge on the motherboard. Then re-install the battery, plug the machine back into the wall and see if it will boot normally.
May 11, 2015 | Dell OptiPlex 330 Minitower Desktop...
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
I am recieving machine failure on kyocera 4200 dn
The most common machine failure codes is CF---. For example CF248, CF000. In the most cases the printer is need to be upgraded to the latest firmware.
Jun 10, 2014 | Kyocera FS Office Equipment & Supplies
My machine beeps 2 long and 4 shot times. what is the problem?
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Nov 02, 2012 | Dell Dimension 4600C PC Desktop
I have by cannon 6570i moddel ihave continew error {chek the network conection chek the tcp ip the defalt key is curruptedor invelid}
1) Select the following service mode COPIER>TEST>NETWORK>PING, and select PING.
2) Enter the IP addressof your PC using the numeric keys on the control panel, and press OK.
3) Press the start key.
- OK is displayed if Ping succeeds, but NG is displayed if it ends in failure.
Perform this procedure only when connecting the machine to networks.
If the machine fails to be connected to networks, any of the following causes is probable.
a. Connection failure between networks and the machine
b. TCP/IP setting failure of the machine
c. User network failure
d. Main controller PCB failure
The detailed check methods are as follows.
Checking with Loopback Address
you can check whether TCP/IP settings of
the machine are appropriate by executing Ping with this address.
1) Enter the loopback address (127.0.0.1) in PING.
- If NG is displayed, check TCP/IP settings of the machine again, and re-execute Ping.
- If OK is displayed, perform the next check.
Checking with Local Host Address
The local host address is the IP address of the machine. Since the local host address returns in response to the network controller by executing Ping with the address, you can check whether the network controller (main controller PCB) is in a normal condition.
1) Enter the IP address of the machine in PING.
If NG is displayed, take the following actions, and re-execute Ping.
- IP address error of the machine: Check to see again if the IP address settings of the machine are appropriate. Ask the system administrator whether the allocated IP address is valid.
- Failure in the main controller PCB: Replace the main controller PCB
If OK is displayed, a cause may be user's network environment. Inform the system administrator of the current situation, and ask for measures.
Apr 16, 2011 | Canon imageRUNNER 5570 Copier
Kyocera KM1530 photocopier. What does C610 mean? It is comin gup on the display when we turn our machine on.
C610 = Fusing Unit Heat failure. The fusing unit is the part that gets hot and "fuses" the toner onto the paper. The C610 code means that the fuser is not heating up as it should. The 2 most common causes are thermal fuse failure or thermister failure. The thermal fuse will keep the heater lamp from coming on while the thermister failure would cause the machine to not "see" the temperature rising as thus shut down the machine. Either way you will need a service company to come out and diagnose/repair the machine. You must also use the factory service mode to reset the fuser failure code.
Good Luck and Thnak You for using Fixya.
Sep 13, 2010 | Office Equipment & Supplies
HE5 frontload washer error f11
F11 error code indicates a communication problem. The communication between the Central control board and the Motor control board cannot be sent correctly.
Potential causes:
1. Loose connections between the motor control board and the machine control board, or at
motor
2. Machine control board failure
3. Motor control board failure
4. Motor failure
5. Door lock failure
If this answers your problem, please rate my answer.
Thanks,
David
May 27, 2009 | Kenmore Elite 45986 Front Load Washer
Power failure message.
Power Failure Recovery
If the system is disconnected from the AC power it will not operate. Your announcemen and messages are retained in memory during a power failure but you will need to reset the clock. See the instructions on the bottom of the unit. If the message window displays CL, you need to reset the clock. See the instruction on the bottom of the unit.
Mar 11, 2008 | AT&T 1726 Digital Answering Machine
Engine failure notification
Yep. Most likely you could replace it for the price of repair
Nov 12, 2007 | Xerox WorkCentre 385 Laser Printer
121 people viewed this question
jasbo
jasbo
