Question about Volkswagen 2006-2010 Jetta TDI Steering Wheel Cover Original One Color, Size 14-1/2 x 4-3/4
There is a problem with my electronics. I am unable to open the trunk or the fuel flap with the release buttons in the car. I need fuel. All of my windows are open and I'm unable to close them at all. The key fob doesn't work to lock and unlock the doors.
  • 5,316 Answers
If you have checked all fuses (may be located in more than one place), next would be to check fusible links.
Posted on Jan 15, 2015
Testimonial: "thank you. The problem was in fact the wiring harness in the driver door which I had replaced last week. Apparently this is a flaw in the 2005 - 2006 Jetta's as they economized on the wiring in the original production of these models. Many VW dealers are aware of this but no-one let the vehicle owners know about it. There was apparently an extended warranty offered to those who brought it to VW's attention. If it happened after the "expiry" date you are on the hook for everything personally. Not a very nice way to do business."
  • David Harrelson
    David Harrelson Jan 16, 2015
    Thank you for the feed back. Glad you got it fixed.
S60 Trunk won't open with remote or switch
trunk won't open with remote/release - Volvo Forums - Volvo ...
volvoforums.com > ... > Volvo Vehicles > Volvo S60 & V60
Oct 24, 2008 - ... will not open with the remote nor with the release switch on the trunklid. ... My 2002 S60 trunk button (above Lic. plate) never has worked. electrical trunk release
Apr 15, 2011
trunk won't open
Jan 27, 2011
Trunk won't open
Sep 7, 2009
New to me 04 S60 trunk release problem
Sep 27, 2006
More results from volvoforums.com
Re: 2002 S60 Trunk won't open with remote or switch - Matthews ...
www.matthewsvolvosite.com/forums/viewtopic.php?t=45848
Jan 16, 2012 - My trunk won't open with the remote or by using the soft switch"handle" on the trunk. I can open the trunk using the key. I can hear an electronic ... Trunk & Fuel Door Won't Open & Fuel Gauge is Wrong In 1 Day?
Dec 2, 2015
Power Locks/Fuel Door/Trunk won't open 1999 s70 GLT Turbo ...
Aug 14, 2011
2001 V70 T5 Tailgate - Matthews Volvo Site
Jan 12, 2010
Re: 98 V70 XC - Trunk open light on - Matthews Volvo Site
Dec 20, 2009
More results from www.matthewsvolvosite.com
Dec 18, 2015 | 2006 Volvo S60 2.5
Trunk will not open fuel door will not open all fuses ok
You have listed the vehicle is a 1987 Jaguar XJ6. The trunk is not electronic and only unlocks with the key as well as both the gas doors. Any issues here then it is your key or the actual trunk latch. If you do have a 1988 model year then the trunk lock has 3 positions. locked all the time, unlocked all the time or the vertical position locks and unlocks with the vehicles drivers door lock. If the trunk button (paddle) is loose and moves but nothing happens then the inside rod has come loose and you will have to manually operate the latch by removing the license plate and taking a long screw driver through the lower plastic bungs. The fuel flap is a separate unite and does have a manual release but you need to open the trunk to get to it. If the fuel flap stays locked all the time then the actually filler neck module will need replacing.If you have a 1997 which has the electronic release button to open the trunk (95-2003) Then you will need to firstly lock all door and unlock the drivers door 2 times. Check the fuel flap is now released, if not then the fuel flap actuator located on the filler neck inside the trunk is bad. If the trunk does not open with the remote, inside car switch and trunk mounted switch then the passenger side trunk harness is broken. Open the trunk with the key and on the right(passenger) hinge there is a grey plastic cover, remove that cover and carefully peel back the wiring harness cover and you will find 1 or more broken wires. Once the wires are repaired then I recommend you zip tie them in place and retest the trunk release button.If this does not answer any of your questions please feel free to email mejpseuro@gmail.com
Jan 23, 2012 | 1987 Jaguar XJ6
2006 2.0T fuel filler flap will not open with the button, How can I get this open?
There should be an emergency release in the trunk on the side that the fuel door is on.
Jan 22, 2011 | 2006 Volkswagen Passat
Unable to open fuel tank flap on a Volkswagen Passat cc. with the push button release. is thier another way.
You need to remove the lining by the fuel door in the trunk. Once you get the lining loose you can bend it out of the way and remove the solenoid that is held in place with 2 philips head screws.
Dec 18, 2010 | 2002 Volkswagen Passat
2001 audi tt -- trunk release and gas cap release don't work
Hi, yes there is. To release the trunk - look on the centre console, just rearward of the front seats and you will notice a separate rectangular section in the plastic, if you lift this out you will find a cable release for the trunk underneath. To open the fuel filler cap manually, look inside the car just behind the rear light on the same side as the fuel filler and you will notice a flap in the interior trim, which is to allow access to the rear lamp. Open this and then looking towards the top you should see a loop of orange plastic - pull this towards the rear of the car to release the fuel filler.
Hope that helps Matt..
Nov 18, 2009 | 2001 Audi TT
Trunk release and fuel door release buttons do not work
cable knocked loose and key wouldn't work if it did previously. last option, obtain acess from back passenger seat and pull aux cable or force lock open, as far as the key issue, call a locksmith
May 29, 2009 | 1996 Pontiac Grand Am
Is there a way to manually open the gas flap?
Inside the boot there is a liitle cord with a fuel symbol on it. pull this and the cap will open.
Apr 27, 2009 | 2005 Volkswagen Jetta
i just bot mazda millenia and i can't find trunk release???!!!!
Mar 15, 2009 | 1996 Pontiac Grand Am
Locked trunk
There should be a button on th dashboard to open the trunk. I would think the emergency release is for the fuel filler flap. Is the key going in the lock? maybe it just needs a squirt of wd40?
The ford locks can be taken apart and made to fit any key, by rearranging the tumblers in the lock.
Any decent garage would be able to do this for you.
TL
Jan 02, 2009 | 2001 Ford Focus
Need help
There is a release in the boot (trunk).  It's a little green piece of the plastic about 12mm diameter that is stuck in the trunk lining just on the other side of the fuel filler.  Pry it out of the liner and pull on it.  That should open the fuel door.
Sep 12, 2008 | 2001 BMW 325
Volkswagen 2006-2010 Jetta TDI Steering Wheel Cover Original One Color, Size 14-1/2 x 4-3/4 Logo
82 people viewed this question
Top Wheelskins Vehicle Parts & Accessories Experts
David Harrelson
David Harrelson
RAYMONDO1953
john h
Are you a Wheelskins Vehicle Part and Accessory Expert? Answer questions, earn points and help others
