Question about Electrical Supplies
Can the dishwasher hose intake be rotated so that the hose does not have to loop around the disposal?
  • 5,245 Answers
You can cut off the dishwasher hose so it is shorter, but that might not give correct end for connecting to drain tailpiece. See if end of dishwasher hose has built-in fitting.
They sell universal connections that fit both the dishwasher hose and the drain tailpiece... but check what is available at hardware before cutting off dishwasher hose.
The drain tailpiece can be taken apart and then rotated so dishwasher hose can come from different direction. This requires removal of p-trap, and cleaning of each part before reassembly.
If this is double sink, the disposal can be moved to other side, and sink basket with tailpiece move to other side.
Following link has step by step tips for taking apart P-trap and reassembling tubular drain pipes so they don't leak: and installing disposal if you switch sides on double sink
http://waterheatertimer.org/How-to-install-vent-under-sink.html#apart
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Gene
Water Heater Timers Save Money
Posted on Dec 06, 2014
I have to keep cleaning out drain hose filled with food.why?
Question is the drain plumbed to a disposal if so does the drain have a high loop by this does the hose come from the top down to the disposal if not then food from the disposal is migrating into the drain hose
Sep 13, 2014 | Dishwashers
Tip
Pollution may be filming your dishes.
A very important installation trick that is commonly overlooked is the correct routing of the dishwsasher drain hose to the sink drain or disposal. As the hose exits the sink drain or disposal it is necessary to loop the hose up higher than where it is exiting out of and only then go down to the dishwasher sump.
Failure to follow this proceedure will cause a mixture of dirty drain water, dish soap and or disposal debris to siphon this pollution into your dishwasher sump.
on Mar 15, 2012 | Whirlpool Dishwashers
Rough in plumbing diagram
This can vary, but must be higher than the connection to the household drain to prevent the sink/disposer drain water from entering the dishwasher. The best approach will route the dishwasher drain hose up to the underside of the counter top (it is handy to tie off to one of the sink mount clips if they are convenient) and then back down to the household drain connection, often the garbage disposer. Some dishwashers have a drain hose retainer clip on one side of the tank to help form a "high loop" before running the drain hose to the household drain connection. You should *not* ever have more than one (1) high loop as this will impede the dishwasher drain.
Aug 28, 2014 | Dishwashers
Maytag MDBH985AWS leaking
not sure where or how its leaking.- ??. is it leaking out of the dishwasher?, or where the hose hooks into the garbage disposal? here's a check for you tho. make sure that the hose going to the garbage disposal routes
above the disposal and loops back down to where it connects into the garbage disposal. This will keep the water from back-flowing into your dishwasher. Hope that helps. gGood luck
Aug 01, 2014 | Maytag MDBH985AWB / MDBH985AWS 24 in....
Kitchenaid dishwasher wont drain
Allow the current cycle to complete. Draining will occur at the end of the cycle.
Close and latch the door. The dishwasher will not drain if the door is not properly secured.
Press the "Cancel/Drain" button on the dishwasher to start a two-minute drain cycle.
Remove the knockout plug in the disposer outlet of the garbage disposal if the dishwasher drains into the disposal. Turn off the water supply and remove the drain hose from the disposal. Place the tip of a screwdriver on the plug and tap it lightly with a hammer to remove it. Replace the drain hose and turn the water supply on.
Clogged Drain
5
Run the garbage disposal to empty it and clear the drain if the dishwasher drains into the disposal.
6
Remove the cover on the air gap on the sink or countertop. Turn the plastic cap counterclockwise to remove it. Remove soil from the inside of the air gap. Replace the plastic cap and cover.
7
Check the sink. Dishwashers connected to a sink will not drain if the sink drain is clogged. Unclog the sink. Contact a plumber, if needed.
Issues With the Drain Hose
8
Check to see if there is a loop in the drain hose. The loop cannot be more than 20 inches above the floor. Disconnect the hose and loop it just above the floor. Reconnect the drain hose.
9
Remove kinks in the drain hose. Always use the new drain hose included with the dishwasher. Do not reuse old hoses.
10
Check the length of the drain hose. The hose should be less than 12 feet long. Replace with a shorter hose, if needed.
Sep 01, 2012 | KitchenAid KAWS850LE Top Load Washer
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
My new dishwasher leaks water on the floor about an hour after it is completely finished with the cycle
Make sure the drain hose connected to your garbage disposal is connected well. Also, the hose should loop up near the sink (counter top) before it loops back down about 3 inches below the drain connection on the garbage disposal (or sink drain pipe if you don't have a disposal). This effectively makes a drain trap to avoid any smell from the dishwasher.
Also make sure the door is closed properly and there is no packaging material on the door.
Jul 16, 2011 | Dishwashers
I installed a new bocsh dishwasher and garbage disposal. The water is not draining. I routed the drain hose on the floor rather than looping it up the back of the dishwasher, due the short lenght of drain...
If you did not remove the plug from the disposer drain where you made your drain connection will cause the dishwasher not to drain. This should have been mentioned in your installation instructions. Also, routing the drain hose other than what is specified in the instructions, will allow food waste to enter the dishwasher when you grind food in the disposer. Read your instructions and don't take shortcuts, you want to have your appliances work well for a long time, as you have made a considerable investment in some quality appliances.
Hope this helps!
Jul 16, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher does not drain completely, has standing water after every complete cycle.
  • Some water, usually one to two cups, remaining in the bottom of the tub is normal. However, if water is covering the bottom of the tub, the dishwasher is not draining properly.
  • Check for paper or large objects covering or blocking the sump area in the rear of the tub.
  • Make sure that the right type and amount of detergent is used: Using the wrong type or too much detergent can cause sudsing that can prevent the dishwasher from draining. Only detergent specifically designed for automatic dishwashers such as Electrasol®, Cascade® or Cascade Complete® should be used. If you find suds in the dishwasher.
  • Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects.
    Please consult the Owner's Manual. Download a free copy of the Owners Manual and/or Installation Instructions. In the Installation Instructions, will be the procedure for removal of the drain plug. You may also check with the installer.
  • Be sure the kitchen sink drain is not clogged. The dishwasher typically drains into the kitchen sink drain or a garbage disposer. If the dishwasher drains into a garbage disposer, run the disposer to clear the drain system. Do not put hands into the garbage disposer. Serious injury could result. You should always turn on your garbage disposer prior to running the dishwasher to clean out any food or debris within the drain system.
  • Check drain hose where it connects below the sink for blockage or a kink in the hose. New dishwashers come with a white corrugated drain hose, which should be used. Re-using old, worn out drain hoses may promote kinking and blockage. If it is neccessary to extend the length of the corrugated drain hose, be sure the total length does not exceed 120 inches and the extention used is not kinked or crushed. See your dishwasher installation instructions for details.
  • Check the air gap if one is installed. It could be clogged. An air gap (not part of the dishwasher) is usually located on top of the sink. Some state or local plumbing codes require the use of an air gap between the built-in dishwasher and the drain system of the home. This plumbing device is used to prevent the possibility of back flow into the dishwasher in the event of a clogged drain system. This item is not a part of the dishwasher and, therefore, the dishwasher warranty does not cover costs related to cleaning or repairing a drain air gap.
  • Typical air gaps are easy to inspect and clean. Be sure the dishwasher latch is in the OFF position or unlatched prior to removal of the drain air gap cover. Simply lift off the cover (usually chrome, could plastic) and unscrew or unsnap (depending on type of air gap) the plastic cap below. Remove any material that may have accumulated and replace the plastic cap and chrome cover. This simple procedure should be followed any time the dishwasher fails to drain properly.
    View a short video about cleaning the air gap:
    Play Video
    Sometimes perceived "no drain" problems are not "no drain" problems at all, but back flow of water from the sink or some other device into the dishwasher:
  • If you notice dirty water building up over time in the bottom of the dishwasher and do not have an air gap, make sure you have a high drain loop. A high drain loop is created when the drain hose is makes a loop at least 18 inches above the floor. Usually this is accomplished by attaching the drain hose to the underside of the countertop. Without a high drain loop or air gap, dirty water from the sink can flow into the dishwasher. The high drain loop prevents back flow of water from the drain into the dishwasher if an air gap is not installed. View a short video about a high drain loop:
    Play Video
May 08, 2008 | Dishwashers
Installation
It sounds like you have connected your dishwasher to a garbage disposal.
  1. The 2 hoses provided with your dishwasher connect together.
  2. You run the drain hose through a hole in the bottom/back of your cabinet, then up to the top of the cabinet, then connect it to the drain on the garbage disposal. (The reason that you run your drain up to the top of the cabinet is: This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher.)
  3. Be sure to knock the plug out of the drain of the garbage disposal. A garbage disposal is designed to work with or without a dishwasher. The plug is in the center of the drain. The best way to knock this plug out is to pull the garbage disposal, and with a flat screwdriver, knock the plug out.
  4. Then remove the plug from the disposal. Reinstall the disposal.
  5. Install the drain hose. The drain hose will connect right up to the disposal using the clamp provided with the dishwasher.
This should help you. If not please attach more info.
Please rate this solution
Sep 09, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Electrical Supplies Logo
55 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
