Question about Toshiba Computers & Internet
My Toshiba laptop makes a ding sound every so often even though it is shut down. What is that and how do I get rid of the bing
  • mahabishara Dec 05, 2014
    it gave you this sound even when laptop closed ???
  • Lou Duignan
    Lou Duignan Dec 05, 2014
    Yes, and there was no rhythmn to the distance between these dings
    Top Expert:
  • Toshiba Master
  • 21,522 Answers
Is it in sleep/hibernate mode? If it was shut down it should be quiet.
Posted on Dec 06, 2014
5 Suggested Answers
SOURCE: toshiba laptop
think you I like that laptop
Posted on Sep 27, 2008
  • 10 Answers
SOURCE: Toshiba A135 random shut downs
Normal defaults are when lid is closed "Shutdown" and when Power pressed to "Hibernate". Go to Control Panel and select Power Options. Under heading of Power Scheme select the Option you wish. I feel like you want to select Portable/Laptop (XP Pro) and make your changes. Click on the Advanced Tab to select what the Power Button does when pressed (Shutdown) and "When I close the Lid" (Nothing). (Well, those are my settings)
Click on Hibernate Button and un-check "Enable hibernation". When you accept these changes Toshiba will send a message stating that "Toshiba Power Saver mode will be disabled" click OK then click OK again to exit. Try it out.
Posted on Jul 08, 2009
dDex
  • 145 Answers
SOURCE: Hello! Ive got Toshiba Qosmio X300-11W laptop the
Use the correct video driver. Maybe you installed the incorrect video dirver. try installing driver from cd.
Posted on Aug 13, 2009
  • 540 Answers
SOURCE: My Toshiba laptop turns back on when I try to go
The battery seems to be short please remove the battery and use the laptop with the power adapter only to confirm the issue.
Posted on Feb 03, 2010
Get rid of ASK and replace home page with G
Hi John! I found some visual instructions that I think will be easy to follow for deleting Ask.com and adding Google. I have a Toshiba too. Good luck! http://www.bing.com/videos/search?q=how+to+delete+and+replace+a+homepage+on+a+toshiba+pc&qpvt=how+to+delete+and+replace+a+homepage+on+a+toshiba+pc&FORM=VDRE#view=detail&mid=A4BE97CA4E65AD8F8EA9A4BE97CA4E65AD8F8EA9
Apr 21, 2015 | Toshiba Computers & Internet
Indicators& wiper warning sound doesn't work
Wow we are lucky ,the amount of cars i get to remove such things going bleep and ding '''''''''''''' especially on cars built for world markets but made to conform to as many countries laws as possible ,kia hyundai and such are prime examples ,ding ding ding .. or bing ''''''''' ,these noises do my brain or what is left of it that is
Feb 28, 2015 | Cars & Trucks
When I try to log in, the keyboard will not type anything, but makes a ding sound.
Hi Glen,
Before typing your password make sure that there is a blinking line on the password field.
If it is not there, use the mouse to click there and type the password.
Hope that helps.
Dec 06, 2011 | Toshiba Satellite P105-S6197 Laptop
Eveytime i charge my laptop, it automatically shut down, reboot and even hang,
Possible cause:
1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution:
First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Jun 04, 2011 | Toshiba Satellite Pro L300 Notebook
The dinging keeps dinging even though all the doors are shut and interior lights wont shut off when driving
one of your door switches is not working properly try pushing them by hand one at a time and see if it changes anything
Dec 01, 2010 | 2005 Dodge Durango
Feb 03, 2010 | Computers & Internet
Toshiba Satellite 1005-S157 shuts down periodically by itself. Replaced fan/heatsink. Still shuts off.
you need to check a few things... when the fan/heatsink assembly were replaced, did you make sure that the thermal pads on the CPU and GPU are NEW/Good.... Make sure that the Heatsink GPU pad Firmly sits in the chip....
You can test the thermal controller by using a hair dryer or heat gun.... Point it onto the heatsink pipes and see if your fan spins when the pipes get hot, then remove and see if the fans slow after a minute...
You might have faulty RAM or Misseated RAM... Pull The RAM chips and reseat them...
Also Make Sure Your CPU Is Locked Down....
Periodic Shut Downs Can Be Caused By Quite A Few Different Things...
Typically it's due to Thermal Damage
Though Failing RAM or A Failing Hard Drive, Overheated Video/GPU Chip, Or Even Failing CPU can as Well Cause This Issue...
Nov 16, 2009 | Toshiba Satellite 1005-S157 Notebook
chect the operating system maybe some files or configuration change.. try to re install the operating system,, save first you data or make back up.. in another drive.
Jul 06, 2009 | Toshiba Satellite A135 Notebook
Toshiba Satellite A105 laptop keeps shutting off for no reason.
I think your fan might be broken....if the fan doesn't cool the pc,the processor or the chipset will automatically shut down the pc to prevent burning hardware.Or your hard drive might keep crashing.Oh yeah and abstract from this i don't recommend ever using mcaffe
Oct 25, 2008 | Toshiba Satellite A215-S7422 Notebook
Computers & Internet Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
