Question about Qca Spas Paradise Hot Tub
How do i change topside reading from celsius to ferinheight. what are the JP
  • 3,368 Answers
That is in your manual. Not all are the same and we do not know what you have,
Posted on Dec 10, 2014
How to switch temp. readings from celsius to degrees?
Celsius IS a temperature measured in degrees, as is Fahrenheit.
I don't know about your rig, but my guess is that you can hold down the menu button or go to "set up". Get the temp to flash, push the up/down button until the change. If you are needing to make a manual calculation, Celsius is changed to Fahrenheit by multiplying the reading X9, dividing that by 5, and adding 32 to that number.
Ex== 30 degrees C to F is 30X9/5+32= 86 degrees.
Oct 19, 2014 | 2015 Jeep Wrangler
My Dometic digital thermostat wont go up past 32 degrees. What could be wrong?
indicates inside sensor defective or not communicating resulting in a/c being locked out.
Sep 16, 2014 | Dometic 3313192.000 White Single Zone LCD...
On the FAH125p2T the display is reading in celsius instead of fahrenheit
Good Afternoon Friend,
I understand you are trying to change the display from Celsius to Fahrenheit. To convert from one to the other and back, press and hold the " TEMP/TIMER" Up arrow and Down arrow buttons together for 3 seconds. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire Heating & Cooling
I know its very simple but I cant remember how to switch the ferinheight back to celcius in the display screen above my radio and that.. what are the steps?
read the operators guide, its in the glove box.
if missing ,get one, you really need to have it and read the warnings.
Oct 25, 2013 | Suzuki Cars & Trucks
Changing the external temperature gauge from Fahrenheit to Celsius
If your temperature reads in climate control reads in degrees Celsius "C" instead of Fahrenheit "F", follow these steps to change to Fahrenheit.
  • Turn the ignition on.
  • With the climate control turned on, push and hold the recirculation button in. While holding the button in, push and hold the off button in for 3 seconds or until you hear a beep.
The display should then change to "F". Follow these same steps to change your read-out to Celsius , if preferred.
Sep 21, 2012 | 2005 Land Rover LR3
How do I change the temperature reading from Celsius to Fahrenheit?
with the switch in the 'lock' position, hit the C/F button (also labeled as the 'min' & 'date' button)
Dec 30, 2011 | Elgin Travel Alarm Clock
The digital thermometer was flashing "lo". I assumed it needed new batteries and then replaced them. It is still flashing lo, but also showing a C reading. What do I need to do to reset it?
there should be a setting on it that changes the temp from Celsius or "c" to ferinheight and lo means that it currently isn't reading a temperature in the normal range. try running it under hot water and see if it says error or high.
Jul 15, 2011 | Prestige Medical Infrared Ear Thermometer
How do I change temperature reading from celsius to fahrenheit
There is a formula for that
F to Celsius ===> C = (F - 32) * 5/9
Celsius to F ===> F = (C * 9/5) + 32
Oct 13, 2010 | Health & Beauty
How do you change the tempature reading for the air conditioner from Celsius to Farenheit?
You can switch the temperature mode between Fahrenheit to Celsius as follows:
While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit.
Feb 03, 2010 | 2004 Kia Optima
Qca Spas Paradise Hot Tub Logo
82 people viewed this question
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
