Question about Plumbing
How do i change a internal stop tap which is leaking that is connected t alcathene pipe, no sign of a external stop tap.
Look at pipe freeze kits but they say only for lead, copper pipes, tried to tighten the stop tap,
muttandjeff
  • 359 Answers
SOURCE: flexible copper water heater with washer leaks at cold inlet .
pipe dope not needed tighten snug then one quarter turn is recommended by most mfg
Posted on Dec 19, 2008
SOURCE: Bathtub water won't shut off
Did you solder close to the valve. you may have melted or damaged you cartrage inside. shut water off and replace it.
tborn6
  • 700 Answers
SOURCE: Ice forms on copper pipe under freezer off compressor
it sound like your unit has a bad sensor on it or a leak. you should never have to add refrigerant to a unit unless theres a leak then it has to be repaired firdt the recharged.
Posted on Jan 11, 2009
  • 234 Answers
SOURCE: Think I have pinhole leak in 1/2'' copper water pipe
What type of pipe are you looking at?If it is copper then you can fine someone to solder it.If it is plastic pipe with glue joints,then you get some glue call rain and shine,clean first then apply wait a few minutes.But turn the water first.
Posted on Mar 14, 2009
  • 659 Answers
SOURCE: Plumbing, gas pipes leaking
What you are doing is very hard to do without adding a union to the piping. There really isn't anything more you can do than what you already are doing. But if you have bubbled each joint and can't find anymore leaks then move to your valves. Also, flex lines have a tendency to leak as well. Like the ones that go to your water heater, stove/oven, furnace and small gas appliances. Check for the old style valves that don't meet code anymore like the valves with a bolt all the way through the valve. You will want to change them out to a ball valve. I hope this answers your question.
Posted on Apr 04, 2009
Water leaking
Check all external pipes, includeing the ones at top. If you find no pipeing leaks, the odds are, depending on age and waranty, you
have an internal tank leak and need to replace. There is virtually no way to fix that kind of leak.
Mar 28, 2015 | Water Water Heaters
My logik freezer wont freeze
Hi, the motor (compressor) is not working, or the gas is not circulating properly due to a blocked choke ( A much thicker short section of the piping housed at the back of the body) or the gas is leaking out, probably by now there is no more gas in the pipes. But first check to see and hear if the motor is working when switched on.If the motor does run, then it is definitely a gas circulation problem due to the two mentioned above facts. Only the repair man can help in any one of these circumstances
If there is a gas leak, then you will have to buy a new freezer.as present day modern freezers are too labor intensive to strip down to access the piping in order to repair an internal leak. If the leak is external then it is easily repairable.
Hope i have been of help
Good luck
Sep 10, 2014 | Logik LFC55W13 White 200 l Fridge Freezer...
My Bosch washing machine pumps the water out continuously without ever filling the tub. When I first start a load, the water moves through the detergent dispenser but never gets to the tub. About 5 minutes...
Could be time to call the electrician. If the freeze happened recently you are possibly further inland than me. Lagging on pipes often helps and wrapping external taps and pipes with towels or the likes for winter and with plastic tied over top if in the weather. After super cold frosts we are best not running showers and taps till midday or later occasionally. Vehicles can be similar if it is cold enough. Fill jugs and bottles the night before for breakfast if the water might freeze. If your water might be soon dirty because of a flood or water supply stopped, fill the bath with clean water before it is
Feb 28, 2014 | Washing Machines
What is the reason for losing water/
could be you have a leak in one of you hose,s
Dec 08, 2012 | Cars & Trucks
Broken water line or water heater, from winter freeze. When water is turned on tap water goes under the bunk bed area. Could this be the water heater or a hose in the area. We don't know the layout...
Depends on which tap you're turning ON. If it's cold water tap, it's probably a water line. If it's the hot water tap, it could also be a line. As heaters leak, whether the water tap is ON or NOT. Opening a tap valve doesn't cause the water heater to leak. The main question is, was the water heater's tank drained, before the Winter Freeze, when no one was using it? If it wasn't, there's a good chance the water heater will leak too
Hope this helps you solve the leaking water pipes problem. Please let me know Thanks.
Jun 15, 2011 | Heating & Cooling
1998 gmc yukon 4 wheel drive what does it mean when the number5 cylinder is misfiring and I changed the plug and the wire,just had a full tune up with coil and module,fuel filter! What could be the problem...
cHECK YOUR ANTI-FREEZE LEVELS IT IS PROBABLY LOW. These engine are famous for the in take manifold leaking internally and externally on cylinder # 3 & #5. This will cause the computer to give a misfire code. Tzop up your anti freeze and pressure test the cooling system I can gauruntee you lose pressure and it will be your intake gasket. You will have to replace it the gasket kit cost about $100.00 make sure you but the Fel Pro gasket kit it has been redevelope and made from steel rather than plastic. This will solve your problem and your truck will run much better as well.
Apr 25, 2011 | GMC Yukon Cars & Trucks
Losing coolant but can not see a leak
CHECK WATER PUMP AND GASKETS AND ALL OTHER EXTERNAL LEAKAGE
OTHER WISE LEAKING INTERNALLY TSB ON LEAK IN CYLINDER HEADS
Dec 08, 2010 | 2000 GMC Sierra
Leaking from what looks to be the water inlet connection...however we have changed the hose,including putting a sealant around where it connects, but it still leaks.
it could be that the nut on the pipe connection tap is leaking and not your pipe fitting try tighting the nut just a small amout do not over tighten as you will crush the copper pipe and it will leak more
Jan 16, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a 1990 gmc 1500 5 speed that is overheating and leaking coolant i changed the radiator hoses,thermostat, and water pump, and i know the leak is not coming from the radiator what do i do next?
any external leaks?coolant stains? would check the intake for signs of leakage also the heater hose quick connect.also check the sides of the block for leakage from the core plugs.
Jan 02, 2010 | 1990 GMC C1500
Noise at strart
The tapping, I think, from the limited information, is the Valves not getting the Oil due to low oil pressure. Once the engine warms up, and the Oil pump starts to flow the oil, the tapping stops. Many vehicles, do this. I would not be overly concerned about the tapping, but I would be concerned about the coolant leak. An easy way to see if you have an external leak is to go to a local parts store, and purchase a leak test kit, which usually is a dye, which can be seen with a blacklight. Take vehicle to repair facility and have a Carbon Block Test done
Nov 24, 2008 | 2005 Dodge Magnum
Plumbing Logo
87 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
