Question about Sony KDS-60A2000 60" HDTV
Power led flashes red 3 times
Just changed rear projection lamp. tried turning on and off. unplugging.
    Top Expert:
  • Sony Master
  • 74,459 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Jan 29, 2015
  • 38 Answers
SOURCE: Television won't turn on
If its a DLP tv chances are the bulb went out, double check with the manufacturer before getting as they are not cheap, around the $250 range.
Posted on Oct 26, 2007
ctf1800
  • 4402 Answers
SOURCE: Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Posted on Feb 26, 2008
SOURCE: Sony KDF-55xs955 TV will not turn on. Red LED flashes 6 times.
Where is therm fuse location
Posted on Jan 30, 2009
  • 86 Answers
SOURCE: Sony KDF 55WF655 rear Project tv Power/standby light flashing
This would be an error code indicating a problem.  You didn't mention if anything else was going on with the TV as in no picture, or no sound.  If the TV is operating just fine, there could be a bug in the software causing this.  If there is a problem, the best thing would be to contact Sony and relay that error message and go from there.
Posted on Mar 26, 2009
  • 1039 Answers
SOURCE: TV won't come on. Standby goes green,then goes red blinks 3 times
3 flashes means the lamp door is not on correctly or the lamp door switch is broken.
Posted on Apr 26, 2009
I have a LG rear protection tv. I believe 52sz8d-is. When I plug it in the red power led light comes on and the bulb led flashes green but it won't Turn on
Tries change the tv projection lamp.Tv projection lamp ben in the tv like 1 1/2 or 2 years already,tv watches daily 4 or 5 hours every day.Yes.Than the tv projection lamp life are ended,now tv require a new tv projection lamp replacement.
Jun 05, 2011 | LG RU-52SZ51D 52" Rear Projection...
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Grand wega kdf-55wf655, won't power on and led flashes 3 times
Make sure lamp cover is placed properly and securely after lamp replacement.
3 blinks of LED shows lamp door is still open or not closed properly.
Jul 04, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Mitsubishi WS 55809
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 15, 2008 | Mitsubishi WS-55809 55" Rear Projection...
TV turns off aftering powering up. red LED flashes 3 times.
3 red blinks means th lamp door in not on. if you have installed the lamp door corectly and it still does this solder all three pins together on the door switch.
Oct 08, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDS-60A2000 60" HDTV Logo
64 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
