Question about Uniden Cordless Phone
How do I change the display to make it brighter on my Uniden D1361 cordless phone?
New phone: Put battery in correctly, plugged phone to charger correctly, charger light lights up but display screen does not. Instructions say it should light up.
    Sergeant:
  • 284 Answers
There is a bulb behind the display it is for backlighting the lcd, likely it is burnt out or bad connection from the board
Posted on Dec 05, 2014
I got new uniden reveal 1260 cordless phone. It does not display any light on the screen. I am getting difficulty in reading the numbers. Is it normal not to have screen light in this set.
According to Uniden, the 1260 is a CORDED phone, not a cordless phone. It needs batteries AND it needs to be plugged into a telephone jack.
Nov 20, 2015 | Uniden Lands Phones
How do I RESET???? my Uniden cordless DECT 6.0 phone.?? It stopped working....not used a lot....only by one person
I think they meant to power the phone off. Remove the batteries for about one minute. Then put it in a working charger. It should find the base unit within two minutes.
Oct 14, 2014 | Uniden DECT 6.0 Cordless Telephone...
Batteries won't charge
There are a few reasons why a battery won't charge. Make sure that the contacts on the phone and the charging cradle are clean. (Unplug the base or charger.) A pencil eraser is good initial cleaner; electronic contact cleaner sprays are a second option. Remove the battery and check the contacts inside the handset and the battery as well. Next replace the battery pack. If you add a comment with your phone's model number, then I can try to find the correct battery. (Stores like Battery Mart may have a compatible battery.)
The final possible problem is that the charging system is bad. If your phone has multiple handsets, try a different charger. If the phone allows you to add handsets, try getting a new handset. The new handset will come with a new charger. (I've never seen the chargers sold without the handset but you could try Uniden customer service. If the base station is the only handset cradle, you'll probably need to replace the phone if a new battery and clean contacts don't work.
If your Uniden phone is under warranty, contact the company.
I hope this helps.
Jun 18, 2014 | Uniden DECT 6.0 Cordless Telephone...
Uniden cordless phone not working
Yr battery is probably Shot. With these type of batteries they can fall over if they go below 25% charge for a length of time. The charger is not charging even though it says it is. If the phone is not to old then get a new battery and try again. cheers
Sep 06, 2012 | Uniden Cordless Phone
My Uniden phone will not charge up, even when it is on the charger it says, set on charger, battery low.
First open the handset and disconnect the battery. Then reconnect the battery (just in case the connection is loose). Make sure that the battery is in the handset in the correct orientation.
How old is the battery in the handset? After a year (frequently), the battery must be replaced. This time includes the length of time the battery was in storage before you received it. If you add a comment with the model of the Uniden phone, I will be glad to provide additional information on the cost of the replacement.
If the battery is new, then the charger may have failed. (I have seen this with many rechargeable devices.) Make sure the contacts are clean. However you may need to replace the charger. Again I need the model number to check if additional handsets are still available for the phone.
If your phone is under warranty, contact Uniden for repair/replacement of either the battery or the charger, as needed. Start at http://www.uniden.com .
I hope this helps.
Oct 01, 2011 | Uniden Cordless Phone
My phone is display out of range
  1. hi..
  2. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
Jan 03, 2011 | Uniden Cordless Phone
My uniden cordless phone is not recharging, even tho i bought today a new battery at 17 dollars a pop at radio shack. the regular part of the phone unit with the answering machine on it works fine, help???
Your phone charger is shot. New batteries will not help if your battery heats up during charge or stays hot when left on charge. If the battery never gets warm and your charge light doesn't come on then it is a different problem. The phone manufacturer suggests you buy a new phone.
Sep 08, 2010 | Uniden Cordless Phone
2nd request: Model 27956 GE Cordless Handset with Picture Caller ID & Slide Show. Won't work after power outage. White & gray screen only. Disconnected and reconnected as advised by service call....
This fixed mine:
1/15/10
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
Sep 02, 2009 | Uniden Cordless Phone
you may check the replacement batt make sure it polarity is the same as the firt you if correct you may have to charge the on base for a few hrs if not checked the power source
Aug 08, 2007 | Uniden TRU8885 Cordless Phone
CORDLESS PHONE - NO DIAL TONE
Plug out the power from the main charger and then plug in again. It needs to reset after they have gone dead. Immediately you can lift one of them off the charger and you will hear your dial tone.
Apr 18, 2007 | Uniden DXAI5588-2 Cordless Phone
Uniden Cordless Phone Logo
90 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
