Question about Arrow Tools & Hardware - Others
Brand new Arrow T50 staple gun and using "Genuine Arrow staples" (JT21 - 10 mm). It will not work. When loading the staples they do not go in easily. Is there a way to loosen?
Used WD40 to lubricate the staple holding area. It helped but the gun still does not work. It's as if the staple track is too tight and it does not allow the staples to move forward.
  • 3,382 Answers
Take it back for a replacement!
Posted on Dec 05, 2014
Craftsman 68514
The replacement pack for this gun say the staples are compatible with "Craftsman 68514 and 68517; Arrow Brand T50 Staplers T50 and T55; and Stanley/Bostitch TR110 and BT110 staple guns", so I assume they are also backwards compatible. That's just an assumption though.
Mar 22, 2013 | Arrow Tools & Hardware - Others
T50 elite wont staple
I just bought a T50 elite, and it will NOT staple too.
Simple 3/8" staples loaded and nothing comes out.
Jan 31, 2012 | Arrow T50P ARROW STAPLE GUN
Just got an ET50red electric staple gun. Loaded Arrow T50 14 mm staples with the points facing up and out of the tool. When I pull the trigger, the led worklight comes on, I hear and feel the stapler...
remove the staples and check inside for a jammed one up there. squirt some oil in there. load it again and try. please follow the instructions to a tee. having the wrong staples or what ever can damage the unit, if it isn't already. good luck
Jul 31, 2011 | Arrow T50P ARROW STAPLE GUN
I need instructions on how to refill the Arrow T50 Staple Gun. I have the stapler and ran out of staples. I can't get the staples into the track.
remove the spring loaded magazine from bottom rear of unit by pushing down on piece about two inches below curve section of rear end of handle push down gently and pull to rear staples go in front ofin same slot from which this magazine is removed load normally two clips if your dead empty when you return the spring follower back into place it follows the staples if if doesnt go all the way in you probably have to many remove some good luckd
Mar 23, 2011 | Arrow T50 Staple Gun Tacker
The info on the gun says it will shoot many different staples, but it will only take 3/8 staples and I need to use 1/2 staples to do the job.
The T50P stapler uses T50 staples of various lengths, including 3/8, 7/16, and 1/2. Is it possible that the 1/2 inch staples you are trying to use are not T50? All T50 staples are the same width and should fit your stapler. There are several other widths of staples that are not T50, although T50 is the most common.
Nov 29, 2010 | Arrow T50P ARROW STAPLE GUN
Cannot find staples for this staple gun. The model I have just says PowerShot on the sides. I purchased some Black & Decker PowerShot heavy duty Staples for the gun but I cannot find anyway to get...
The ones you have are T-18 I believe
Fires 6 sizes of T50 type staples and drives 9/16 In. brad nails. Visual refill window and easy load chamber. Comfort grip.
•Uses Staples: PowerShot Staples, 97-010, 97-011, 97-012, 97-013, 97-014, 97-015, 97-030, 9/16 In.
•Brad nails
•Ceiltile 17/32 In., 9/16 In.
•T50 type staples, 505TML, 506TML, 508TML, 509, 50CT, 506SS, 504M, 505M, 506M, 508M, 509M, 504, 505, 506, 508, 509
•MFG Brand Name : Arrow Fastener
•MFG Model # : 5700
•MFG Part # : 5700
Aug 13, 2010 | Black & Decker 5700 Powershot Forward...
How do you load staples into the gun?
The staplesare NOT loaded on top of the pull out shaft; they are inserted directlyinto the slot that opens when you pull the shaft out. If the nose ofthe tool is not placed firmly against a surface, it will not fire.
CLICK HERE
and click the PDF icon on the right of the model # to start the download.
Here is a step by step:
Unplug the tool.
Squeeze the end of the shaft at the rear bottom of the tool and pullout the shaft.
Flip the tool over on it’s back.
Insert the staples,(points up) and then slide the shaft back in.
Plug it in, press the on button (under the the power cord in the back). Press the nose squarely against the material and press the trigger
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 07, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
My T50M Staple strips break up in the gun and jam after 4-5 staples. This happens with old staples (10+ years) and with new staples that were purchased two days ago. Out of frustration I purchased a new...
The staples are held together with an epoxy. I have used staples that are older than 10 years. The problem is the gun. Check for dirt or a burk in the magazine as well as a bent pusher blade. My gun also had a problem loosing a screw and nut that attached at the blade guide.
Jun 12, 2009 | Arrow T50P ARROW STAPLE GUN
Can't load staples
Fire the stapler with the load chamber open and down, see if anything falls out. Point it in different positions and fire it, just make sure it cannot fire anything at you.
Apr 18, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
My arrow fastener model t-50m is jammed how do I remove the few
I have a similar issue with my T50m stapler. To remove the staples unscrew the locking nut near where you load the staples and remove the tapppered bolt. The track will lift out and the staples can be easily removed. Why this is happening is unknown to me also. I purchased a new gun.
Feb 14, 2009 | Arrow Fastener 509 9/16" T50 Staples
Tools & Hardware - Others Logo
375 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
