Question about Samsung Cell Phones
On my Samsung tracfone my alarm only went silent does not even vibrate but when you set the alarm you can see it working ???
I looked for alarm mute can not find it
My Samsung Galaxy Light won't vibrate anymore. How can I fix it or get it to work again. Thank you
Setup the Vibration
This option allows you to set your device to vibrate and ring.
1. From the main Settings page, tap My device tab ?
Sound.
2. Tap Vibrations.
3. Select a vibration pattern and tap OK.
- or -
Tap Create to then use an on-screen touch circle to
create your own custom vibration pattern. Tap Save to
store the new vibration pattern.
Sound Settings
From this menu you can control the sounds on the phone as
well as configure the display settings.
 From the Home screen, press and then tap
Settings ? (My device tab) ? Sound.
The following options display:
Silent mode via Device Options Screen
Silent mode is convenient when you wish to stop the phone
from making noise, in a theater for example. In Silent Mode
the speaker is muted and the phone only vibrates to notify
you of incoming calls, or other functions that normally have a
defined tone or sound as an alert.
1. From the Home screen, press and hold
(Power/End) until the Device options screen displays.
2. Tap either Mute, Vibrate, or Sound from the Device
options screen to activate or deactivate these features
(the current mode displays).
You can download the User manual from the site below
https://support.t-mobile.com/docs/DOC-9140
Feb 07, 2015 | Samsung Cell Phones
How do i turn off the alarm on my Samsung galaxy mini
Go to Settings > SOUND > Silent mode (No sounds except media and alarms).
If this is ticked (on), it means alarm will sound even if you make the phone silent.
Regarding the loud sound even after reducing ringer volume, no idea for this.
Oct 31, 2011 | Samsung Galaxy S GTI9000 Smartphone
I have already put my phone on ' Silent All ' but for some reason it keeps vibrating, I have also, went to the settings and changed it to ' Silent All ' but it still keeps vibrating and i need to turn it...
Possible there is software or a hardware issue on the phone. To start with remove off the battery and keep aside for about 30 minutes.Put back the battey and restore the phone to factory settings by using the restore key and the default code of your phone.
If the phone is now set to mute the ring and vibration and if this works we have achieved the goal.
But if the fault remains, it can be a fault of the vibrating motor shorting without a control
The last resort is to reinstall the software to clear any errors in the software.
Helpful?
Aug 29, 2010 | Cell Phones
Even on silent, it vibrates. i want to stop vibration. this is samsung impression
1) go to menu
2) settings
3) sound profile
4) tap silent
5) tap on call alert type and choose mute and then tap on save.
6) then save.
Nov 02, 2009 | Samsung SGH-A877 Impression Cell Phone
Incoming calls on mute and vibrate cannot get ring tone on
go into settings, fone profile , check its not on silent if not go into edit on the normal profile then look throu all the settings
Sep 22, 2009 | O2 Samsung SGH-E250 Cellular Phone
My Sony Ericsson W890i, I cant set the alarm with a vibrate tone?
You go to:
main menu->settings->sounds & alerts (or something like that)-> vibrating alert
Open this and you will find 3 choises (on,on if silent, off). Choose "ON".
Then vibrating alert will be always turned ON,even if You putt it on "silent".
Sep 05, 2009 | Sony Ericsson W890i Cellular Phone
Silent profile alarm Nokia E71
go to profile activate silent mode in the settings alarm mode vibrating
Jul 15, 2009 | Nokia E71 Smartphone
Having alarm clock sound even in vibrate mode
It is not possible to sound alarm in vibrate mode, but by going into master volume and setting it to sound alarm only, the alarm sounds in silent mode.
Jan 10, 2009 | LG Cell Phones
I have a new LG200C cell phone that has been activated with TRACFONE. Problem: when dialing the LG200C from another phone, the the ringer is completely silent, even though I have put all volume settings on...
try pressing the * key for about 2 seconds (until it vibrates or beeps) that toggles between the normal ring settings and "manner mode" which is vibrate
then check menu - settings - sounds - volume
select Master volume and make sure it is not on silent
Sep 28, 2008 | LG Cell Phones
How do i yurn my fone off silent
go to tone setting-alert function-select ring only.
Jun 10, 2008 | Samsung SGH-D600 Cellular Phone
Cell Phones Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
