Question about Ricoh MP-301SPF Copier : MP301
How do I stop one side of a paper from being copied on both sides?
We looked at the manual and tried to use the menu on the copier to help. Nothing has worked.
  • Ricoh Master
  • 5,499 Answers
Press other function, then press combine, then print
Posted on Dec 05, 2014
Epson repair manuals for DX6500
hi you should check the paper path should be clear nothing struck in side the paper path
Jul 14, 2014 | Office Equipment & Supplies
Canon imageclass mf6590 sucks paper back in when printing/copying even though all 2-sided print/copy settings are turned off. Can't make it stop.
You can try to put it back to factory setting's under user mode.
Press MENU and #, select clear and all, press OK.
Now the machine is back to the original state.
NOTE: after clear all you need to enter all your settings that you had before
Hope that helps!
Mar 23, 2011 | Canon imageCLASS MF6590 Copier
I get a paper jam every time I try to manually make a copy on the second side of a copy. First side no jam. Help. Derek
hai,
Open the leftside lower cover (below the dlivery door).
i think duplex revesing area have old copied papers. if have remove it, then
Check the paper passing rollers dirt or demage, clean it, hold properly
then clean the sensor of paper reversed area.
best of luck
May 23, 2010 | Canon imageRUNNER 400S Copier
Canon ir3320 problem is a 2 side copy command after 1 side print ok 2nd side pcopy is a lite
If one side looks great and the second side is faded try loading fresh paper in the copier. Sounds like there is moisture in your paper. It dries out after going thru the fuser section on the first pass so on the second side the paper is dry and the copy will look alot better.
May 11, 2010 | Canon imageRUNNER C3200 Copier
The paper is not feeding properly on my printer.As it advances the paper crumples or tilts at an angle and then just stops. A paper jam message appears. Solution Attempts. 1. I turn the machine...
Most of Lexmark printers (including the Z- and X- series) pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print the self test page.
Please follow the steps given below to perform the self-test:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper jams to sides on x5470
Most of the Lexmark printers (including the Z- and X- series) pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
Apr 13, 2009 | Lexmark X75 All-In-One InkJet Printer
I do not know to copy on both sides of the paper, can you help?
I don't think the HP Officejet 5780 have the capacity automatic for double side copy.
nothing in the printer specification have the double side copy listed.
what you can do is copy one side and trun the paper over and copy the other side.
Dec 09, 2008 | HP Officejet J5780 All-In-One InkJet...
How to use
Does the copier have a duplexer? Automatic 2-sided copying (duplexing) was an optional feature for the EP2030. If there is a drawer in the lower section of the copier labeled "duplex" then your unit has this feature.
To use it, simply select 1>2 (for single-sided originals) or 2>2 (for 2-sided originals) on the "Orig>Copy" section of the control panel (toward the left side).
If your copier is not equipped with a duplexer, the only way you can make 2-sided copies is to copy the first side and then load the copies back into the paper tray or the manual bypass on the right side of the unit.
Note the the copier copies on the bottom side of paper fed from the paper trays, and the top side of paper fed from the manual bypass.
You can download a .pdf file of an operator's manual for this copier from the Konica Minolta website.
Oct 22, 2008 | Minolta EP1030/1030F CS/PRO Copier
Cannot copy Double-sided
Q1- What make and model of copier are you using? Q2- Which document feeder are you using?
Sep 26, 2007 | Office Equipment & Supplies
Ricoh MP-301SPF Copier : MP301 Logo
64 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
