Question about GE Ovens
Ge Model Number JPK27WOW1WW - Flashing F3
When I try 2 start the oven or broiler it Flashes F3. What does that mean?
  • GE Master
  • 842 Answers
Please confirm your model number as I only find a JKP27WW1WW.
Thanks
Posted on Dec 06, 2014
Testimonial: "This is Exactly what is on the Information Plaque... GE Electric Double Wall Oven… UL LISTED HOUSEHOLD USE GENERAL(GE)ELECTRIC 371 G LOUISVILLE, KY 40225 M DEL NO COLOR SEREAL NO J KP27WOW1 WW TR6022240 U.L. FILE NO. KW 7.1 5.8 E 3702 0 120/240V 120/208 VPN PTL-135-3 OUTSIDE DIMENTIONS: 24” W x 19” H INSIDE DIMENTIONS: 19” W x 15” H x 18” D"
I have a magic chef electric wall oven and it flashes an error code of F3 when I try to bake something. How do I fix it and what does it mean?
The F3 code means that the temperature sensor in the oven is not giving the signal to the oven control. This could be the result of a problem with the wiring or the wire harness between the control board and the sensor or indicate that the sensor itself has failed.
To identify the correct parts, you need to provide your oven model number. Try here: http://www.partselect.com/Magic-Chef-Parts.htm . There are other sources for parts.
I hope this helps. If you add a comment with the model number, I'll be glad to give you more specific information for your wall oven.
Sep 25, 2011 | Magic Chef Ovens
GE Wall Oven JTP 10GP F3 code when I turn it on it goes straigt to F3
on our maytag a f3 code means shorted or open temperature sensor. do not know if that code is the same as a ge, but you can google your oven model codes and find out what the problem is.
Jun 21, 2010 | GE Profile JTP18 Electric Single Oven
GE Double oven flashing F2
The f2 code means that the oven temp sencer needs to be replaced.
Sep 10, 2009 | GE Profile JTP56 Electric Double Oven
F3 code flashing
Replace your oven temperature sensor.
F-3 bad sensor.
Feb 02, 2009 | GE Profile JTP18 Electric Single Oven
F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Mar 04, 2007 | GE JTP15 Electric Single Oven
F3 code
It's your oven temperature sensor. It's a thin metal stick that juts into the oven. It is located on the upper right back wall of the oven cavity. Flip your breaker, slide out the oven. You install it from the back, very simple, two screws, i think. I'm a beginner at DIY and had no problem fixing it.
Feb 23, 2007 | GE Profile JK915 Electric Single Oven
GE Profile-electric oven
Copper, F3 means oven temp sensor is open. You need to replace the probe. Easy job. Part number I have for this is WB23X5340, but double check your model number. Look it up on the net to see what you are going after...Catriver..post back
Sep 19, 2006 | GE Profile JTP18 Electric Single Oven
Ovens Logo
97 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
