Question about Rockworth RW1503TP 3-Gallon Factory Reconditioned Trim Finish Electric Air Compressor
Need gasket - Rockworth RW1503TP 3-Gallon Factory Reconditioned Trim Finish Electric Air Compressor
  • 3,368 Answers
Great Question, I have a feeling there is more then one gasket in your unit, you might want to give more info so somebody can help you such as what gasket.
Posted on Dec 05, 2014
How do I change the thermostat on a 1996 chevy cavalier
You will need a socket or wrench set to take the small bolts out of the thermostat, You need to have something to catch any antifreeze in the heater hose as you remove usually the top heater hose. You will need a new thermostat and some gasket sealer. You might need to remove the old gasket sometimes they stick BUT BE CAREFUL do not grove the gasket area. Use a gasket scraper to remove old gasket, if you don't have one you can use a straight blade to remove it JUST BE CAREFUL not to grove housing. Put gasket sealer on one side of gasket and place on thermostat housing let dry 5 minutes. Then use sealer on the top of gasket and place thermostat on gasket let dry 20 min. Replace bolts in thermostat and replace heater hose then start car and check to see if you need to add antifreeze if you lost any. Hope that helps
Jan 02, 2014 | 1996-2002 Chevy Cavalier Thermostat...
Need replacement door gasket on fridge/co. no longer makes them
Jeanne,
If this is a commercial refrigeration unit we offer a custom made gasket option. It's a simple process at coolergaskets.com
Step 1: visit our custom made gaskets page HERE and identify the gasket profile material that best matches your existing gaskets.
Note: If you have a hard time with this we offer a $1 gasket sample ring.
Step 2: Input the outside edge dimensions you need your gasket to be (length and width) and how many sides it has (3 sided gaskets are most common for walk-in coolers/freezers, You will want precise measurements. Here's our "How to measure your gasket" video.
Step 3: Select the quantity you want and add that gasket to your cart where you will be able to proceed to check out there. Then relax because your gasket is in good hands!
Dec 11, 2013 | managemylife.com Computers & Internet
Changing thermostat v6
drain coolant until its below the thermostat.then remove two thermostat housing bolts.remove thermostat housing and thermostat.make note position of thermostat before removing it.then carefully clean all old gasket material from thermostat housing and cylinder block you can buy can gasket remover at any auto parts stores.buy new thermostat gasket.if you have the paper type you need to buy RTV SILICONE to help seal gasket if you have rubber type gasket you dont need RTV SILICONE.make sure both surfaces are clean.then install new thermostat and new gasket.if you have paper type gasket apply thin 1/16 coat RTV SILICONE both sides thermostat gasket.then install gasket to thermostat housing then install housing to cylinder block first make sure new thermostat in place before installing thermostat housing. let RTV silicone sit up about hour before adding coolant.IF THERMOSTAT HAS THE O RING SEAL DONT NEED RTV SILICONE AND THE PAPER GASKET.
Jul 01, 2013 | Mercury Sable Cars & Trucks
Model# RT18DKXEW05 parts
Repair clinic has booth door gaskets
the refrigerator gasket is $91.60
The freezer door gasket is $72.95
If the unit is working good it might be worth it to replace the gaskets if unit is in good shape and you only need one of the 2 gaskets I would replace it. if needs both you need to see what a replacement unit costs and make a decision
http://www.repairclinic.com/Roper-Refrigerator-Model-RT18DKXEW05-ID-114014-Gasket-Seal-Parts
Jan 29, 2013 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
What gaskets do I need to replace when doing a head gasket
The routine gaskets are included in a "head gasket set". this would include new valve seals as well12_30_2011_6_48_15_pm.jpg
Dec 30, 2011 | 1994 Ford Aspire
What gaskets do I need besides my head gasket when replacing the head gasket on a 2004 Ford Taurus, in otherwords what would replace while doing this job car has 168000 kms
Head bolts and head gaskets. Let's see, you will need a lower and upper intake set as well. These head gaskets usually blew because bad fan relays caused the gaskets to blow and warped the heads. Ford used cheap oil pressure switches that leaked as well.
Mar 22, 2011 | 2004 Ford Taurus
Hey everyone. I have another issue with my 84 2.8 liter s10. Major problem the head gasket blew and i need to replace it. I know that I need to replace the intake manifold gasket, valve cover gaskets, and...
Here is a PDF file of the procedure to removal and install the cylinder head gasket:
http://www.qfpost.com/download.do?get=7a3aa7185772e86bc716780771f1941d
Mar 16, 2011 | 1984 Chevrolet S-10
Can i just replace the head gaskets or do i need to replace alll gaskets
when u replace the head gaskets u must also replace any parts gasket that u remove (valve covers, intake manifold etc.) to get the heads off, they sell what is called a "Valve Grind" gasket set that is what u need, it will have all the gaskets in it u need..
May 27, 2010 | 1991 Buick Century
Do i need any gooop when i change the vavle cover gasket
should not need any on these because the gaskets for the valve covers on these are more like a rubber oring and a regular gasket they are self sealing.
Aug 28, 2009 | 1996 Dodge Stratus
All Engine Gaskets leaking oil. Suspect Brake fluid added to oil resevoir. 2002 pontiac sunfire motor 2200. Can I replace gaskets and what gaskets do i need
Well If you did happen to get Brake fluid in your Engine some how. The gaskets you would need would be the valve cover gasket, head gasket,Header gasket, Waterpump gasked, Front and rear main seals,and Thermostat gasket.
Jul 14, 2009 | 2002 Pontiac Sunfire
Rockworth RW1503TP 3-Gallon Factory Reconditioned Trim Finish Electric Air Compressor Logo
70 people viewed this question
Top Rockworth Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Rockworth Air Tool and Compressor Expert? Answer questions, earn points and help others
