How do i get rid of two horizontal black lines at the bottom of my screen?
Ive tryed the buffer board,and cleaned it still the same
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Dec 05, 2014
How to fix Black Horizontal Line on Samsung Plasma TV (PN60F8500)
It is possible that the buffer board will fix your problem, but try removing, cleaning and reseating the flex cables between the buffers and the panel first. All it takes is a little bit of dirt or oxidation to open a connection and cause a line-out condition. Use a lint free cloth and a little bit of alcohol to clean them. Make sure to fully insert the cables and center them perfectly in the connectors or you will have even more lines. If the original line is still there after cleaning, then try replacing the board. Buy a board from a reputable dealer that will guarantee no problems with the board. If you still have the line even after changing the board, then the plasma panel has failed and the only fix is to replace the panel.
Always let the tv set for an hour unplugged before attempting any repair work. There are dangerously high voltages in plasma tvs that can cause severe shocks or even *****.
Feb 07, 2017 | Samsung PN60F8500 60" 8500 Series Full HD...
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Black horizontal lines on screen on my p50h401a plasma tv after replacing upper buffer board
Hello, the problem is with the buffer board ribbon cable. You have to really force them in there till you see no more lines, then close the latches in place "try using both hands" and press into the board HARD :)
Jan 16, 2014 | Hitachi P50H401 50 in. Plasma HDTV
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
Apr 01, 2009 | JVC PD-42DX6 42 in. Plasma Television
Screen Problem
hi....Your tv picture is managed by several boards, the two specific ones are the ysus and the xsus. The Y controlls the horizontal pixelation and the X the verticle, if you are having horizontal problems then its the Ysus thats faulty, on this particular set, the Ysus board has two accompaning buffers that are particularly troublesome. I've had more than one of these sets in the shop recently with the same ailment.Sounds like your buffers are starting to go out. The screen is split horizontally by the two long skinny buffers attatched to the Y main, if the bottom one has one leg in the grave you'll be getting a partially black screen or no picture at all. The colored lines running through the screen are more typical of a failing buffer. Are you interested in taking this set apart and putting a couple hundred into fixing it?  When buffers go they usually take the Y main too. Worse case scenario you're gonna be out about $350 dollars to fix it yourself. Best case, a ribbon is loose on the bottom buffer and with a dismantle you'll be able to connect it again..
thank u rate me!!
Feb 12, 2009 | Philips 42PF9630A 42 in. Plasma Television
The lower half of the screen goes black,with a whack to the left side of the unit,the picture comes back.Also, the top 4 inches of the screen continues to have colored lines running across it,which will...
Sounds like your buffers are starting to go out. The screen is split horizontally by the two long skinny buffers attatched to the Y main, if the bottom one has one leg in the grave you'll be getting a partially black screen or no picture at all. The colored lines running through the screen are more typical of a failing buffer. Are you interested in taking this set apart and putting a couple hundred into fixing it? If so, comment and I'll post pictures of the dismantle and the buffers you're likely going to have to replace. I can also recommend where to get them but this fix isn't cheap. When buffers go they usually take the Y main too. Worse case scenario you're gonna be out about $350 dollars to fix it yourself. Best case, a ribbon is loose on the bottom buffer and with a dismantle you'll be able to connect it again, but seriously, when in life has the answer ever been the best case scenario? Maybe your luck is better than mine.
Jan 31, 2009 | Philips 42PF9630A 42 in. Plasma Television
Samsung HPR4252 with red horizontal lines accross the screen
I just had my HP-R4252 repaired on 12.05.09 with a similar problem. The picture is covered in horizonal, broken lines and the color is predominately red. They lines are grouped together in large bands across the screen.
The tech replaced the Y-Buffer boards (Up) and (Low) in about 20 minutes.
Samsung BN96-02034A BOARD, Y BUFFER UPPER ASSY
Samsung BN96-02216A BOARD, Y LOWER BUFFER ASSY
Feb 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
