M/s my problem is one micro chip number pic18f8720 pierces but not in the software bill t in i am major problem plies prwedit software
To the product uk
    Top Expert:
  • Computers & ... Master
  • 22,107 Answers
Please use English not text speak. Thank you
Posted on Dec 05, 2014
What can i do if i do not know my invoice number
It should be on your bill, if not I would try asking the company you are involved with.
If you are the one billing, you get to make it up.
Nov 12, 2015 | Computers & Internet
Port my home phone number 7042790149
Not all telephone numbers are portable. Usually the only numbers that can be "ported" are those the presently belong to one of the major landline carriers, in other words, your local exchange carrier. Look at your phone bill... if there is a charge on your present phone bill for number portability, then you can port it. Otherwise (as a general rule) you can't. A phone number that you originally obtained from some online service or non-major phone company or cell company often are not portable. Also only FYI it's not a really good idea to post your phone number (above) on the internet as you can wind up receiving a bunch of weird callers. Good luck with the return.
Dec 26, 2014 | Computers & Internet
How do i remove write-protection from a micro chip
If the micro chip is a rom then you can not remove it. If the chip is a flash then you can. I need to know more about the chip ie number on the chip to see how it is done. The number on the chip will tell you if it is a eprom flash rom controller, basically what kind of chip it is and its function.
Apr 03, 2014 | Dell Computers & Internet
The cam snapped in half. on my 1994 ply. acclaim. and there is only fifty lb's of compression in #1 cylinder, and a major leak in cylinder # 2.
With the cam in 2 pieces it is a sure bet that the half that is not moving will have bent valves from the piston hitting them. It likes a head off for valve replacement
Feb 27, 2013 | 1994 Plymouth Acclaim
I have Intel E210882 motherboard.Which is the chipset?
http://www.amazon.com/Intel-Desktop-Board-D845PEBT2-E210882/dp/B009B5L0OA/ref=sr_1_3?ie=UTF8&qid=1353781789&sr=8-3&keywords=intel+e210882
http://www.intel.com/support/motherboards/desktop/d845pebt2/sb/cs-012740.htm
Click on Product Specification (PDF)
Product Guide (PDF)
http://downloadmirror.intel.com/15337/eng/D845PEBT2_ProductGuide_English01.pdf
The motherboard chipset is an Intel 845PE.
Intel part number - Intel 82845PE - on Northbridge chip;
Intel part number - Intel 82801DB on the Southbridge chip,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
The Northbridge chip is under the tall aluminum finned Heatsink, that sits between the processor socket, and the bottom of the motherboard.
The Southbridge chip, Intel 82801DB, sits down towards the bottom of the motherboard.
For additional questions please deposit $30,000 in unmarked bills......................OH, I'M JUST KIDDING!
Post in a Comment.
Regards,
joecoolvette
Nov 24, 2012 | Intel Motherboard
How to change a 4 ply wool pattern to 8 ply
INCORRECT PRODUCT CATEGORY
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category This is the car and truck problem category
Jun 29, 2012 | Cars & Trucks
How do I apply refrigerant?
******This is for educational purposes only. Handling, recovery and installation of refrigerant should be done by experienced, licensed technicians.******
The first thing you want to do is very that the problem you are having is caused by failure in the sealed system or something else. There are a multitude of checks you can do but we'll take the fast track.
1) Confirm that the compressor is running. Usually when the machine is low on freon, the compressor will run but not generate a lot of heat.
2) Remove the rear wall of the freezer and check the evaporator coils. If the coils are mostly aluminum, with a small section of frost or ice, then you have a freon issue, if completely covered in frost or ice, stop this route and diagnose for defrost issues.
3) Verify all fans are running, coils are clean.
Okay, if your check list all check good, then move forward with the sealed system diagnosis. The tools you'll need for checking are as follows:
1) HVAC guages, not automotive.
2) A piercing valve, some machines have an access port already, but most don't. I use a bpv-31.
WIth the machine running, locate the suction line coming from the compressor, it will be the bigger of the two. The smaller line is called a discharge line and is part of the high side of the freon loop. DO NOT MESS WITH THIS LINE. Once located, install the piercing valve, pierce the line, attach your gauge using the blue line, and open the valve. You'll now be able to see the pressure in the machine. You'll notice the outside numbers on the blue gauge, most in blue, the lower portion in green going to 30. The green means a vacuum. Your freon level should be anywhere between 5 and 10 on the blue side.
If your number is in the blue but way past 10 with the compressor running you have a restriction and you should stop and call a tech.
If your number is in the blue but below 5, you may have a micro leak.
If your in the green, the machine is in a vacuum and has a significant leak.
********* Note that knowingly adding freon to a machine with a leak without first repairing the leak is a federal offense, and carries a major fine, like $25,000.*******
Now, lets say the machine is in a vacuum, like at -10, or 10 in the green, we'll go to the next steps. If your gauges read like 30 in the green stop because thats a major leak. The tools you'll need for the repair are as listed:
1) Gauges
2) valve (already installed)
3) vacuum/recovery pump
4) freon
5) Freon can piercing tool since your only going to be able to but the small cans without epa certification.
6) recovery bag
Okay, turn the machine off. Leave the gauges connected and connect the yellow line to the recovery pump, with the pump connected to recovery bag. Turn on and open manifold (gauges) valve and vacuum all the old Freon out of the machine. Let the pump run for about 30 minutes.
Next, close the manifold valve, then turn the pump off. The needle on the gauges should be at 30 in green and not move. If for any reason the needle moves upward toward the 0 then you have a major hole somewhere and it has to be sealed.
If the vacuum holds, take the yellow hose off the pump, pierce the Freon can with the clamp (tool) and connect yellow hose to it. You'll want to unscrew the yellow hose at the manifold for a brief second to vent the air out, leaving only Freon. You don't want any moisture in the sealed system.
Now this is the part where you should have Freon scales, or a graduated cylinder to measure the amount of Freon. On the sticker on the inside of the machine, you'll see the amount that goes in the machine. Most cans are 10 oz . Most machines don't use that much, and over charging a machine will cause it not to cool.
Add your Freon by opening the manifold valve, and be sure the piercing valve is open as well. Get as close to the amount as possible. When done, close the manifold and watch the pressure to make sure it stabilizes and doesn't drop down. With the machine off it will be pretty high.
Plug the machine in and leave the gauges connected and watch the pressure on the gauge, it will drop, your concern is that the needle finally rest between 5 -10 in the blue.
If this is the case, Close the piercing valve, remove the gauges and your done.
******* Remember this a short hand version of Freon installation. This is nothing compared to actually having the right equipment, training and experience.
Jun 22, 2012 | Refrigerators
What is the product key for microsoft office 2003
Hi, The product key is YOUR 25 digit set of keys for YOUR unique installation of the Office package. No one else should have these numbers, except the software owner. If you're having trouble installing and activating your copy, then check your source where you acquired the software.
Thanks, Bill
Sep 08, 2010 | Microsoft Office Word 2003 for PC
I AM LOOKING FOR A CD RE-WRITE DRIVE FOR A COMPAQ EVO MICRO DESKTOP PC, PART NUMBER 250105-001
If you're looking to buy one of these, you could select any one of these online stores and buy it using a major credit card:
http://www.google.com/products?q=250105-001
Thanks!
Jul 19, 2008 | Computers & Internet
T.V.
Valerie,
That is a M134C chassis - one of the most inexpensive (throw-away) chassis ever built and the so-called v-chip is actaully a function of the micro, short for micro controller Ic. It would be less expensive to replace the entire board, RCA p/n# 268733 which is around $70.00 bucks plus shipping, than to replace just the micro.
You can find them available at Vance Baldwin... Just login as guest and enter thr RCA part number above and order it there.
Putting in an entire chassis is a plug-n-play repair...
Hope this helps.
Bill
Feb 11, 2008 | RCA TruFlat 27F520T 27" TV
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
