Question about Garden
I need a replacement power cord for the Worx series electrical snow blowser. kc
The Electrical Cord for my Worx Snowblower has been damaged due to wear. i am trying to find a replacement... for the entire Cord. Not sure to start... because I can not find a replacement parts list, or a manual on construction.
  • Garden Master
  • 2,478 Answers
FIND A NEW CORD, SAME 3 OR 4 WIRE. 12, 16 SIZE. PUT NEW WIRES ON SAME TERMALS
Posted on Dec 06, 2014
  • Bob Miller
    Bob Miller Dec 06, 2014
    I was THINKING of that..I am in Ohio.. and ILL work on it this weekend and let you know how it works.
wilsodfarm
  • 986 Answers
SOURCE: Seems to be an electrical part at the bottom of
remove that bowl off and clean that jet with a small paper clip
Posted on Jul 28, 2009
Testimonial: "Was extremely helpful!!!!"
  • 78 Answers
SOURCE: need manual for craftsman snowblower 42 or parts below
Ok
That Snowblower is made by Agri- Fab for Sears/Craftsman .If you go online to the agri-Fab website it is possible to down load the manual or if you email them they will send you a copy. I have dealt with them.They have even sent me missing parts. GOOD LUCK
Mike
Posted on Oct 22, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a MTD 600 series riding lawnmower. I
http://manuals.mtdproducts.com/mtd/public/list.jsp
above link needs model and serial number or
http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1
above link for parts breakdown
Posted on Nov 12, 2009
mickey813
  • 472 Answers
SOURCE: riding mower snow plow
go to manuals online put in model number off the snow plow and it will show you the manual
Posted on Feb 12, 2010
  • 61 Answers
SOURCE: I need parts manual for MTD Snow King Snowblower
on the internet try
mtd.com/manuals
Posted on May 29, 2010
MTD Mastercraft Snow King Snowblower (1997) electric starter stopped operating today (during a snow storm of course). Any ideas? Thanks. Checked cord - good condition. Power to the chord. David
It was running and stopped while using or it worked one day but not the next?
The Machine stopped running or just the electric starter? If just starter check to see if snow/ice built up around starter button.
Jan 06, 2017 | Garden
Brand new snowblower. Engine will not start
Stuck? you mean if you try to use the pull starter the engine will not let you pull the cord out?
Will it not start OR is the engine frozen. help us with your description
Take the Spark Plug out and see if that helps it turn over. Maybe the float in the Carburetor is stuck open and the cylinder filled with gas Causing Hydrolock.
Dec 19, 2015 | Craftsman Snow Blower / Snowblower Bottom...
The ground broke off of the electric starter of my troy-bilt storm 2480 snow blower. Is there a way to fix it other than buying the $230 dollar replacement part?
You could just connect it as usual but provide a wire with an alligator clip on one end and the other end connected to the bare ground wires in the outlet box whenever you need to start the snowblower. An alternative ground location that is often easier for homeowners to access is to connect it to a cold water copper pipe, the external, visible ground point near the electric service, water main, cable TV, telephone, etc. Some states permit iron gas lines to serve as ground too. Check with your wiring inspector or local electrician to see what is acceptable in your town. Whichever way you choose to access ground, add this wire without disconnecting any of the others.
Once you have it wired up, the procedure is pretty simple really - you would first connect the alligator clip end of the ground wire to an unpainted, solid part of the snowblower's engine, starter motor or frame. Then plug in the power cord the way you did before the ground was broke off (orient the cord / plug as if the ground were still present). Press and hold the start button as usual until it starts. Once running, remove the 120 volt power cord first - then disconnect the grounded alligator clip. The ground clip must always be first on - last off. This way, at no time is the snowblower ungrounded when it is connected to 120 volts.
Of course, some folks will say you don't have to have a ground connected. True, it will work / start without the ground wire - but you do give up a bit of safety by ignoring it. The ground is to protect people from electrical faults - its presence does NOT effect the ability of the starter to function. I wouldn't dream of spending $230 to replace the starter just because it is missing ground wire (because it is so easy to get around the problem with my simple little fix) but I would only start it w/o the grounded alligator clip wire if I had too. For maximum protection, you should be connecting the snowblower to a ground fault protected outlet when using the electric start regardless of whether or not you're using the ground wire alligator clip.
Jan 07, 2014 | Troy-Bilt Storm 2840 277cc 28-in Two-Stage...
How to start my snowblower model #247 886911
check gas and oil
put full thottle
full choke
prime 3 times
pull cord or electric start
repeat if doesnt start
Dec 25, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Damaged power cord on worx wg303 chain saw
I would just go to wal mart and get a new plug and put it on what is left of the wire shouldn't cost over $2.00 and a little time
Oct 21, 2012 | Worx (16") 3.5 HP Electric Chain Saw -...
Where can I find a electric cord for the worx trivac wg502
i would buy a extension cord and cut off the other end why not you always need a cord to use it anyway
Aug 01, 2012 | Worx Trivac Wg500 12amp Allinone Leaf...
The lead on our machine is becoming frayed - is it possible to replace the lead and if so, how is it achieved? John Tuffley
If you are refering to the Electrical Power Cord? Yes, this can be easily replaced or repaired.
Depending upon where the cord is damaged, you can either cut it a little shorter and install a replacement electrical plug end (available at any electrical parts store (Lowes, Home Depot, Radio Shack, etc) for about $2.50.
Or if the cord is damaged near the vacuum, you can purchase another cord or even make up one yourself how ever long you want it within reason.
Jun 15, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
My Tecumseh Snow King 8HP snowblower won't start. I need to know how to start it with an electrical cord.
In order to start it with an electric cord you must have a feature called an electric starter. If you dont have the electric starter on your machine now, one can be added at a dealership
Jan 13, 2009 | Vacuums
Hp photosmart c4580 won't print
Your problem indicates that your printer is not getting the power supply .
  • Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
  • If the power cord is not damaged, plug the power cord into a different electrical outlet without using a surge protector. The product power light should turn on.
  • If the product power light does not turn on, the power cord should be replaced.
Dec 09, 2008 | Office Equipment & Supplies
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
