Question about Tivax LSS-505 Model Michley Lil Sew & Sew Portable Sewing Machine, Double thread, double speed, Featuring 8 built-in stitch pattterns, Forward and reverse sewing, Automatic thread rewind, Sews sleeves, Drawer included, Use hand switch or foot pedal to star
Where to buy small spools of thread used by this machine?
Spool that will fit on spindle, but spindle is not long enough for the disk to fit snugly enough to stabilize the spool.
  • Tivax Master
  • 1,860 Answers
You should be able to get small spools of thread at Walmart, hancock fabric, ebay.. some people who have the small sewing machines use what is called a thread stand, when the spool will not fit on the spool pin, I use a thread stand myself. I'll put a link so you can see what I'm talking about.
1 058results for thread stand
Posted on Dec 09, 2014
  • 24 Answers
Ok . . . . I see what you mean, very difficult to find, but my wife (pro seamstress) says you should be able to thread the spool in a similar fashion as you would a bobbin
Is the Bernina Activa 140 equipped to use a double needle?
Berninas can use double or triple needles, just be sure the needle is set in the center position and the stitch width is set to zero. If your machine does not have dual spool pins, you can put one spool in a drinking glass on the table behind the sewing machine. You can also probably fashion a spool holder out of a small dowel on a base or even find a standalone spool holder. Instead of using two thread spools, some people will use a thread spool and load thread on a bobbin and put both on the spool pin.
Be sure to thread each separately so the two threads do not become twisted. Your machine may also have dual tension disks, so each thread should be separated when going through the tension unit.
Mar 19, 2018 | Bernina Sewing Machines
How come spindle is so short to put spool thread on
Is it the spindle for the top thread or is it the spindle to wind the bobbin? The bobbin is very short because it needs to accommodate only the width of the bobbin. Older machines sometimes do not have thread spindles tall enough for the large spools of thread that can be purchased today. I cut a plastic drinking straw into a length long enough to accommodate the thread spool and simply slip the plastic straw over the thread spindle. Voila! A longer spindle!
Sep 04, 2017 | Sewing Machines
I am using invisible thread on my elude machine to zigzag appliqu?. Thread breaks often. Should it come off spool from bottom or top? Any other suggestions appreciated.
When we used nylon thread, we set the spool off behind the machine (on a stand-alone spindle or in a coffee cup. Then we attached a paperclip to the top rear of the machine and ran the nylon thread through the paperclip and the rest of the way through the thread guides to the needle. (We skipped putting the spool on the spool pin.)
Do NOT use nylon thread in the bobbin.
Jun 22, 2017 | Sewing Machines
How do I replace the spindle to hold the thread on my machine it has snapped off
sadly we can not say as we do not know the make of your machine . suggest you try the manufacturer's website for customer support .
Jun 18, 2016 | Sewing Machines
What is the best thread to use on the pixie plus machine. A lot of the threads do not fit.
I am not sure why they would not fit but embroidery thread is thinner than general purpose thread so it might work. Good luck.
Mar 25, 2015 | Singer Pixie Plus Sewing Machine
Why does my thread get wound up on the spindle of the pfaff 230 sewing machine
Do you mean the spindle that holds the spool of thread, on the machine's top ?
If it's winding on that, chances are it's something about the spindle itself. Check that there isn't a loose washer under the spindle. If there is, check the washer for any rough spots, it may need replacing. Make sure the spindle is firmly screwed into the machine, if it screws in. If it's welded on, make sure there are no rough spots. If all that's ok. try putting a felt washer under the spool. You can b buy them but they're easy to make. Just cut a spool base size circle out of firm felt, and snip a hole in the middle just large enough to slip onto the spool. A leather punch works great for this. If it's still winding up, check the instructions, if you have them, and make sure you have the thread coming out from the spool in the right direction.Some machines are very picky about how they are threaded. For some, the thread must come from the back of the spool, for others, from the front of the spool. Try both to see if one orientation works better. And last check there is no rough spot, either on the needle or any of the thread guides. If the thread is being chafed anywhere along the thread path, excess tension may result, which can cause the thread to start winding on the spindle. Changing the needle is easy. Changing a guide may not be, but if it's a guide that's got a rough spot, see if you can remove the guide and then smooth the rough spot using some very fine sandpaper or emery cloth. The entire thread path has to be perfectly smooth for thread to move as it should.
Oct 09, 2014 | PfaFF Sewing Machines
Sewing machine design
It sounds like the spool cap is broken or defective. It should fit snugly on the spool pin. If it is constantly falling off, then try finding a replacement. The horizontal spool pin design helps the machine pull the thread off the spool because the thread spool does not need to spin. The added pressure of spinning a thread spool contributes to tension issues (especially if you are using large thread spools that are so common now days).
On new machines, frequently the thread cutter is on the back of the presser foot lifter.
The thread guide above the needle is usually threaded from the left side because the thread tends to be pulled toward the right.
Unfortunately, what you are experiencing are pretty much common functions with most newer sewing machines, so even changing machines may not result in any greater degree of satisfaction.
Mar 31, 2017 | Singer Sewing Machines
Need to put bobin in a merritt 4530
Flip the presser switch up to raise the presser foot. Turn the hand wheel counterclockwise until the needle is in its highest position.
  • 2Hold the hand wheel in place with your left hand while turning the hand wheel knob counterclockwise with your right hand to loosen the hand wheel knob.
  • 3Place the desired spool of thread on the spool pin so that the pin fits all the way through the hole in the center of the spool. Put the spool holder onto the end of the spool pin that is sticking through the spool of thread and press firmly to ensure that the spool holder keeps the spool in place.
  • 4Grasp the end of the thread and hold it taut between the thumb and index fingers of both hands. Snap the taut section of thread into the thread guide post located to the left of the spool pin.
  • 5Pull the end of the thread gently. Wrap the thread around the bobbin winder tension disk near the left front on top of the machine, starting at the side of the tension disk facing you and wrapping around in a clockwise direction.
  • 6Poke the end of the thread through the small hole in the bobbin from the inside out so that the loose end of the thread sticks through the top of the bobbin. Put the bobbin on the spindle, or bobbin winder, and gently slide the bobbin winder to the right.
  • 7Hold the loose end of the thread in place while pressing down on the foot pedal to start the machine. Hold the foot pedal down until the bobbin is as full as desired. The machine will automatically stop once the bobbin has reached capacity.
  • 8Cut the loose end of the thread using scissors. Slide the bobbin winder to the left and remove the bobbin. Hold the hand wheel in your left hand and tighten the hand wheel knob with your right hand by turning it clockwise
  • Apr 05, 2012 | Singer 6510 Sewing Machine
    New Home sewing maching, using Gutermann thread to sew faced, turned "windows" (square)....PROBLEM: the machine checks, the thread pulls, seriously nests on the underside and I notice that the thread...
    1.put new spool of thread on
    2.watch the thread on the take up lever,make sure it doesn't come off
    3.check the tension disk for loose threads, if there are threads pull out
    4.check needle for being bent or blunt --if so replace
    Jul 29, 2010 | New Home HF-1012 Mechanical Sewing Machine
    Thread constantly wraps around spool pin
    Cut a round curcle of fabric the size of the spool from a piece of felt. Put a hole in the middle and put it under the spool of thread. If this does not work you can purchase a small net that fits over the spool. It is designed to keep the thread from coming off the spool except for being pulled through naturally.
    Hope this works.
    Zelma
    Jan 19, 2008 | Brother LS-2125 Mechanical Sewing Machine
    Tivax LSS-505 Model Michley Lil Sew & Sew Portable Sewing Machine, Double thread, double speed, Featuring 8 built-in stitch pattterns, Forward and reverse sewing, Automatic thread rewind, Sews sleeves, Drawer included, Use hand switch or foot pedal to star Logo
    124 people viewed this question
    Top Tivax Crafts & Hobbies Experts
    R.A. Ellis
    R.A. Ellis
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Are you a Tivax Craft and Hobby Expert? Answer questions, earn points and help others
