Question about Ovens
The fan on the halogen oven is making a rattling noise
When the fan goes round it rattles
barkencoa
  • 3463 Answers
SOURCE: NOISY OVEN
Yes, it can be fixed quite simply.
First check that the fan is not catching the cover or grill, if it is not remove panel covering fan and see if the fan blade is loose,on the shaft, they are usually held on by a left handed nut., so to tighten go the oppisite way to what you normally do, if that does not cure it, then your only solution is to replace the fan motor complete.
Plz rate my solution.
Thanks, and a merry xmas.
Posted on Dec 21, 2008
SOURCE: Rattleing noise when either oven is turned on
It could be a loose screw that has fallen from inside your back panel.... Be sure to turn off all power sorces before you access the panel to avoid electrical shock!
Posted on Dec 30, 2006
  • 200 Answers
SOURCE: Fan rattling in Hotpoint BS41 oven
Hi
Check this link
http://repair2000.com/oven.html
Posted on Sep 16, 2008
SOURCE: cooling and/or convection fan
I had the same problem. The screen protecting the fan bends into the fan from the heat. Take off the top front control panel (3 screws), reach in to the back where the fan is and push the screen back away from the fan. As always, turn the power off first to avoid shock. This should solve your noise problem.
Posted on Apr 14, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kitchenaid convection oven fan rattles/noisey
Sometimes the fan blade mounting nut gets loose. Remove the cover from the fan and see if the blade wobbles. If so,tighten the nut on the fan motor.
Posted on Jul 27, 2009
Why is the oven fan making a rattling noise
I do not no the specific model you have but chances are that the noise you are hearing is the bearings(or brass bushings) are going out in your fan motor. Which in turn allows the shaft of the motor to not remain true and rattles. In laymen's terms, you just need a new fan motor. I hope this helps. "Be Easy!"
Feb 25, 2015 | Ovens
Caple C3242SS Double Oven. Fan rattling in Main Oven when turned off after cooking on manual.
Since it is new contact the people that sold you the oven for warrenty repair.
Nov 18, 2014 | Caple Ovens
How to repair exhaust fan rattle?
You can look at fan closely and see if there is a set screw holding the fan to the shaft. It could be loose causing the rattle. If that is not the problem then see if the shaft has a lot of play in it. It could be worn out and allowing the fan to rattle. If that is the case then replace the fan
Apr 26, 2014 | Bosch HBL 642AUC Electric Single Oven
The oven makes a loud rattling sound when it reaches a certain heat (tends to be about 200 degrees) and then rattles intermittently until turned off. If you slam the door it does sometimes shut for a...
From what you describe is happening, I would say that it is the fan that is causing the noise, not neccesserily the oven fan, because there is an external cooling fan as well, and these are the only moving parts that could cause a noise.
Hope this helps.
Feb 02, 2010 | Candy FP855 Electric Single Oven
Convection oven making rattling sound.
It is most likeky that the fan bearing is worn and thus causing the rattling sound. You will probably need to replace the fan. Check first that there is no obstacle in the way of the fan rotating.
Replacement of the fan will require the back of the oven to be removed giving access to the fan unit, which will need to have the wires disconnected and the fan assembly unbolted. Fitting is the reverse.
Always remember to switch off the power before working on electrical equipment.
Jan 07, 2010 | GE Ovens
Fan rattles no does not heat
If the fan is working, but there is no heat in the oven at all, then it is going to be the element that is faulty, assuming it is an electric oven.
If the fan is rattling, then could be loose fan blade, or the bearings are failing.
Hope this helps.
Dec 14, 2009 | Smeg Ovens
Very noisy fan
Hi
you need to replace the fan as this will be the cooling fan which cools the oven down. and can not be disconneted .
regards
Mar 21, 2009 | Kenmore Ovens
Dec 27, 2006 | KitchenAid Architect Series KEBC208KSS...
Ovens Logo
297 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
