Question about Hardware & Accessories
How do I change the battery on an ET171C? Manual says battery is marked, but can't find it.
I have looked it over and even removed it from the housing to look at the back and cannot find the battery.
  • 5,670 Answers
You do not need to remove! Look at the screen and below that the 5 programming buttons and below that is the logo and battery compartment! Press and slide down to replace battery!
Posted on Dec 05, 2014
Need owners manual for fossil Big Tic Blue JR 8624
Inside the case back on my JR-7855 is a label with the steps to take to change the batteries. The sticker says to short the pad marked "S1" with the pad marked "+". Keep doing it quickly, then check the watch facelb_icon1.png. You got it right when the seconds start to change on the face.
Here is a view at the inside of the watch. The two points you are looking for are highlighted in red.
Ads by Google
Apr 02, 2014 | Watches
Timex electric watch not running
Hi Mark,
It appears to be a battery problem. Have you changed the battery recently? How have you checked the battery? I suggest you check the battery's voltage, even if it is a new, replaced battery.
You need to be sure the battery is not the problem before looking elsewhere.
Need more detail if this does not help, including the model of watch. Also how long has this problem existed, and when did you notice a change - was there a specific time/event?
Feb 01, 2014 | Timex Watches
My rebel xsi won't turn on. there is nothing. I used it yesterday and it was fine. I changed the battery and still nothing! HELP!
Hi please try to do this and let me know. Remove the battery and give a look inside the battery compartment with spot light. Make sure that place are clean and there no damaged mark. Specially look the Battery connector pins. That should in proper place , not bend, not even sulfur layer there. Use ear buds and drop of alcohol for cleaning. After checking if every thing Ok then some how the power supply not able to connect the circuit board. Its happens when the connectivity cable disconnected or damaged, circuit board short or the power transformer stop working. For all this internal fault part confirmation you need to visit electronic repair center.
but before visit for repairing make sure the battery which one you use that's is fully charged with working condition. Thank you
Aug 09, 2012 | Canon EOS Rebel XSi Digital Camera
When re-tuning, won't hold any stations at all when telly turned off. can get 76 digital stations
It sounds as though the tv's backup battery has failed. Unplug the tv and remove the rear of the case. Have an exlporitorylook about to see if you can find something which looks like a battery. On philips sets, they tend to be wrapped in plastic so look to see if anything which matches this description can be removed. If you dont feel confident then get a repair tech to take a look. The battery module itself shouldn't be too expensive, if you can find and remove the battery then look to see if there are any markings on it which you can use to search for.
REMEMBER
Even though the tv is switched off, it can still hold fatal charges of electricity
mess with it at your own risk.
May 06, 2011 | Philips Televison & Video
Hi,im removing the water pump on a 98 daewoo lanos its leaking all the coolent. Its looks tricky, ive removed the front wheel and wheel cover, ive then removed the belts and pulley, removeved front plastic...
hello. its not as bad as it looks. you can go to autozone.com create you an account cost you nothing totaly free. make your account add the car to you list. and then it will let you view the repair manual free of charge. it will tell you exactly how to change the pump and the procedure to aligning the marks and setting the tension. becareful. to no move the crank or cams after you have taken the belt off. just incase it is an interference engine. that means it would bend the valves hope this helps.
Mar 11, 2010 | 1999 Daewoo Lanos
Hi, I've misplaced my user manual for a Husky 2548xp lawn tractor. I've changed the belt for the cutters and now need to replace the drive belt. I'd like to know how to do this or receive a schematic...
Without even seeing the mower they are usually removed by loosening the bolts / nuts that secure the main cutter shaft, Look for slotted holes with bolts in is a giveaway.
Jan 20, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Changing a Battery on a 2007 Ford Galaxy 1.8 TDCi Zetec. The car is not starting I think due to the battery beind dead. Wanting to replace the battery and looked in the manual to find that it only tells...
I have just changed my battery on a 56 plate. You need to remove the air box in front of the battery compartment as the battery has to slide forward to come out. Firstly look down at the box and at the front is black rectangular pipe going to the air grill at the front of the car. At the top of the pipe is a plastic clip, unhook this and slide the pipe down away from the box. It takes a bit of force but it will clip out. Then at the back of the air box there is a large pipe with a circlip on it. Undo the circlip and remove the pipe from the box, You can leave the sensor in the air box and then just pull the air box free. It is only held in with rubber gromits. Once free move it to one side and you can remove the casing and then remove the retaining bolt holding the battery in.
Jan 06, 2010 | 2007 Ford Focus (3 Door) Hatchback
How do I change the battery in my Mitutoyo digital?
The battery compartment is on the front of the instrument. The cover is round and has some symbols that resemble arrows pointing down. Slide the round cover down to access the battery.
Nov 05, 2009 | Mitutoyo 500 506 10 Electronic Digital...
I have a 2002 ML320 benz keyless remote stopped working when I opened to change batteries they went flying i do not know how they were in I have tried diffrent ways still do not work
The batteries are flat like a nickel. the smaller end is the negitive end, the larger silver end is positive. Look inside the remote it will have marking corrisponding to the positive and negitive marks on the batteries.
Oct 10, 2009 | 2001 Mercedes-Benz M-Class
Hardware & Accessories Logo
65 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
