Question about Kodak Esp 1.2 All-In-One Printer
Kodak esp 1.2 will not power up
Printer will not power up have put volt stick on power cable appears all ok but no life showing at printer this is the second esp 1.2 i have had with the same fault cheers andy.
    Champion:
  • 219 Answers
Be sure that the power supply is receiving the voltage
Posted on Dec 05, 2014
  • Andrew
    Andrew Dec 05, 2014
    power supply all good but thanks for the reply.
I need a new printhead for my ESP5 how much is this going to cost and is it worthwhile replacing thankyou
The price of the printhead for Kodak ESP5 is approximately 45 US Dollars.I will suggest replacing your printhead because it will provide a better life to your printer
Jun 05, 2011 | Kodak ESP 5 Printer
How to manually reset printer
my kodak esp3 printer keeps showing usb port at the back of the printer not conected purchased new usb cable problem not fixed
Nov 28, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Mi impresora kodak Esp 5 Muestra en su pantalla " error de la impresora" Código de errro 6202" ¿Qué hago?
To quote Shockwave727:
6202 error code means that the scanner motor failed
to solve this
-Open the printer access door of your printer
-Unplug power cable
-then after 30secs plug the power able back
-If the printer is already power-up the message printer access door will appear
-Close th printer access door
-try to scan or print
If this issue not solve call tech support of kodak Toll free 1 800 421 6699
Sep 28, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
How do I clear a paper jam in the Kodak ESP-3 can't get to the paper
If you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below. Works for esp 7.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
Jan 17, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have Kodak esp 5 all in one- says I have paper jam--- but no paper inside
backward.
Jan 14, 2010 | Kodak ESP 5 Printer
Scanner motor move failed error code 6202
to solve this
-Unplug power cable
Nov 07, 2009 | Kodak ESP 5 Printer
No power light - there is power from the transformer
Please check the power cable of the printer and look for light indicator if theres a light indicator on the cable it means cable is roking fine (You can see the light indicator of the cable on the cable itself near on the power socket of the printer
Now if theres a power light on power cable., Please do not use the transformer. Please used the wall outlet or direct the power cable of the printer onto walloutlet socket
If this issue did not solve call kodak for repair toll Free 1 800 235 6325
Nov 02, 2009 | Kodak ESP 5 Printer
Esp 5 all in one printe paper jam shows error. can't see where the paper is jammed. where do you start?
Go to www.kodak.com/go/itg and try the step by step solutions. If still you do not see the paper,call kodak @ 1800 421 6699 and they will replace the printer for you free of cost,even if Your printer is more than 1 year old,as all Kodak Esp printers are under warranty. Kodak is the best. Enjoy ,keep me posted.
Sep 25, 2009 | Kodak ESP 5 Printer
Kodak ESP 3 printer does not print YELLOW
no,kodak replace printheads free of cost, and if they send a printhead and that doesnt solve issue and in next 30 days,u have same issue,then kodak sends a replacement printer. and esp-3 printers are considered o be in warranty tilll now even if they are 24 months old. kodak is the best.. ur issue will be resolved.dont worry
Jul 23, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak Esp 1.2 All-In-One Printer Logo
178 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
