Question about Kenmore Microwave Ovens
How do I replace a fuse on a Kenmore over the oven microwave oven. Model number 72189941490? Everything works but once I set time,etc., to cook or reheat, the time shows going down to zero, but no hea
Tried reheating something. I set timer, and pressed start and nothing happens. The light is on, the clock is on, all items work but the heat will not start
    Champion:
  • 219 Answers
It has a fuse located behind the main control panel. you will see it after you remove the cover
Posted on Dec 05, 2014
After pressing start, light goes on but not operating. Senor issue?
I had a similar problem once with an older Kenmore microwave, which at the time, were actually made by LG. After removing the cabinet, there was a small automotive type fuse in a clip-in fuse holder which proved to be "open" after checking it for continuity with a test meter. I replaced the fuse with the EXACT type and rating, and continued to use the oven for several more years until I gave it away. Please note, that microwave ovens are not something that you want to mess around with. Make absolutely certain that you have unplugged it before doing anything. In my case, I suspect the after several years of trouble-free use, the fuse had failed, -likely due to age. In your case, it may be a similar issue, so you might want to see if your microwave oven has a similar replaceable fuse. Beyond that, I would strongly suggest taking it to an approved service facility. Also, NEVER operate the microwave until you have replaced all covers, cabinet, etc. to it's original state.
Nov 12, 2014 | Kenmore Microwave Ovens
Why does the fan keep running on a kenmore spacemaster 300?
Check those 3 micro switches in the door latch assembly. A bad microswitch can blow the main fuse. This usually ruins the microswitch.
Nov 13, 2017 | Kenmore Microwave Ovens
Digital button on kenmore microwave does not respond when pressed could this be a fuse or is key pad gone
Considering the problems you are having it would be cheaper to replace the microwave oven.
May 22, 2012 | Kenmore Microwave Ovens
On model mh1160xss-0 whirlpooll microwave the fuse blows everytime you turn on cook
The magnetron is shorted or the inverter board is defective if microwave is 7 years old or less.
May 16, 2012 | Microwave Ovens
Microwave turns on but doesn't cook
There is an inline fuse that is accessed by removing the outer casing. Follow the power line in to the magnatron and you should see the fuse. Make sure the fuse that you replace it with is the same as the one you removed. If this doesnt work then the magnatron has gone out.
Dave
Mar 31, 2010 | Kenmore 80012 Microwave Oven
Does everything but heat food.
Sounds like the magnatron tube or it's fuse.
Aug 11, 2009 | Kenmore 80809 Microwave Oven
Grinding noise from turning platter mechanism - Kenmore #63252
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 23, 2008 | Kenmore 63252 Microwave Oven
Just stop working
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 07, 2008 | Kenmore Microwave Ovens
Kenmore 665.61629100 Microwave Problem
The 665 prefix on your model number is Whirlpool, but I haven't found the code "d" listed yet.
Can you set the cooking time?
If so, what happens when you press Start?
I'll post back if I find the codes or if you have other info and I can help further.
Oct 13, 2007 | Kenmore 63792 Microwave Oven
Microwave Ovens Logo
217 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
