Question about Crafts & Hobbies
How to you get the music to play on the Rudolph the Red Nose Reindeer MTH train? It play once, but I've never heard it again. The bells and horn and Santa's Ho Ho Ho all work, but no music.
4 Suggested Answers
  • 103 Answers
SOURCE: Tried to play our Rudolph
Check the actual DVD player menu after movie starts there should be a language option there. Also there is an option on the TV (called SAP) which makes whatever plays through the tv into spanish make sure that is off while on the same channel your dvd plays on.
Posted on Dec 15, 2010
adamfjeld
  • 1508 Answers
SOURCE: we've got a santa fe
sounds is run by 3 aaa batteries under the smoke stack and train is run by 6v battery under the seat, 6v battery probably need to be connected or recharged
Posted on May 22, 2012
99rannellis
  • 12009 Answers
SOURCE: was Bob May the originator of Rudolph the red nosed reindeer
You need to do the research for yourself. We don't do homework here...
Posted on Dec 23, 2016
I NEED A SCHEMATICS MTH TIU
Request them from MTH.
Sep 19, 2016 | Crafts & Hobbies
I cannot get my MTH engines to run properly. Power is on, bell and horn sounds, lights are on
MTH locomotives have internal batteries that may need to be replaced. The circuit boards in some older MTH locomotives can be damaged if operated with discharged or faulty batteries. Contact MTH customer service for help with your engines.
Feb 07, 2015 | Crafts & Hobbies
Which command base will work with MTH dcs
You will need to add a TMCC Command Base and the required TIU/TMCC serial interface. This will allow you to control Lionel engines with the DCS remote. Please see page 100 of the DCS Operators Manual fifth edition.
Nov 13, 2014 | Crafts & Hobbies
Lionel train problems
Make sure the A or D terminal is connected to the center rail. U terminal to the outer rail. First do this without the sound activation button. Horn should sound this way. Once this works correctly, add the sound button in on the center rail lead (A or D) If the sound activation button activates the horn, reverse the connections to the sound activation button.
This should solve your difficulties
Dec 04, 2013 | Crafts & Hobbies
Santa sent his reindeers, Prancer, Dancer, Comet, Vixen, and Rudolf, each to a different city, each with a sleigh of a different color, to bring various gifts to good children. Comet was sent to Chicago,...
The trick to this is to list all the reindeer.
Write down what you know about each reindeer. Tick the list.
Then use a process of elimination to work the rest out.
The answer is here.
Discussion Board View topic Santa sent his reindeers
Mar 01, 2017 | Miscellaneous
I KEEP HEARING A RATTLING AND A BELL JINGLING SOUND
Three things come to mind. A heat shield is loose, The inside of the converter is going bad or you ran over a reindeer!
Dec 30, 2011 | 2005 Cadillac SRX
My cw-80 Lionel transformer has button issues when operating both traditional and tmcc loco. the horn and bell sounds are goofy. and on some of my traditionaltenders the sounds are still on when the...
The CW-80 is not suited for electronic sound systems. The output is non-sinusoidal. When electronic sounds are generated for some locos, the sound will be garbled. Use another power source. The Z1000 MTH power source or similar is recommended as are many other older Lionel standard power xfmrs. For the sound stay on problem with switch off, try putting a fixed load on the tracks ie: An accessory of some kind (lights etc). Usually a fixed electrical load will fix this problem. Overall, I would recommend changing out the power source and save yourself a lot of headache..
May 14, 2011 | Lionel Cw 80 Transformer
Tried to play our Rudolph the Red Nosed Reindeer for the holidays, and all of a sudden the movie will only play in Spanish. The DVD has a Spanish language version, but I hadn't used that option. There are...
Dec 15, 2010 | Televison & Video
Crafts & Hobbies Logo
50 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
