Question about Kenmore Sewing Machines
I can't get my buttonhole maker to work on my model 385-15516000 kenmore. The thread just bunches up. Help!
  • Kenmore Master
  • 1,860 Answers
Try a new needle
does the machine have a button hole lever that has to be pulled down?
is the machine in the darn position
Posted on Dec 11, 2014
Singer Advance: Buttonhole getting stuck and not advancing fabric
make sure the buttonhole lever is pulled down
make sure to use the right needle for the fabric being sewed
make sure the to thead has not come off the thread take up lever
also could be a problem with the feed dogs, look in the manual
and see where the feed dog lever is and check to see if it's in the
up position, if the feeddogs are in the up position then the feeddogs need to be checked to see if they need to be adjusted.
Dec 17, 2012 | Sewing Machines
I cannot get my buttonhole function to work can you help?
check to see if you have a button hole lever to the left of the needle
the button hole won't work till it's pulled down
here's a link for a free manual to download
http://www.singerco.com/uploads/download/1228_3323s_talent_esf.pdf
Sep 08, 2012 | Singer 3323S Sewing Machine
Cannot get the auto buttonhole to work..it beeps and I can't find the problem
there is a button hole lever to the left of the needle & you pull it
down gently against the button hole foot & the beeping should
go away
Aug 25, 2012 | Singer Confidence 7469 Mechanical Sewing...
Bottom thread bunches
try changing the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or thread
make sure the bobbin is inserted correctly into the bobbin case
if none of these suggestions help then it's possible that the machine is out of time & needs to be serviced
May 18, 2012 | Singer Sewing Machines
Brother sewing machine cs2000i botton hole problem as follows the foot stays in place and does not feed. I have changed the thread, looked at the video, clean any clogs. What is it?
it does not specify if this machine is electronic or mechanical, but electronic sewing machine,,like mine have what is called a buttonhole lever & unless that buttonhole lever is pulled gently down the buttonhole maker will not work.
that may be the problem with the machine
or it maybe the feeddogs may not be working,,check the feeddog knob or lever to see what position it's in,,up position is for sewing & down position is for darning
Feb 01, 2012 | Brother Sewing Machines
Kenmore 385 model Automatic Button Hole Apparatus Jams Thread?
Practice and practice some more! Use the same fabric and interfacing as your project and a NEW needle (the correct needle) This is for the Sears Kenmore 385 automatic button hole maker. Make sure you pull the bobbin thread through the Guide Block - it is that simple. Make sure you pull your thread to the back of the machine though the presser foot slot - the correct presser foot. Account for both thread tails before starting to sew. Keep thread tails to the back of the machine 4-5", insert fabric under presser foot keeping thread tails clear. Mark button hole and sew.
Mar 30, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Bernina Buttonhole foot #3A
Hi, you must have an 1130S which means it could also be a circuitboard issue. If the LED/LCD light for the buttonholer does not flash you either need a new RET-Print (circuitboard) or a new buttonhole foot. Sorry to say that you DO more than likely need a new buttonhole foot according to my manual on this machine. No way to repair the foot that I know of.
You should bring the machine in and try it first.
Guess not all news is good news. Sorry.
Rick (Bernina tech)
Aug 18, 2008 | Bernina Virtuosa 160
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Machine made buttonholes.
Here ya go! For 1 Step Automatic Buttonholes: 1. Place button into the buttonhole attachment. 2. Push slider to hold button securely in the slot. The button goes to the back! 3. Put button foot onto needle bar--just attach it securely. 4. Place needle thread and bobbin thread UNDER buttonhole attachment and let 4"-5" of thread trail behind it. 5. There's a lever called a Button Stop to the left of the needle bar. Give it a gentle tug and pull it down. Pull forward. Hear a click? Now the machine knows what length to STOP sewing! 6. Put foot on pedal and machine will sew barrack closest to you first. It will continue all around until it makes complete rotation of each side. 7. You must do these steps for each of your buttonholes! IMPORTANT: Make sure you set your dial for making buttonhole pattern because that "tells" machine to zig zag, and use appropriate size needle for the particular weight of your fabric. A new needle before you begin is recommended. Turn screw on needlebar to loosen screw. Hold it so it does not slip down into the feed dog area! New needle is inserted flat shank toward back of needlebar as far as it will go. Tighten screw. Did this help? Hope so!
Jimmy
Mar 03, 2008 | PfaFF Tiptronic 2030
Sewing Machines Logo
62 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
