Question about Dryers
Why does my Frigidare crown dryer runs smooth when starts up, but gets a noise that gets louder the longer it runs it runs
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
Either your drum bearing or drum felt kit is worn out. It is always better to put drum bearing along with new drum felt kit.
Posted on Dec 06, 2014
Brown Burn Stains and little holes from FRIGIDARE GALLERY HEAVY DUTY STACKABLE DRYER
If you are using LP gas make sure the dryer is set to LP on the regulator. If a natural gas dryer is run on LP you will get way to much flame.
Jan 02, 2014 | Dryers
Siemens Siwatherm TXL 2100
I reckon the belt snapped leaving the tensioner to rub against the drum,(making the noise) then the fuse blew. This happened to me.
Dec 12, 2013 | Dryers
Ford crown vic engine makes a knocking noise
sounds like you broke a connecting rod...drain your oil look for metal..
Mar 12, 2013 | 2004 Ford Crown Victoria
2001 crown victoria lost oil pressure and just cut off now when i start the car after five mins the car start ticking really loud
i have a 2001 crown victoria was driving down hwy car made loud noise and shut off had it towed home got it started and has NO power almost couldnt get i in drive way, had been making a slite noise before that and bucking
for about 4 months in the last 3 weeks noise was getting louder. Was told could be timing chain how likely is this and how do i check it.
Sep 30, 2012 | 2001 Ford Crown Victoria
I have a fridgedair electric dryer m#fer311fs0,making a constant noise and gets louder the longer it is on.not a high pitch sound.i pressed on idler pully and it seams to quiet down?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 23, 2011 | Frigidaire GLER341A Electric Dryer
I have a Kenmore 80 series dryer. When we start the dryer the unit gets a loud noise it will run through a few loads but then the noise will get louder then the dryer will cutoff.
heatman101
Oct 20, 2010 | Dryers
Ticking getting worse!
heatman101
edgfd
Sep 30, 2009 | Bosch Nexxt 500 Dryer
My frigidare heavy duty crown series not heating
sounds like you have a cloged vent i normally get a few calls in the winter timer for this problem because the vent is clogged outside due to the snow remove your vent try the dryer to see if it dries if yes check your vent
Mar 15, 2009 | Dryers
Real bad squeaking noise in dryer
Yes check the brake. Just open the back panel and look under the machine. Check the brake latch and make sure that when the unit starts to spin that the brake backs itself off and also make sure that the bad is not worn down. If it is then replace it. A few screws and off it comes. To check the pulley and the belt there is really no wrong way to do it. First look at the belt and make sure that it is not cracked or really smooth. If that checks out ok then make sure that it is attached to the pulley fully and that the pulley is not bent
Feb 13, 2009 | Maytag Performa PAV2200
Brand new Dryer with loud noise and hot
contact bosch for factory service on the unit
May 10, 2008 | Bosch Nexxt WTMC 6300 Electric Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
