Question about Alcatel One Touch C750 Cellular Phone
What can cause my phone its just close even its charging,wht is the best way to open its back
I try to open it but I cant,what can I do to solve it
My phone is restarting after welcome screen. i cant update it cause i cant set the usb mode to pc suite and i cant restore settings. i tried nokia sotware updater, jaf nothing works they cant detect p
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 25, 2012 | Cell Phones
My iphone wont turn on or charge
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Sep 10, 2012 | Apple iPhone 3G
Why when i charge my bb the touc doesnt work|?Wht can i do?/
I changed the battery and the wall charger , found out the earlier charger pin was faulty causing the screen to hang while trying to use during charging
Nov 23, 2011 | RIM BlackBerry Storm 9530 Smartphone
My iphone 3gs can not open, it hang then it shutdown automatically
i cant switch off my phone neither even do anything about it because it has got hanged so wht should i do
Sep 12, 2010 | Eforcity Apple iPhone 3GS 16GB / 32GB...
Would like to know how to turn headset back off...
hi :) wanna ask your phone has water damage right ?? ok,if some water has been remain at the area of charging or headset port,will make your phone show in headset mode,when i n headset mode,that why u cant hear people talking.but once u plug in headset,i sure u can hearing.it cant be solve even how many time u turn on and off your phone. what to do ?? u should send for technician open up your phone to clean up inside.
if my solution useful,please give me rank. thanks.
Jul 19, 2010 | Pantech Matrix Cell Phone
Opening/closing the keyboard slider often switches the phone off
hi,....
This may be because there may some water log present inside it which is preventing from charging and making it to often switch off by shorting some lines when current is passed through it.
NEVER charge your mobile when it get wet.even though it works well after drying there may be some water log which may cause the circuits to short and even cause shock to the person using it.
please give to the service centre they wil remove the water logs in it and the phone wil properly after that.
thanx
Jul 18, 2010 | Nokia N900 Smartphone
My sony ericsson w995 won't start,ive tried charging it...but all that happens is that the red light on the back flashes...ive tried everything,please help!
Very simple.Just follow this steps:
1. Connect the charger.
2. While the charger connected, open the back cover and close the cover again. Your phone can be switched on now. This is because this phone got sensor that ensure the back cover always closed while the phone operate.
3. If the above steps not working, try remove the battery while the phone is connected with charger.
~ Please encourage me to help people like this by donating small amount to my PayPal account.Thanks dude.
My PayPal id : ruzaini88@gmail.com
Feb 19, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Subsidy Lock?
if you give me your imei number i should be able to get you the code that overides the code it is asking for but i cant get them for all phones but give me your imei number off the back off your phone this worked on my nokia 6230 so cant see why i cant get the code for your phone aswell alot of people charge for this info but as i dont get charged im not going to star charging people your imei code will look something like 123456/12/123456/0 post back and i will try my best to help you ok.................
Nov 22, 2007 | Motorola Mobility i850 Cellular Phone
Alcatel One Touch C750 Cellular Phone Logo
Top Alcatel Cell Phones Experts
Gene
D. E. Hev
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
