Question about Honda 3000 Watt Portable Generator
What causes blow back out of the carburater? - Honda 3000 Watt Portable Generator
    Scholar:
  • 145 Answers
Make sure that the exhaust is not clogged.
Posted on Dec 05, 2014
HARD TO START WON'T REV ACTS LIKE CHOKING OUT
Your problem could be a simple carburater adjustment. Air fuel mixture may be off. There may be adjustment screws on the side of carburater, adjust they slightly to see if this fixes it. If not the carburater itself may be dirty and need to be taken apart and cleaned. Hope this helps.
Sep 27, 2015 | Garden
How to take our carburater from pulser 150 DSTi
then you have to move whatever is in the way .
May 02, 2015 | Bajaj Pulsar 150 Motorcycles
My coleman 2500 powermate generater leak from top of carburater, help
The carburetor needs to be rebuilt - the float valve is stuck open.
Jul 05, 2014 | Coleman Powermate Portable Generator...
Leaking carburater
The float valve in the carb is sticking or the float height setting is incorrect or the float has a hole in it.
Do not use Pri on your fuel tap until this is sorted as it could cause hydraulic lock in your engine, which will wreck it. Fuel will flow through your carb into the engine when it is parked.
This will also ruin your engine oil as the fuel will mix with it. Check the oil level to see if it has increased...
Apr 11, 2013 | 2008 Keeway Supershadow 250
Oil being blowend out of the fuel pump and smokeing
its probably got a hole in the fuel pump diaphram just by pass the fuel pump and see what happens
Dec 03, 2012 | Garden
Carburater schematics diagram for a 2004 arctic cat 300
Go to http://www.arcticcatpartshouse.com/arctic-cat-atv-parts.aspx?aribrand=ARC#/Arctic_Cat/2004_ATV_300_4X4_GREEN_MRP_%28A2004ATF4AUSS%29/CARBURETOR/A2004ATF4AUSS/A2004ATF4AUSR.
Oct 13, 2012 | Arctic Cat Racing Carberator
Carburater blowing gas out instead of sucking in on 23hp kohler engine
it sounds like one of the valves is not seating do a compression test and see what cylinder it is a valve not seating will cause the compression to blow back threw or the exhaust valve is not opening
Jun 02, 2012 | Garden
I have a walbro carberator that squits gas out of a little hole on the side near the top of the carb why?at the top why?
Probably the needle valve is sticking, letting the float bowl over flow. Remove the float bowl, and blow very low air pressure (less than 5 psi) through the fuel line. lift the float and see if the air blows past the needle and seat. If it does check the needle and seat. Sometimes a deteriorated fuel line will cause little bits of rubber to keep the needle valvefrom closing. If raising the float does shut off the air flow remove the float and check it.Brass floats on old carburetors can develop pin holes allowing fuel to enter the float causing it to drop. This keeps the float valve open. Some non metalic floats can become fuel soaking causing the same problem.
May 07, 2012 | Stihl Walbro Wt-160b Carburater For An...
Honda 3000 Watt  Portable Generator Logo
57 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
